Interior/Exterior HAHAHA!!!! Dealer wants $1250 to install temp gauge.
Old Apr 5, 2011 | 04:41 PM
Headlands's Avatar
Headlands
Are you freaking KIDDING me!? A cheap little temperature gauge and installation for $1250???
Obviously I'm not that much of a fool to do it at the dealer, so can someone point me to a good temperature gauge that I can have Mini Corsa add on?
Thanks much!
Old Apr 30, 2011 | 08:02 PM
TBangin23's Avatar
TBangin23
Bump...
I'm kinda interested in doing so also. Had a little scare last week with the thermostat housing going bad, and didn't even know the car was almost gonna over heat. So any advice would be appreciated.
Old May 1, 2011 | 12:18 AM
unibus_driver's Avatar
unibus_driver
Less expensive temp gauge.
Buy a ScanGauge. It will tell coolant temperature, and many other things, your choice as you set it up.
Old May 1, 2011 | 12:23 AM
maxmini's Avatar
maxmini
Was just going to say this . It's much more than just a gauge and you can install it yourself
randy
M7 Tuning
http://www.amazon.com/ScanGauge-Auto...4234579&sr=8-1
Old May 1, 2011 | 04:23 AM
MiamiGuitarMan's Avatar
MiamiGuitarMan
Look into the garmin ecoroute usb attachment and one of their GPS units that work with it. Will give you all kinds of gauges including temp and also a GPS to boot!
Old May 1, 2011 | 06:16 AM
NightFlyR's Avatar
NightFlyR
If you happen to have a droid phone already, download the torque app, then get the wireless bluetooth adaptor from amazon for 35 bucks and you will have alot more guages and choices of set ups with no wires and a 5 minute setup
Old May 1, 2011 | 07:07 AM
NightFlyR's Avatar
NightFlyR
Some pictures of the Torque app
Attached Thumbnails HAHAHA!!!! Dealer wants 50 to install temp gauge.-100_0364.jpg   HAHAHA!!!! Dealer wants 50 to install temp gauge.-100_0373.jpg   HAHAHA!!!! Dealer wants 50 to install temp gauge.-100_0367.jpg
Old May 2, 2011 | 12:06 AM
maxmini's Avatar
maxmini
Thats pretty cool , is there anything similar for the Iphone4 ?
Randy
Old May 2, 2011 | 12:17 AM
ThumperMCS's Avatar
ThumperMCS
Randy
Rev
Old May 2, 2011 | 05:30 AM
Derk's Avatar
Derk
Which bluetooth adapter are you using? This one? Besides what I see in your pictures, what sort of readings can you get with that app?
Old May 2, 2011 | 08:36 AM
Headlands's Avatar
Headlands
These are great suggestions, thanks.
I like the ScanGauge...just don't like how it looks, personally. I love the old analog gauge look myself, though I might just go for it anyway.
Old May 4, 2011 | 01:13 PM
zeiker's Avatar
zeiker
Thanks for the tip - this is a cool idea and a simple solution to our gauge issue.
Old May 4, 2011 | 04:56 PM
NightFlyR's Avatar
NightFlyR
That is the adaptor I am using, as for the App, there is more then one, I am using the torque version, there is a free one, but I went with the one you pay for.
I cant even count how many reading your get, the version I have not only give's you the cars readings, it gives you 0-60 times, quarter mile times, 3 different types of displays, either graph, digital or Dial, many different types of colors and you can arrange them anyway you want. I am still learning with all it can do. I had the scanguage before, but I like this better
Old May 4, 2011 | 05:28 PM
steve216's Avatar
steve216
so I'm guessing if you dont have bluetooth option for your car you cant use that phone app?
Old May 5, 2011 | 12:12 AM
Davidoyo's Avatar
Davidoyo
I am pretty sure you don't have to have the Bluetooth option. The adapter sends out a Bluetooth signal and an iphone or similar device picks up the signal up.
Old May 5, 2011 | 03:09 AM
NightFlyR's Avatar
NightFlyR
The adaptor is a bluetooth device it plugs into the OBD11 port and then the phone reads it, so far I have not had any problems with it
Old May 5, 2011 | 04:22 AM
Walt's Avatar
Walt
Can you have more than one bluetooth connection at a time with a phone?
Or if you are using an OBD11 adapter, you can't use a bluetooth handsfree system too?
Old May 9, 2011 | 03:11 AM
Davidoyo's Avatar
Davidoyo
Hey guys, couple of questions. I am trying to find a good iPhone app that is like the Torque app.
The only results I have come up with are the Rev and Dashcommand app.
I have read both bad and good reviews for both and don't know what to get. Does anyone have any experience with either of these apps?
Also, as long as the Bluetooth adapter is ELM 327 will it work with both of these apps? Thanks
Old May 9, 2011 | 03:59 PM
japtor's Avatar
japtor
There's a free one called LogWorks, try that one out, although I'm not sure if it works with Bluetooth adapters.
I know Rev has a free lite version that at least shows what it can read from your device, so try that to at least see what the full one would be capable of showing.
Otherwise on the more enthusiast racer end of the spectrum, there's an app called Harry's LapTimer (and LapTimer Pro) that seems to be able to do some other cool stuff (lap timing, GPS mapping and tracking your speed and G-forces) but I don't think it has basic gauges like the others.
Old May 9, 2011 | 04:35 PM
NightFlyR's Avatar
NightFlyR
I turn on the torque App first, then I turn on my Bluetooth for the phone, I have had zero problems using both
Old May 13, 2011 | 01:14 PM
investigator's Avatar
investigator
Prosport Gauges
Thanks much!
I've got a Prosport coolant temp gauge and boost gauge on my Mini. Install and price of the gauges came to less than $500.00. They look good and I've had no trouble with them.
Old May 13, 2011 | 07:37 PM
Maugre's Avatar
Maugre
I'm kind of fussy. I know these bluetooth, USB, hookups work, and are realtime indicators, but for me , nothing beats a realtime analog guage.
Just me.
Old May 14, 2011 | 06:24 AM
NightFlyR's Avatar
NightFlyR
Just me.
Even tho I have the bluetooth setup and had the Scanguage prior, I would have to agree with you, nothing beats a true Analog guage. But when you still want the information and are not all worried about how it looks, the Scanguage, Torque and Iphone app are a good second choice IMO
Old May 16, 2011 | 08:03 AM
SMOG's Avatar
SMOG
Alliance Member
2011mcs gauges
I put a PLX WiFi OBD2 sending unit in and use an i-Phone 4 for the gauges in my 2011mcs. Battery time in the phone is limited so it needs to be plugged into the aux power. It still does NOT have an oil pressure gauge!!!!
Putting in an engine coolant temp gauge is easy with a manual transmission and is still possible with an automatic transmission. Check out my link for my 2009mc.
http://www.mini4fun.info/09_MCa_Gaug...6_Photos..html
On the 2011 MCS engines the oil sending units are located in a different place and not sure how the Cravenspeed Tapless Adapters will work.
S.
Old May 30, 2011 | 10:22 AM
cgaubuchon's Avatar
cgaubuchon
S.
Can you download LogWorks for the iPhone and see if it works with you Kiwi? Its a free app and might only work with their wifi device but am curious as I can get the Kiwi from a friend if it works.
