Interior/Exterior Genuine Italian leather shift boots - custom made for your MINI!
Old 08-19-2009, 05:41 AM
RedlineGoods.com's Avatar
RedlineGoods.com
RedlineGoods.com is offline
Hello everyone,
We, RedlineGoods.com, are no stranger to the automotive industry. We have been providing our customers (now over 12 000) with QUALITY GENUINE ITALIAN LEATHER SHIFT BOOTS for 5+ years now. If you take pride in your ride - you will want to read this.
Has your shift boot seen better days?
Have you purchased a short shifter kit and the stock boot doesn't look good anymore or even hinders shifter travel?
Do you simply want to upgrade your stock vinyl pieces to finer leather?
Are you looking for the finishing touch to your custom interior?
Regardless of the reasons, RedlineGoods has a solution for you.
Starting with fine, buttery soft Italian leather, we will hand-craft new boots for your vehicle. The boots are made specifically for your model, so they fit your ride perfectly without any modification - unlike generic boots sold by others. See for yourself:
RedlineGoods has nothing to do with mass production. We're all about YOUR needs and YOUR car, which means a vast array of customization options.
These range from available materials (leather, carbon-fiber, faux-alcantara, perforated leater), through many color options (30+ colors of material and threads) to various finishing types (quadruple thread, two-tone, stripes and piping) - and we're open to even more custom arrangements. You can find our complete color chart by clicking here: http://www.redlinegoods.com/clrchart.shtm.
You can also order a re-sized shift boot for your short shifter or custom transmission setup, get the boot with the mounting bracket (where available) and order extra padding for your armrest cover. Or if you need a small design modification, for example in order to get your aftermarket shift **** to sit flush against your shift boot - we're the ones you should send an email to!
Our products are hand made to your order, shipped from Europe and arrive at your doorstep within two weeks from placing an order.
Our products have been discussed on many automotive forums and we frequently receive great customer comments. Just run a search on RedlineGoods on this forum to find out more about us, our products and our customer feedback.
Since, as the proverb goes, a picture is worth a 1000 words, here are some of them for your enjoyment. Click the link above them to go directly to our page dedicated to YOUR CAR, where you can easily order them with PayPal or your credit card!
MINI 07+ (AUTO) both boots & door armrests ---> $159.00
MINI 07+ (AUTO) both boots ---> $69.00
MINI 07+ (AUTO) both boots & center armrest ---> $109.00
MINI 07+ (AUTO) both boots & door+center armrests ---> $189.00
MINI 07+ (AUTO) shift boot ONLY ---> $49.00
MINI 07+ 4-panel shift boot ONLY ---> $59.00
MINI 07+ both boots ---> $69.00
MINI 07+ both boots & center armrest ---> $109.00
MINI 07+ both boots & door armrests ---> $159.00
MINI 07+ both boots & door+center armrests ---> $189.00
MINI 07+ both boots w/4-panel shifter ---> $79.00
MINI 07+ both boots w/4-panel shifter & door armrests ---> $169.00
MINI 07+ both boots w/4-panel shifter & center armrest ---> $119.00
MINI 07+ both boots w/4-panel shifter & door+center armrests ---> $199.00
MINI 07+ center armrest ONLY ---> $69.00
MINI 07+ door & center armrests ---> $139.00
MINI 07+ door armrests ONLY ---> $109.00
MINI 07+ ebrake boot ONLY ---> $49.00
MINI 07+ shift boot ONLY ---> $49.00
One of the first questions is always about the available colors. I hope this pictures explains it perfectly well!
Please remember that if you cannot decide without seeing the colors in person you can ORDER SAMPLES from us. For a mere $10 you'll get ALL the samples (a small swatch of each color) and, more importantly, if you actually order a product going by those, you'll get $5 of that reimbursed to you.
Find below some photos of our STRIPED BOOTS. These can be ordered for any car and unless you specify otherwise, the stripes will be put wherever there are stitches on your stock boot, ie. a stripe is inserted between two adjacent panels, which are also re-sized to make sure the overall dimension is correct!
