Interior/Exterior Beltline Blackout -- OUT MOTORING
Old Sep 21, 2009 | 01:34 PM
schreiber117's Avatar
schreiber117
Just applied the kit, and wanted to give it a big thumbs up . I'll take some pictures later.
The amount supplied would do the car and then half again, which was nice since the first panel I did (drivers door) I messed up, so I had plenty to redo it. Just takes patience.
Clean the chrome surface, apply the blackout tape, trim the edges, remove gloss layer.
My one hint, which after reading so many people's experience, they claim the Bonnet section is the hardest. I have an 02, and the bonnet section on mine is actually two pieces, split in the center. I found it easiest to simply do it as just that, two pieces. I'll try to show in picts later.
again, two for OUTMOTORING's blackout beltline kit
Old Sep 21, 2009 | 01:44 PM
ngweibing's Avatar
ngweibing
let us see yr work..
Old Sep 21, 2009 | 01:52 PM
schreiber117
I know, I know, Im at work though. let me go downstairs and snap a quick crappy one for now...
Old Sep 21, 2009 | 02:06 PM
schreiber117
some crappy iphone shots...
lastly, the bonnet section:
Old Sep 21, 2009 | 02:40 PM
Act_04's Avatar
Act_04
+1 for the OUTMOTORING kit!
I blacked out my red MCS (which may have been nearly identical to yours in the beginning) and had no trouble.
As long as you go slow, overlap when you get to an edge, then cut with an x-acto blade it is very simple. My MCS also has the split on the bonnet section. I feel like cutting the tape to do this part would help for those of you with later models.
Good post schreiber, and the car looks good. Keep it up.
Old Sep 21, 2009 | 02:45 PM
schreiber117
Thanks act 04
I just looked through your gallery, where'd you get the splitter, I like it.
which wheels are you currently rockin? your gallery shows a lot.
Old Sep 21, 2009 | 03:03 PM
Act_04's Avatar
Act_04
This link tells the tale of the homemade splitter:
https://www.northamericanmotoring.com/forums/interior-exterior/174519-new-front-lip-spoiler-splitter-and-hid-fogs.html
The wheels are:
17x7.5 Elbrus I04 BDC ICE (passenger)
17x7 O.Z. Racing Superturismo GT Bright Silver (driver)
Cruisin' on the passenger's side and racin' on the driver's side.
That post is here:
https://www.northamericanmotoring.com/forums/interior-exterior/172293-my-red-s-just-got-new-wheels.html
Old Sep 21, 2009 | 03:17 PM
ron-s mini's Avatar
ron-s mini
Nice Job!
Old Sep 21, 2009 | 05:56 PM
MrCooperS's Avatar
MrCooperS
Moderator
Awesome job!
For future references, you can go to homedepot and buy heavy duty black vinyl tape from 3M. It's rated for below 30s and it's for outdoor use. It's a big wide and you can do about 5 cars with one roll for $5. Cheaper to replace. The stuff outmotoring sells is too brittle and cracks.
Old Dec 1, 2009 | 09:23 AM
NeilHernandez's Avatar
NeilHernandez
Schrieber, did you have to remove the chrome trim from the car or did you do it in place? i'm waiting for my kit to arrive from Outmotoring! Great job btw.
Old Dec 1, 2009 | 09:59 AM
jckonrad's Avatar
jckonrad
Looks great! I think I might do this as my chrome is starting to chip.
Old Dec 1, 2009 | 11:48 AM
d.p's Avatar
d.p
You can do it in place, don't have to remove it. Also I would recommend getting Vinyl over outmotoring's kit. Which is basically electrical tape.
Old Dec 2, 2009 | 08:58 PM
schreiber117
sorry I didnt get back to you sooner. No removal needed. I just cleaned the surface with a cloth, and applied the kit... easy as pie.
Old Dec 3, 2009 | 07:11 PM
jirsty's Avatar
jirsty
I hope they last well.. anyone had one for a longer time? I will order mine soon too =]
Old Dec 4, 2009 | 11:48 PM
rjtrout2000's Avatar
rjtrout2000
so would electrical tape be easier than the outmotoring kit? Reason being I want to do this so I can match up my freshly painted balck s-lites a bit better to my car. What do you guys think? electrical tape ftw!?
Old Dec 6, 2009 | 03:25 PM
schreiber117
rjtrout2000, The real difference is in the finish. The outmotoring is a flat black, electric tape has a shine.
Old Dec 6, 2009 | 05:26 PM
Fatherdeth's Avatar
Fatherdeth
Nice job!!!! Reminds me that after 4 years, I need to go on ahead and redo mine.
Old Jan 19, 2011 | 08:45 PM
dez's Avatar
dez
any pointers for removing the film? I had a hard time removing it and actually damaged some sections attempting to remove it.
more on order for repair...
Old Jan 20, 2011 | 04:31 AM
yetti96's Avatar
yetti96
I left about 1.5" excess on each section and put my knife tip into the excess about 1/4" from the end. I pulled the blade through the material sideways (perpendicular as you would to actually cutting) and the tearing motion is what separated the two at the very tip and I was able to then pull it apart.
Old Jan 20, 2011 | 10:27 AM
schreiber117
Honestly, not sure, as I sold the car with the kit installed. If it's giving you trouble, you can warm it up with a hair dryer, carefully though, as not to heat it too much.
I have to imagine, it peels off fairly easily.
IQRaceworks
53
Jun 28, 2024 07:29 AM
NYMADMINI
Dec 14, 2016 02:33 PM
Sep 29, 2015 12:11 PM
Emnotek
Sep 29, 2015 07:37 AM
