Interior/Exterior Plasti dip FTW
Old Mar 18, 2010 | 12:10 PM
minirooferS's Avatar
minirooferS
Plasti dip FTW
Got myself a can of plasti dip spray an decided to black out my car with my friend. Here's some pics of the progress and final results.
Here I masked off the edge of the stripes to get rid of the white edging from the factory stripes. I never liked the white outline. I also masked off my headlights. (We did a much better job than it looks with the headlights, the pic was taken before we were done masking it.) Unfortunately when I was peeling the tape around the stripes the plasti dip came off with it, and when it didnt it was rippled on the edges. So I just decided to leave the white on.
then I decided to paint the chrome around the grille.
here's the final results... It looks sooo much more agressive. I love how the grille is black on the outside and green on the inside.
I also plasti dipped my gas gap, Hood scoop, spray painted the S side grille in black, and plasti dipped my rear mini logo, but left the circle unpainted.
I still got more to come.
-chrome lining around the body of the car below the windows
-exhaust tips
-strip right above the rear license plate holder
-Cooper S badge
-door handles (maybe)
oh and I also lowered the front licence plate bracket one notch so it doesn't cover the bottom half of the grille. I definitely recommend that to anyone. It gives it a cleaner look.
Old Mar 18, 2010 | 01:21 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
You definitely have some ca-ho-nez to be spraying your car with only portions being masked...
How was the over spray with that product?
It looks like it turned out quite well!
Old Mar 18, 2010 | 01:27 PM
BlimeyCabrio's Avatar
BlimeyCabrio
It's plasti-dip... overspray wipes right off.
Old Mar 18, 2010 | 01:51 PM
minirooferS
Yup no worries with overspray. I actually didn't get any overspray except for my rear badge which I wiped off. it sprays out very clean.
Old Mar 19, 2010 | 10:31 AM
jirsty's Avatar
jirsty
+1 "Plasti dip FTW!"
Old Mar 19, 2010 | 10:46 AM
MINIchaser's Avatar
MINIchaser
wow! I would be so nervous doing it that way...my worry would be with the quality of the tape you used to mask stuff off. I just had a horrible experience taping off my living room walls to paint the ceiling....we used very high quality painters tape and when were were finished we pulled it off and it took off tons of paint from the wall almost everywhere where there was painters tape.
So anyway...how'd the tape work on your car? Any sticky parts left on, or damage ...?
But it does look very good, and that seems to be an swesome alternative to taking everything off and dipping them separately...
Old Mar 19, 2010 | 02:59 PM
minirooferS
TBH it did peel off with the tape when I did the stripes, and there are a few hidden areas on the grille where there's tiny pieces of tape left. I'm sure I can get them out but I'm a little afraid it will peel with the plasti dip.
It really isn't perfect at all if you get up real close. But considering I can just peel it all off as if I never dis anything, I don't really care. As long as there's no damage.
Old Mar 19, 2010 | 03:07 PM
MINIchaser's Avatar
MINIchaser
yea that's true. that's definitely a good way to go! thanks for the info
Old Mar 19, 2010 | 05:08 PM
minirooferS
yea man go for it. you can always just peel it off.
Old Mar 19, 2010 | 05:31 PM
Myke@RPI's Avatar
Myke@RPI
+1 on the plastidip club... plastidipped gas cap and still good after 2 years!
Old Mar 19, 2010 | 09:16 PM
JohnnyVillan's Avatar
JohnnyVillan
The trick to peeling the tape off is to trim the plastidip with an xacto first so the tape doesn't take any of the plastidip with it.
Old Mar 20, 2010 | 09:06 AM
minirooferS
We were going to do that, but on the outside ends of the white on the stripes, is the paint. I wasn't going to leave 4 nice straight scratches on my hood.
Old Mar 22, 2010 | 04:25 PM
Act_04's Avatar
Act_04
Looks good!
I would be worried about doing the exhaust tips though. I think you'd be dripping melty plasti-dip all over the highway.
Old Mar 22, 2010 | 04:37 PM
J_'09s's Avatar
J_'09s
Do you r53 guys do the joey mod? Car looks great! Not bad for an afternoon's worth of work.
Old Mar 22, 2010 | 04:38 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
^ for tips it would be better to use high temp engine paint or have them powder coated. PC is not that expensive, and if you have access to a junk oven somewhere or kiln, you can purchase the PC stuff at Harbor Freight and DIY.
The PD will just melt off.
Old Mar 22, 2010 | 05:12 PM
BlimeyCabrio
Black textured powder coat is the way to go on tips. Perfect match for the black trim texture and color.
Old Mar 23, 2010 | 10:42 PM
xnotfunkylex's Avatar
xnotfunkylex
Peel the tape off while it is still wet. That should give you a clean edge and it won't tear when wet.
Old Mar 24, 2010 | 11:17 AM
minirooferS
Originally Posted by Act_04
Looks good!
The tips don't get hot. All I had to do was unscrew them with an Allen key and spray. The coating is staying on after a few days. I also sprayed the strip above the license plate holder.
Xnotfunky: I actually did that with the front mini logo. Next time I buy a new can I'm going to redo the stripes.
Old Mar 30, 2010 | 08:22 AM
adam_randell's Avatar
adam_randell
how dod you get on with the masking tape? im going to be redoing my door handles over the weekend - but last time i did it it was a PIA because the plastidip set on the tape and started peeling as i peeled the tape off....
Old Mar 30, 2010 | 12:11 PM
Act_04's Avatar
Act_04
When you guys have done your door handles, what did you do about the keyhole? Just spray it and assume your keyfob never dies, or mask it?
Old Mar 30, 2010 | 12:13 PM
JohnnyVillan
^^I masked mine
I use my door keyhole to roll up my windows
Old Apr 11, 2010 | 06:18 AM
minirooferS
Re-did the stripes again. This time I peeled the tape off before it was dry so it wouldn't peel.
BEFORE
AFTER
in semi dark lighting like the pic above you can hardly tell there's stripes with the black outline. I love it.
Old Apr 11, 2010 | 02:11 PM
Act_04's Avatar
Act_04
I really like that. I hope it doesn't peel. Let us know if it does after you wash it a couple times.
Old Apr 11, 2010 | 08:30 PM
minirooferS
That pic was taken right after I washed it less than an hour after I did the stripes. No peeling so far atleast.
Old Apr 12, 2010 | 06:48 AM
AggieMini11's Avatar
AggieMini11
OOO. Love the all black stripes. Good choice. I PD'ed my grill slats on my R50. Nice BRG!