Stripes can be combined with stitching which can be CONTRASTING (these two are black perforated leather with light gray stripes and contrasting thread):
Same as above but solid, not perforated, black:
Thread can be also MATCHING so it won't be visible
Thread can be color-matched to the stripes or to the main panels' leather color. Here color matched to stripes, obviously
Or it can be a completely different color than either the main panels OR the stripes - below is black leather with white stripes and red thread:
PIPING is a cool, sporty and elegant way to finish off your shift boots. Piping can be done for any car, and it replaces the threads with a special, well, pipe made by wrapping a thin plastic tube with leather. It looks amazing:
When ordering please make sure to select the primary color as the first leather color and the color of the piping as the secondary leather color.
Another special finishing we offer is QUADRUPLE THREAD. The idea is simple - there are four rows of thread instead of two, and you can choose both the color of the two inside threads, as well as the color of the outside threads. They can all be the same color, but they don't have to - which gives a vast array of visual effects:
Here's the new 10% discount code you may find useful: A63P5HM6U51 - Valid through July 17th!
Have a great weekend,
Maciek
Old 08-19-2009, 05:45 AM
RedlineGoods.com
Hi everyone,
we've added a new item to our 07+ MINI lineup: the door pull covers! Retail at $59 for the pair, available as part of our product combos. Please don't hesitate to check them out at:
http://www.redlinegoods.com/MINI07doorarm.shtm
Here are the pictures!
Take care
Maciek
Old 08-20-2009, 10:45 AM
Sparks's Avatar
Sparks
Sparks is offline
Just ordered a set of the door pulls yesterday. How do they attach? Velcro on the back?
Old 08-20-2009, 12:16 PM
ron-s mini's Avatar
ron-s mini
ron-s mini is offline
Got the door arm rest - door pulls - center arm rest - shift boot - e brake -- They really punch the interior out!!
Old 08-20-2009, 01:30 PM
RedlineGoods.com
That's exactly right.
Maciek
Old 08-20-2009, 03:36 PM
Porthos's Avatar
Porthos
Porthos is offline
I have had experience with Redline with my old car. Good products just a super PITA to install.
Old 08-21-2009, 12:01 AM
RedlineGoods.com
Yeah but, I hope, that wasn't the fault of our products but of the design of the car (more specifically, the way the shift boots are mounted in it)?
Maciek
Old 08-21-2009, 10:17 AM
Porthos's Avatar
Porthos
Porthos is offline
Nah it was the shift boot that took no time at all it was the center console cover. It didn't want to stretch at all so I think I ended up putting it on a little crooked. Also the ebrake boot did go on very easily either. But like I said these products are really nice products and the customization makes it that much better so you can indivualize your car. I might buy from you guys again but I need to see more Minis with redline products before I get them again.
Old 08-21-2009, 12:05 PM
Sparks's Avatar
Sparks
Sparks is offline
I have everything Redline puts out for the Mini, the only problem I had was Mini's fault. Be careful when pulling apart the shifter base. The little tabs are fragile.
Redline's items went on with out a problem at all!! Perfect fit and finish.
Old 08-21-2009, 12:16 PM
not-so-rednwhitecooper
not-so-rednwhitecooper is offline
Redline boots are top notch. Just ordered my second set.
Old 09-04-2009, 01:45 PM
RedlineGoods.com
Hi,
Most of you already know (I hope), but perhaps it would make sense to remind it... As you can see below, we are THE SOURCE of customized solutions as far as shift boots and other interior accessories go.
Below: a Mustang GT 05+ with a Hurst short shifter with a specially modified boot (so that the polished Hurst shifter remains visible - the stock boot ends right under the shift ****) and custom, 3-colored stitching.
Here's a 10% discount code you may find useful: 63I7CIS23I6 - Valid through September 12th!
Maciek
Old 09-18-2009, 07:42 AM
RedlineGoods.com
Hi,
more red stripes!
Here's a 10% discount code you may find useful: 6E372GQS7E5 - Valid through September 25th!
Maciek
Old 09-19-2009, 02:38 AM
brightwhite's Avatar
brightwhite
brightwhite is offline
i had a set of these on my Mazda3 and they were fantastic! will be ordering some for my Mini soon.
Old 09-27-2009, 01:50 AM
RedlineGoods.com
Hi,
still hot, straight off our inbox folder. Black perforated leather with TAN PIPING in a B5 Passat:
Today's10% discount code: 6TBI3JY8012 - Valid through October 2nd!
Take care
Maciek
Old 09-27-2009, 09:16 AM
Robin Casady's Avatar
Robin Casady
Robin Casady is offline
I'm very happy with mine.
