So..something I missed when I built my MCS was the white turn signals. Does anyone know if there is a way to swap out the orange lens with a clear one, without changing the entire headlight assembly?
The orange turn signal lens in the headlights can be popped out and replaced with clear ones. The only issue might be finding the clear ones. Some just replace the bulb with one that lights up orange and leave the lens out.
looks good oxybluecoop..i am a bit confused though..you dont you still have to take them apart in order to get the orange lens out..?
No you just need to remove the light(four 10mm bolts)open the access panel on the back and reach a small screwdriver in there to pop off the tabs to the lenses.Give it a shake and they'll fall out.
