Interior/Exterior Exhaust Tips
Old Jun 3, 2012 | 01:52 PM
  #101
joshknot's Avatar
joshknot
I wound up going with 3.5" rolled double-wall slanted tips on mine to give it that OEM+ look. Inspired by some other posters on hear, the tips are rotated a bit to follow the curve of the bumper cutout. I'm really pleased with the results- looks far better than stock and doesn't scream "I've modded my exhaust!"
Old Sep 4, 2012 | 12:41 PM
  #102
ayk07's Avatar
ayk07
Originally Posted by minijoopers
Just went to local muffler shop.
While i was there, i took resonator&2nd cat out also.
Love the sound!
does that throw codes up?
Old Oct 20, 2012 | 11:40 AM
  #103
Rudeman422's Avatar
Rudeman422
Has anyone who has changed the exhaust tips had the TPM ( tire pressure monitoring ) system malfunction after it was done? My TPM system stopped working and the dealer tried to say it was caused by welding the exhaust tips on. I completely removed the exhaust system to weld the tips on, so I said it wasn't possible that I did anything, but I'd like to know if anyone else has had this issue. They've had my car for 4 days now and still haven't figured out what the issue is, but they said if they have to call Mini for a Field Service Engineer, they will probably come out and look at it and say it's from the exhaust modification and say that it shouldn't be covered under warranty. I only had it for a week before this happened!
Last edited by Rudeman422; Oct 20, 2012 at 11:41 AM. Reason: Changed wording of first sentence
Old Oct 20, 2012 | 11:48 AM
  #104
Mojito's Avatar
Mojito
Find a new dealer lol
That's terrible. What's next, swapping rims will cause oil leaks?
Old Oct 20, 2012 | 11:54 AM
  #105
Theta's Avatar
Theta
Seriously, that's as bad as my dealer...
What a load of crap. They're lying to you, plain and simple. Typical.
It gives the good dealers out there a very bad name.
Old Oct 20, 2012 | 01:22 PM
  #106
ayk07's Avatar
ayk07
have you checked your tires? i had a screw in my tire on my old honda and it was showing TPM, sometimes it would disappear and come back on but after removing the screw it stopped.
Old Oct 20, 2012 | 03:40 PM
  #107
Rudeman422's Avatar
Rudeman422
The next closest dealer to me is 250 miles away. I'm kind of stuck. I checked all of the tires, they are good. The system keeps trying to reset itself and then says there is a malfunction and says to contact the nearest Mini service center. The dealer has already replaced the antenna for the system, and all of the sensors in the wheels. They still can't get it to reset.
Old Oct 20, 2012 | 07:09 PM
  #108
1bigpea's Avatar
1bigpea
There's no way that adding tips to your exhaust had anything to do with your TPM failures. The dealer is making excuses because the warranty work is costing them $$$. Bunch of crap, pull the BS card on them if they try to blame that again.
Old Oct 20, 2012 | 08:26 PM
  #109
GeoffreyM's Avatar
GeoffreyM
I'd love to hear what their explanation is on how the two are related.
Old Oct 20, 2012 | 08:28 PM
  #110
Theta's Avatar
Theta
Make sure you let them know that you understand two very important words:
"Magnuson" and "Moss"
That should stop this BS dead in its tracks.
Old Oct 21, 2012 | 12:46 AM
  #111
Rudeman422's Avatar
Rudeman422
Thanks for the info, I'll be sure to mention that if they try to hassle me about it anymore.
Old Jan 11, 2013 | 01:58 PM
  #112
lph2's Avatar
lph2
Digging up an old thread...but thanks for the info!!!
This was an easy mod. The shop didn't have any generic tips,
so I ordered Vibrant 4" #1207 tips from Summit Racing. 20 mins in and out!
Old Jan 12, 2013 | 03:03 PM
  #113
lph2's Avatar
lph2
Also, earlier in the thread, there was some discussion about whether the larger tips made the exhaust louder.
