Interior/Exterior Hood Underlining?
Old May 25, 2009 | 07:41 PM
miniman101's Avatar
miniman101
Hood Underlining?
I've seen a lot of pictures of people with the lining on the underside of the bonnet taken off. Is there a benefit to doing this? Pros Cons?
Old May 25, 2009 | 10:48 PM
xnotfunkylex's Avatar
xnotfunkylex
Some strut tower braces cause the hood to rise in the back with the lining in. So if you take it out it sits flat again. One con of this is that you lose the lining that is there to help put out small fires under your hood.
Old May 26, 2009 | 05:27 AM
BlimeyCabrio's Avatar
BlimeyCabrio
A few other things the lining does:
a) absorbs noise from the engine bay - so you hear a lot less noise from the timing chain, valves, etc. inside or outside the car.
b) reduces the heat transfer from the engine to the bonnet - possibly impacting things like vinyl bonnet stripes, and certainly impacting how hot your wiper fluid gets in the lines (which can cause the fluid to seep out of the jets and stain the bonnet and stripes).
You can remove material from the back side of the blanket to thin it where it passes over the strut brace and solve the "lifted bonnet" issue - I've done that.
Most folks remove it for cosmetic reasons - Personally I like the look of the bay better with it in place, but diff'rent strokes...
Old May 27, 2009 | 04:15 PM
mscmagno's Avatar
mscmagno
for those who removed it are you guys selling your lining? cuz i need to replace mine, due to some squirelle chewed the lining and i have 2 holes inn it,. and it look ugly and i dont want to removed due i want my car quiet..
or do you know where i can get one to replcae my lining..
Old May 27, 2009 | 09:08 PM
miniman101's Avatar
miniman101
Okay thanks. Just wondering.
Old May 28, 2009 | 04:18 AM
BlimeyCabrio
Dealership or junkyard.
Old May 28, 2009 | 07:27 AM
Bigshot's Avatar
Bigshot
I would guess that most of the pics you have seen showing no bonnet insulation are on the 2nd gen cars as they did not come with the insulation.
Old Jun 8, 2009 | 05:48 PM
revo789's Avatar
revo789
i just took the lining out and i LOVE the sound that it makes now.
the car is not any faster, it just sounds that way.
Old Jun 8, 2009 | 06:51 PM
minimarks's Avatar
minimarks
The lining also helps the life of the paint on the hood too.. 2cents.
Old Aug 19, 2009 | 01:51 AM
corduroy's Avatar
corduroy
NVM
Last edited by corduroy; Aug 19, 2009 at 02:08 AM. Reason: My question was REALLY REALLY dumb :P
Old Aug 22, 2009 | 01:20 PM
JohnnyVillan's Avatar
JohnnyVillan
I dont run the lining and the only real difference I notice is the heat. I have a Carbon Fiber bonnet and you can really smell it once its been running for a bit.
OutMotoring
Mar 3, 2017 06:29 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
M7Speed
Oct 1, 2015 07:05 AM
mini merle
Sep 30, 2015 04:42 PM
drum6g
Sep 29, 2015 01:15 PM
