Interior/Exterior easy weight removal
Old May 27, 2010 | 04:12 PM
R53's Avatar
R53
easy weight removal
what things are easily removable and easy to replace again to make the mini lighter?
Old May 27, 2010 | 04:18 PM
inimini2007's Avatar
inimini2007
Take out the Rear Seat Driver.
Old May 27, 2010 | 04:25 PM
ALTA_Jarid's Avatar
ALTA_Jarid
pop out the back seat bottom, unbolt the rear seat upper, tool kit, floor mats, and thats about it thats easy.
Old May 27, 2010 | 05:30 PM
Cavalier Cooper's Avatar
Cavalier Cooper
Start jogging
Take the rear carpet out too. But what are you doing, drag racing?
Old May 27, 2010 | 05:44 PM
Eric_Rowland's Avatar
Eric_Rowland
If you have an MCS, don't bother removing the spare tire...
Old May 27, 2010 | 09:56 PM
Agarwaen's Avatar
Agarwaen
You could replace your Lead-acid battery with a Lithium-Ion battery from a Porsche. The only thing they say they have a problem with is cold, but a MCS battery is in the cabin.
Stock wheels are the easiest and most dramatic way to lose weight. If you have something like R90s, you will lose about 10lbs per wheel if you pick up some of these http://www.tirerack.com/wheels/Wheel...All&sort=Brand
That's 40 unsprung pounds lost from barely any work.
Old May 28, 2010 | 04:55 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Check out this old thread from 2005:
https://www.northamericanmotoring.co...this-baby.html
My 05 MCS weighs 2500lbs (+-20) but it's noisy with so little left on the interior. Biggest weight saving came from racing seats as the stock seats weigh a lot. Once you put in racing buckets you can lose the rear seats as no-one has access to the rear anyway. lol
Old May 31, 2010 | 10:52 AM
chris.j.lamb's Avatar
chris.j.lamb
1 ball exhaust, no passengers, nearly empty petrol tank, empty washer bottles, no rear seats,
Old May 31, 2010 | 10:56 AM
xkot's Avatar
xkot
Ride a bike, diet or hire a lightweight driver.
Old May 31, 2010 | 11:13 AM
inimini2007
1. Lighter Rims...dropping down to the 15" or 16" and Non-Runflats.
2. Do a rear seat delete.
Old May 31, 2010 | 11:18 AM
inimini2007
Like someone said...a One-Ball Mod will take 20 lbs off.
You can take 40 lbs off total by changing your wheel/tire combo to a lighter set.
Old May 31, 2010 | 11:22 AM
xkot's Avatar
xkot
For every pound of unsprung weight that you lose, the car reacts 10 pounds lighter. 1/10 ratio. In real life terms. Reducing unsprung weight minimizes the load placed on controlling the motion of the wheels and tires. This means that suspension springs and shock absorbers will have a greater reserve capacity to control body motion -- just as they were intended to! The result is better handling.
Just copied that from another fourm.
Old Jun 2, 2010 | 05:13 PM
freeskier's Avatar
freeskier
i switched to super light keosi wheels and a sparco evo racing seat and i could feel the differance. rear seat is another good place, and a smaller batt
Old Jul 15, 2010 | 10:51 PM
dannyhavok's Avatar
dannyhavok
Is there a how-to anywhere for removing the rear seats? Or will it be pretty straightforward once I get in there? I don't plan on carrying anyone around back there anyway, might as well lose a few pounds!
Old Jul 15, 2010 | 11:47 PM
DjR53's Avatar
DjR53
http://www.mini2.com/forum/faq.php?f...aq_faq_removal
Motown
Apr 20, 2018 09:31 AM
eatsleepautox
Oct 30, 2015 06:46 AM
greekzilla
Aug 23, 2015 03:44 PM
kpl
Aug 11, 2015 04:52 AM
