Interior/Exterior Yakima install help
Old Feb 11, 2004 | 02:53 PM
BuckeyeMCS's Avatar
BuckeyeMCS
Ok all I have looked at the installed pictures here on NAM and mine is not even close to right. I have my M2 at 6 inches and my M4 at 18 inches. That lines the rear bar up on the front edge of the rear window. I noticed that all the pictures have both bars lined up above the front window. What am I doing wrong here?
Old Feb 11, 2004 | 03:15 PM
dave's Avatar
dave
pug poo picker-upper
Are you taking your M4 measurement from the center of the front load bar to the center of the rear load bar?
Old Feb 11, 2004 | 03:22 PM
dave's Avatar
dave
Here are some pics from my Install:
Old Feb 11, 2004 | 03:23 PM
BuckeyeMCS's Avatar
BuckeyeMCS
I am now.
Sometimes I think if I had 1/2 a brain I would take it out and play with it
Thank you DiD
Old Feb 11, 2004 | 03:32 PM
dave's Avatar
dave
Also recheck your M2 measurement. You should be measuring M2 to the centerline of the front load bar.
FIT TIP: IF you have a sunroof on your MINI, when the rack is properly fit, you should be able to open your sunroof and check the position of the front loadbar by looking at the deployed wind deflector. The sunroof wind deflector should line-up pretty nicely with the front load bar (the sunroof wind deflector actually has a little bit of a wedge shape to it, so this isn't an exact standard).
Dave
Old Feb 11, 2004 | 06:00 PM
BuckeyeMCS's Avatar
BuckeyeMCS
Dave,
How wide did did you place the mounts? I put the Viper mount as wide as it would go.
_________________
Got Faith?
Old Feb 12, 2004 | 07:34 AM
dave's Avatar
dave
:smile:
I put my THULE Velovice bike mounts as close to the Q-Towers as I could get them.
The first time you open the sunroof, I would recommend you do it while standing outside the car. This will allow you to check that the clips holding the trays to the rear load bar are not going to interfer with the sunroof.
Old Feb 12, 2004 | 08:07 AM
sambusik's Avatar
sambusik
Buckeye, were you easily able to lock all four cores?
Old Feb 12, 2004 | 11:04 AM
BuckeyeMCS's Avatar
BuckeyeMCS
Yes that was really easy.
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 12, 2015 01:24 PM
