Interior/Exterior Woodgrain Vinyl Dash
Old Jun 6, 2010 | 01:54 PM
plasticknives's Avatar
plasticknives
I decided to go a different route from the CF vinyl and wrapped my dash in woodgrain instead. I used a 12x48 strip of 3M Di-Noc Marine Teak Woodgrain Vinyl. This was just enough to do all 5 pieces. I also Plastidip'd my downtubes, but I am undecided on how it looks.
What do you all think?
The airbag cover was crooked in this picture, but I peeled it back up and reapplied it straight.
Old Jun 6, 2010 | 02:01 PM
SteveB625's Avatar
SteveB625
I think it looks neat!
Old Jun 6, 2010 | 03:56 PM
thulchatt's Avatar
thulchatt
Not my taste but a very nice job.
Old Jun 6, 2010 | 04:19 PM
soccerbummer1104's Avatar
soccerbummer1104
i hope you put some extra adhesive in the airvent region.. or super glue (what i did) first good summer heat and it all starts to try and shrink back. and it WILL pull the paint off the dash pieces. so you really need to strip your dash of the painted coating before doing any vinyl wrapping of it... i learned the hard way. next time ill be doing either solver or white cf vinyl :P
Old Jun 6, 2010 | 04:28 PM
Agarwaen's Avatar
Agarwaen
Soccer, If you do do white CF, make sure and post it. I've been looking at it myself.
Plastic, It might not be my cup of tea, but it looks great.
Old Jun 6, 2010 | 05:00 PM
jirsty's Avatar
jirsty
Classy!
Old Jun 6, 2010 | 05:21 PM
plasticknives
I actually wrapped the vinyl around it and have a good inch adhering to the back rather than cutting at the edge, so hopefully that will hold it.
Old Jun 6, 2010 | 05:41 PM
soccerbummer1104
oh good sir.. so did I.. so did I.... it didnt come unwrapped, thats not the problem. it started off with just my driver side air vent doing this, but by mid-may both were doing it, so i ended up taking off the dash and getting to the areas that were coming up, putting a dab of super glue there, mushed it around to even it out, opened it up to let the chemical reaction start then sealed it (wear gloves if you do do this eventually.. i didn't and had super glue fingers for like a week...) wow ADHD kicked in sorry... anyways what happened to me is the vinly tried to go back to its orriginal shape, and since the air vent hole has differing depths to it im sure you had to do what i did and the vinly is not evenly stretched down the hole, btu rather stretched so you could get it through, then cut in several places and pulled over the back. well on mine the vinyl peeled the paint off on the walls of the vent hold and while remaining attached to the backside of the dash created air pockets so instead of the hole begin a O at the opening and an O halfway through and then an O at the back it went to begin an O front , D middle O back. (imagine it in your head... i know its a crude explanation, but its the first thing that came to me as how to describe it..)
Old Jun 6, 2010 | 06:18 PM
DooBahDoo's Avatar
DooBahDoo
Very neat job. Ya done good!
Old Jun 6, 2010 | 09:20 PM
xnotfunkylex's Avatar
xnotfunkylex
That looks sweet.
Old Jun 1, 2015 | 08:46 AM
jchmini's Avatar
jchmini
Fantastic Work
This looks amazing, you did a very nice job! I have fumbled around with covering the panels in leather, vinyl, and subsequently went back to just spray painting them.
I have read a lot about Di-Noc and I think it's the perfect solution for my R52..I will be trying this!
Any tips for working around the circular air vents, those seem to give me the most trouble?
Love the wood look, but not worth the $350 for OEM replacement panels.
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