I made a before and after vid.
I think in Sport mode, it amplifies the "pops and gurgles" just a little bit.
Old Jan 12, 2013 | 05:17 PM
  #114
ke3ee's Avatar
ke3ee
how to you connect the vibrant tip's? clamps or welded?
Old Jan 12, 2013 | 05:46 PM
  #115
Mical's Avatar
Mical
If the dealer (who I'm very familiar with) had checked, on driver side rear corner is TPMS antenna which when you had exhaust down, it didn't get reconnected. Easily done - found out when helping a bud adding rear JCW spoiler to his Countryman. PM me & I'll get you copy of install directions. Btw I did the JCW tips.
Attached Thumbnails Exhaust Tips-2012-09-21-12.06.16.jpg   Exhaust Tips-2012-10-23-13.52.04.jpg
Old Jan 12, 2013 | 07:02 PM
  #116
pidge1114's Avatar
pidge1114
I actually had this question in another thread.
The JCW rear kit instructions call for bumper removal, and then cutting plastic and rerouting the TPMS antenna. However i would like to use other tips instead of the JCW ones that come with the kit.
If I just get the old tips cut off on the car while still attached and get new ones welded on, am I to assume there should be no danger to this antenna, nor any reason to relocate it for the rear aero kit?
Old Jan 12, 2013 | 07:27 PM
  #117
Mical's Avatar
Mical
There should be no issues w/TPMS if you go that route.
Old Jan 12, 2013 | 09:47 PM
  #118
lph2's Avatar
lph2
They where welded on.
Old Jan 12, 2013 | 11:35 PM
  #119
bmwr606's Avatar
bmwr606
no problems with TPMS when i replaced my exhaust with a downpipe back milltek system ... it was bolt on, no welding
i have adjusted the exhasts to be even since this photo was taken, the system "moved around" quite a bit during the first couple hundred miles and needed to be retightened several timer, but has been stable since then
scott
Old Feb 11, 2013 | 10:28 AM
  #120
ayk07's Avatar
ayk07
added dimisa 4inch tips and love it. i think i notice the pop more.
Old Apr 21, 2013 | 08:00 AM
  #121
Pete1burn's Avatar
Pete1burn
I emailed DiMisa and they said the 3.5" would work, but they can't tell if the 4" will.
Trying to decide between the two based on the pics here. Thanks for all the pics!
Old Apr 21, 2013 | 08:29 AM
  #122
ayk07's Avatar
ayk07
4" works just as well, i have it. I think it looks more filled out compared to 3.5. cant go wrong with either of them though when you look at the stock set up.
Old Apr 21, 2013 | 11:43 AM
  #123
bmwr606's Avatar
bmwr606
here is a photo of my 100mm (3.9") exhaust tips on my milltek exhaust
scott
Old Apr 21, 2013 | 11:56 AM
  #124
Pete1burn's Avatar
Pete1burn
Thanks for the pics. Where is the inlet on that exhaust, and do you have any sound clips?
Old Apr 21, 2013 | 12:18 PM
  #125
bmwr606's Avatar
bmwr606
it is a DP back system, replaces everything from the DP back, has no second cat and no resonator and is 63.5mm (2.5") from the DP all the way back to the 100mm tips
it uses all of the stock mounting points with no modification
i do not have a sound clip but will say the sound is lower in pitch, a little louder than stock at steady speed, quite a bit louder at WOT, but not "ricey" or "get a ticket" loud
NO DRONE at any rpm or throttle setting
no rubbing on the chassis
with the sport button on, the pop/burble is much more pronounced
the power comes on about 1000 rpm lower than with the stock exhaust, i am assuming the turbo is spooling quicker
connection to DP and first mounting point in front of flex joint
here you can just see the flex joint and the next mounting point
left rear mounting point, right is the same
muffler showing the inlet and outlets ... with the tips off you can see thru the muffler
scott
