Interior/Exterior Any experience with brush on plasti dip?
So I blacked out my beltline with electrical tape, and like the way it looks. But I want something more permanent and was thinking to paint it, but I don't want to tape off the whole car, and I heard removing the trims are a pain. So why not brush it on? At least that's what i'm thinking. Has anyone tried or experimented with this? I figure it's another cheap alternative to consider. I've already got some plasti dip on the way to me, it's in a can, non aerosol style, and will give it a shot this weekend. But I wanted to see if anyone has already tried this, or any experience with the brush on stuff. Tips and suggestions are appreciated.
The biggest problem is that your going to be brushing a vertical surface. Brushing Plasti-Dip goes on extremely thin. If you put on to much you get drips. It may work if you put on about 10 - 15 coats. Tapping the car is pretty easy if you use some plastic like the disposable paint tarps. Make sure to really shake or mix the Plasti-Dip good. Let us know how it goes.
https://www.outmotoring.com/mini-coo...tline-kit.html
Your better off just buying that, it's only 13 dollars and it'll save you a LOT of hassle
It is legit vinyl. It has backing you remove and apply it. Once applied you pull the clear covering strip off too. It is the perfect width, won't soften like electrical take, leaves no residue like electrical tape, doesn't stretch like electrical tape....all around better than electrical tape.
I tried E-tape and halfway through 1 door I knew it was a mistake, plus it gets hot here in SW FL and it began to soften and droop.
alrighty...so I tried painting on the plasti dip....don't bother. lol it looks like crap, and really isn't easy to put on. I only did one small piece of the beltline, and there is no way in hell i'd be patient enough to try and do the entire thing. Now I just have to wait for it to dry so I can try and peel it off. I've already got a call into vinyl styles for their kit. Can anyone tell me how to add one of their items to their shopping cart? I cannot find where to add it so I can do the order online.
patsum
26
May 29, 2021 06:29 PM
tag1260
Tires, Wheels, & Brakes
Sep 10, 2015 08:57 AM
