Interior/Exterior Help id this intake
Old Jan 17, 2012 | 08:38 AM
Gamble_Rumble's Avatar
Gamble_Rumble
Help id this intake
Hey guys, I got my mini cooper a while back and i am finally in the mood (financially) for some changes.
I wanted to know if this intake filter I have is replaceable or I can wash it...like K&Ns and all.
So I looked at it, and it says ALTA on the metal box, and alta on the blue tube however the filter doesn't look like ALTA...could the previous owner installed a different one?
HELP
also, if it is not ALTA what is it? and can I buy ALTA and install it myself?
here is a picture for you guys to tell me what to do :(
Old Jan 17, 2012 | 09:51 AM
itsartem's Avatar
itsartem
yea thats the alta silicone hose and the alta housing but thats not the alta foam filter. you can buy the filter straight from alta. i believe those cone filters are harder to clean than the alta foam filter.
http://www.altaperformance.com/produ...TA-Foam-Filter
Artem
Old Jan 17, 2012 | 10:00 AM
Gamble_Rumble
Any idea what type of filter it is? If its K&N I'd like to buy a cleaning kit unless a new one from ALTA is cheaper. Hmm
Old Jan 17, 2012 | 10:10 AM
ljmattox's Avatar
ljmattox
From the reddish-filter media hue, and the screen size I'd bet it's a K&N of some type.
Old Jan 17, 2012 | 10:21 AM
Gamble_Rumble
So what does NAM suggest? Spend the 51 dollars on a new filter or.... 13 on a cleaning kit lol.... This is silly. I bought the car like this :(
Old Jan 17, 2012 | 11:02 AM
drsimmons's Avatar
drsimmons
It looks like a K&N. The blue ones are NM Engineering Products.
You can use either cleaning kit for either filter. Only diff. is the color.
Old Jan 18, 2012 | 06:19 PM
xnotfunkylex's Avatar
xnotfunkylex
Do you have a Cooper S or a Cooper? That makes a huge difference on if this will fit or not.
Old Jan 19, 2012 | 05:02 AM
Gamble_Rumble
It's a 2005 S. what won't fit Funky?
Old Jan 19, 2012 | 05:16 AM
mdsbrain's Avatar
mdsbrain
I'd say get a cleaning kit and keep the current filter. If it doesn't clean to your satisfaction then replace the filter.
Old Jan 19, 2012 | 06:11 AM
Applesauce's Avatar
Applesauce
Holy smokes! Look at that strut tower bar! Makes mine look like a toothpick...
Looks like a K&N filter to me, but there are plenty of eBay lookalikes. It should have K&N (or a K&N part number) embossed on the flange someplace, if indeed it is. But you might have better luck with drivetrain-related queries on the drivetrain board.
Old Jan 19, 2012 | 06:41 AM
MSFITOY's Avatar
MSFITOY
Most likely K&N...even if it's not, it still the same type....you can go to any motorcyle shop and get K&N cleaner and re-oil kit cheap...don't over oil it tho...
Old Jan 20, 2012 | 03:14 PM
xnotfunkylex
Just making sure you had an S. That intake will fit fine.
Old Jan 20, 2012 | 03:27 PM
quikmni's Avatar
quikmni
Buy a cleaning kit and keep the filter. Most local Auto Parts stores carry the K&N cleaning kit for about $20.
Old Jan 20, 2012 | 11:03 PM
xnotfunkylex
And auto or manual?
Old Jan 27, 2012 | 05:21 AM
Gamble_Rumble
It's auto. I'm tempted to take it off to see if it's a version 1 madness filter, or a K&N. The cleaning Kit is around 16 dollars. Too cold for now to work on it myself.
Old Jan 27, 2012 | 05:22 AM
Gamble_Rumble
I dont even have the tools to remove that sway bar.
Old Jan 30, 2012 | 12:17 AM
xnotfunkylex
HAHA, I just realized that the filter is already on your car. I guess I'm a little slower than I thought I was.
rtk90
Aug 29, 2019 09:08 AM
67morris
May 7, 2016 11:52 AM
Sep 22, 2015 02:05 PM
knbond1
Sep 22, 2015 06:20 AM
Sep 11, 2015 11:09 AM
