Interior/Exterior replacing rear wing.
Old Feb 6, 2004 | 12:06 PM
aokdoug's Avatar
aokdoug
hi all.
trying to replace the stock s wing with the
aero wing.whats the secret besides the 2 end bolts?
did all the search stuff.no good. bridger page comes
up blank. any help please.
thanks doug
Old Feb 6, 2004 | 12:32 PM
dave's Avatar
dave
pug poo picker-upper
I had this done as one of my first mods.
- Open the Hatch
- Locate the three black plastic caps
- The two outer ones cover the nuts that thread onto the studs from the S spoiler
- Once you get the nuts off, the S spoiler is also held in place with a foam tape adhesive.
I paid a bodyshop $60 to remove my old spoiler and install the aero spoiler. Then sold my S Spoiler here on NAM to someone that had a COOPER with no spoiler.
For those who are wondering about the differences between the MINI spoilers, here is a review of all the MINI spoilers. The Aerokit spoiler is totally different than either the Cooper or Cooper S spoiler (see below)
The Cooper with no spoiler
Old Feb 6, 2004 | 12:55 PM
aokdoug's Avatar
aokdoug
hi did.
i only have 2 caps &no 3rd.one {no middle}
just 1 at each end.must take a hard pull
feels real set in place.just do not want ruin
anything.
thanks, doug
Old Feb 9, 2004 | 09:59 PM
maxmini's Avatar
maxmini
Use a heat gun and monofiliment fish liine to remove the old spoiler. Its a real pain but it will come off with no markings if you are carefull. I did it last week to install the M7 wing.
Old Feb 10, 2004 | 03:36 AM
aokdoug's Avatar
aokdoug
thank,s all. did it sunday no sweat.
heat-gun fish-line plus a wedge
from floor for constant& slight pressure.
a little denatured alcohol helps also.
doug
Old Feb 12, 2004 | 09:39 AM
MSFITOY's Avatar
MSFITOY
Maxmini,
Could you elaborate on the installation of the M-wing? Does it use the same holes or no. Does it need new holes drilled? Does it need caps to cover old holes?
Thanks much,
Sid
Old Feb 12, 2004 | 09:46 AM
dave's Avatar
dave
The M7 wing uses different mounting hole locations.
I believe Peter said he supplied a set of plugs for the old holes.
Old Feb 12, 2004 | 01:48 PM
MSFITOY's Avatar
MSFITOY
DiD...so this wing requires drilling new holes into the hatch?
Old Feb 12, 2004 | 02:25 PM
dave's Avatar
dave
That's what it looks like.
Old Feb 12, 2004 | 02:33 PM
MSFITOY's Avatar
MSFITOY
hmmmmm.....have to think about that very carefully. I wonder why Peter didn't use the original holes like JCW does?
Sid
Old Feb 12, 2004 | 02:39 PM
dave's Avatar
dave
See how in the picture above the M7 M-wing has it's supports at about 1/3 span. The S-spoiler mount holes are only a couple inches in from the outer edges of the hatch.
You can actually see the plug'd / dimpled area in this picture where the original mounting holes are located.
Old Feb 12, 2004 | 04:19 PM
MSFITOY's Avatar
MSFITOY
Yes, thanks. But I still don't understand about not mounting in the original holes like JCW wing.
boostedhaze
Jan 2, 2018 07:26 PM
squawSkiBum
Oct 2, 2015 09:21 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
Minibeagle
Aug 13, 2015 10:00 AM