Here is a link to a page on how I installed them.
Armrest install.
Old 10-09-2009, 09:04 AM
RedlineGoods.com
Hi,
E46 M3 SMG with our custom M-stitching:
Today's 10% discount code: 6380VFSU4C8 - Valid through Friday, October 16th!
Take care
Maciek
Old 10-23-2009, 10:54 AM
RedlineGoods.com
Hi,
we've enhanced our color chart with PINK THREAD. Here's what it looks like:
Today's 10% discount code: O638W09OLV0 - Valid through Friday, October 30th!
Take care
Maciek
Old 11-06-2009, 02:01 PM
RedlineGoods.com
Hi guys,
LOTS of changes on our website. We've SLASHED OUR PRICES for older (pre-90) cars. We have made the ordering form easier to fill out. We have provided an easy mechanism for finding the pics for your make and model (click the ORDERING link to narrow down by make and then model). We are very excited about those changes and looking forward to whatever comments you may have about them!
We don't show off our Dark Green thread too often. Here it is though:
Today's 10% discount code: 638T8WF3N9A - Valid through Friday, October 30th!
Take care
Maciek
Old 11-20-2009, 08:14 AM
RedlineGoods.com
Hello everyone,
Another example of how important it is to get a shortened shift boot if you're purchasing a short shifter, which is a service RedlineGoods provides at a very modest surcharge.
Here's a sample of the 08+ Impreza STI with the Kartboy short shifter and respectivelly shortened RedlineGoods shift boot in black perforated leather:
Today's 10% discount code: 63P88B81FFN - Valid through Friday, November 27th!
Take care
Maciek
Old 11-27-2009, 08:52 AM
RedlineGoods.com
Hi guys,
here's our Black Friday Discount Code: 6IFO3KW9612 - valid through December 4th!
And two more pictures of stripes. This is our Charcoal leather with medium gray stripes and contrasting thread. Enjoy!
Have a great weekend everyone,
Maciek
Old 12-04-2009, 11:50 AM
RedlineGoods.com
Everyone,
no discount code this time. But we got this:
We have slashed all our prices starting with 20% off each single item, up to 30% on larger purchases!
Enjoy!
Maciek
Old 12-18-2009, 01:42 PM
RedlineGoods.com
Hi guys,
just a reminder, that our CHRISTMAS SALE is in effect through New Year's! If you'd like to give or be given a shift boot, now's the time to get one.
Now, if you're worried your gift might not make it in time for Christmas, I suggest taking a look at our gift cards. Not only can they be pre-viewed before you buy, so you know exactly what to expect, but they are also PRINTABLE IMMEDIATELY, so even right before the Christmas Eve is not too late.
Here's a link to the page where you can customize your gift card and pre-view it: http://www.redlinegoods.com/ordergiftcard.shtm
The recipient will be able to redeem the gift card at their convenience simply by contacting us via email. ALL REDEMPTIONS FOR GIFT CARD PROCESSED DURING THE SALE WILL BE HONORED AT SALE PRICES! - so if you are the recipient, take your time making your pick, you have these prices locked. Forever.
Merry Christmas Everyone!
Maciek
Old 12-18-2009, 06:24 PM
The QZ's Avatar
The QZ
The QZ is offline
Just got my set of boots and covers in the mail yesterday. They look great. I ordered the alcantara material and it looks and feels wonderful. Perfect material for an armrest. I got it with Quad thread with dark green and white stitching.
Armrests are installed, just waiting for a new shifter to do the boots. I'll post pics when I'm done.
Old 12-25-2009, 12:20 PM
RedlineGoods.com
Hi,
a quick update: we have decided to EXTEND THE CHRISTMAS SALE THROUGH NEW YEARS!
And a new pic we've recently received, this is black and silver carbon fiber vinyl two-tone:
Take care
Maciek
Old 01-08-2010, 09:15 AM
RedlineGoods.com
Hello everyone,
new year, new prices, new ideas! First of all, we're dropping the price of individual items by $5, from $49, to $44! And, there's a discount code to top it off!
Carbon-fiber vinyl AND stripes this time. I LOVE black and yellow!
Today's 10% discount code: 70M0Q8XF45R - Valid through Friday, January 15th!
Have a great weekend, guys
Maciek
Quick Reply: Interior/Exterior Genuine Italian leather shift boots - custom made for your MINI!
