Interior/Exterior Custom Hood Scoop
Old Nov 3, 2009 | 08:20 PM
MRE7986's Avatar
MRE7986
Custom Hood Scoop
g
Old Nov 3, 2009 | 08:46 PM
JIMINNI's Avatar
JIMINNI
Not sure what your doing here? Can you pan back so we can see better. If you look at the M7 Ram Air and the Extreme, they do have a larger opening than stock, so not sure what you are talking about. What IC are you using?
Old Nov 4, 2009 | 06:34 AM
TimL's Avatar
TimL
No offense, but it seems a bit mickey-moused to me. (Which is okay if you don't mind the look; it's just not my thing.) Did you basically cut out the bottom edge of the scoop?
+1 on request for pix from other angles so we can have a better look.
Have you checked out DrPhil's article on intakes and diverters? If not, it's worth a look. (I think Voltage has also come out with a larger scoop since that article was written.)
Old Nov 4, 2009 | 09:49 AM
MRE7986's Avatar
MRE7986
g
Old Nov 7, 2009 | 06:14 PM
Malcon's Avatar
Malcon
My m7 scoop is great! I think the cut up scoop looks pretty bad. Are you finished with it?
Old Nov 8, 2009 | 03:04 PM
R53Warrior's Avatar
R53Warrior
This looks like something I would only *think* of doing after a few Four Loko malt liquor drinks...
Old Nov 8, 2009 | 03:35 PM
bahawton's Avatar
bahawton
FYI- I wouldn't buy the M7 scoop again...
The fiberglass had so much trapped air in it that it kept bubbling under the paint when the body shop put it in the oven to dray. It took 3 attempts to get it looking good, then a couple months later part of the paint on the back flaked off for the same reason : (
Old Nov 8, 2009 | 04:14 PM
cartar452's Avatar
cartar452
wow
Old Nov 9, 2009 | 03:42 AM
jerjer's Avatar
jerjer
^ wow +1
it's kinda like cutting up body panels to save weight~
Old Nov 9, 2009 | 07:13 AM
Mike S's Avatar
Mike S
Why would you willingly butcher your own car
I think you had a dud. I have had mine for over 2 years and I have never experienced any problem like that.
Old Nov 10, 2009 | 04:27 PM
MRE7986's Avatar
MRE7986
fg
Old Nov 18, 2009 | 07:57 AM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I'm sorry, I don't get it. My scoop has an opening 4x that of a stock scoop. And there's no air leak. I'd imagine this mod creates significant leakage problems. It's not just about a large opening, it's about air flow, and getting lots of air through the IC.
That just looks like butchery to me.
Old Nov 18, 2009 | 08:00 AM
Bigshot's Avatar
Bigshot
Old Nov 20, 2009 | 01:12 PM
JS's Avatar
JS
Sorry to hear of your experience. Did you contact M7 and ask to have a replacement scoop sent. If you have not, I would ask them to replace it, as you should not have accept poor quality workmanship.
Old Nov 20, 2009 | 06:50 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Looks like he's running the Alta version of the DFIC...the instructions tell you to cut the scoop like that.
Old Nov 20, 2009 | 06:54 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by MRE7986
g
g
fg
What's with the g and fg posts?
Old Nov 23, 2009 | 07:24 AM
Bigshot's Avatar
Bigshot
Looks like he deleted his posts. Probably didn't like the comments.....
Old Nov 23, 2009 | 10:06 AM
MRE7986's Avatar
MRE7986
For everyones information I didn't make this post for something everyone should do, I did it to see if anyone new of any good hood scoops that involved removing that hood brace which blocks the intercooler. But everyone took it the wrong way. I needed to cut mine to fit that alta intercooler and just knoching it made it look worst. I plan on making one and was looking for ideas not to have comments about how terrible it looks. FO
Old Nov 23, 2009 | 11:07 AM
JS's Avatar
JS
If you want a hood scoop that has a larger opening I may be able to help help you out. This is a scoop I made and ran on my car, with a DFIC IC, until I made a second large mouth scoop I run now. It is about 2+ times larger then a stock scoop. I didn't cut the brace but I did bend it down enough to clear the added depth of the scoops floor.
PM me for more info.
Joel
JSart
PS: photos are from my gallery;
Boverphoto
Jul 3, 2017 10:56 AM
YO MUDA
Oct 5, 2015 04:14 PM
Sep 3, 2015 01:45 PM
MiniSMan
Sep 1, 2015 06:49 PM
