Interior/Exterior Painted My Rims
Old Sep 8, 2010 | 05:05 PM
SlyCooperR53's Avatar
SlyCooperR53
Painted My Rims
I was going to get a set of Sparco Drift's but i decided to paint my stock ones to see what they would look like. here you go
Old Sep 8, 2010 | 05:18 PM
JC55MINI's Avatar
JC55MINI
Looks great! Works much better with your MINI!
Old Sep 8, 2010 | 05:22 PM
iwashmycar's Avatar
iwashmycar
Looks great, but sweet jesus, are the spring blocks still in there!!???
Old Sep 8, 2010 | 05:26 PM
SlyCooperR53
^^^^ haha no i still had the E Brake on and it moved back a lil when i was removing the wheels
Old Sep 8, 2010 | 05:31 PM
iwashmycar's Avatar
iwashmycar
ohh i gotcha... mine does the same lol
is that plastidip? looks similar to mine, just better lol
Old Sep 8, 2010 | 05:33 PM
ACallahan's Avatar
ACallahan
Looks like you must have hit Rimpainter.com, I spent 50.00 bucks on paint and did the same thing they look sweet.
Old Sep 8, 2010 | 05:35 PM
SlyCooperR53
neither of those, haha its rustoleum wheel paint and clear coat, sanded them with 310 grit and went to town.
Old Sep 8, 2010 | 05:37 PM
iwashmycar's Avatar
iwashmycar
well props to you! very well done
didnt know they made wheel paint... good to know
Old Sep 8, 2010 | 06:23 PM
SlyCooperR53
they sell it at your local auto parts store. ill let you know how it holds up in a few months.
Old Sep 25, 2010 | 12:24 PM
clumanjenn's Avatar
clumanjenn
clear coating
Hey, related to this post I've been re-working some R90's. The barrel part of the wheel was clear coated, and I stripped that and repainted.
I put a primer down and then black, then clear coat. The first coat of clear went on beautifully. I looked sooooo smooooth and shiny.
Being the perfectionist I am I wanted two coats of clear for max protection. I did not sand between the clear coats, as it doesn't really say on the type of paint I got to sand, it just says to wait 24 hours before applying a second coat. I let it sit for a day came back to put the second coat on, and now it's textured. Not the smooth glossy finish I had before. It's a little rough and matt looking. Not at all what I wanted. Should I have stopped at one coat and been happy? Or should I have maybe sanded a little between coats?
Old Sep 25, 2010 | 06:02 PM
SlyCooperR53
i put two coats on waiting like an hour between coats and its not rough at all i think its cause you waited to long. thats my guess im not a professional lol
Old Sep 26, 2010 | 05:39 AM
clumanjenn's Avatar
clumanjenn
I've done a little more research and what I've go is Clear Coat Orange Peel. The clear coat gets textured like an orange peel kinda feel. It's fixable by wet sanding and polishing. I'm going to put another layer on before I wet sand, cause my concern is I'll sand through my two thin coats.
How's the Rustoleum paint holding up? I used the same stuff.
Old Sep 26, 2010 | 06:38 AM
ngweibing's Avatar
ngweibing
looks like a great idea
Old Sep 28, 2010 | 08:04 AM
ViperGTS's Avatar
ViperGTS
Just make sure when you wet sand that you use super high grit sandpaper. Anything over 1000 grit should work, the higher the number the better.
And make sure you keep it wet. You might even want to grab a spray bottle to keep it wet between sanding.
It should come out just fine. Then, you can wax it just like your car and it should give it a nice polish. Good luck!
Doc Pain
Mar 10, 2021 04:50 AM
luisfv56
Nov 16, 2015 01:55 PM
malibujoey
Nov 9, 2015 08:22 PM
Winston46
Nov 9, 2015 06:18 AM
M7Speed
Oct 1, 2015 07:05 AM
