Interior/Exterior Matching factory gauges
Old Jun 30, 2010 | 09:53 PM
  #676
JIMINNI's Avatar
JIMINNI
Originally Posted by SRTech
Paul at Marshall recommends the Innovate sensors since Marshall makes most of the Innovate gauges. The Marshall AFR gauge needs 0-5 volts.
Steve
Thanks Steve So the one I showed you is the right one?
Old Jul 1, 2010 | 09:00 AM
  #677
SRTech's Avatar
SRTech
You need a controller, also, not just the sensor. The LC-1 is a sensor and controller all in one sealed cable. It's $199 from Innovate.
Steve
Old Jul 1, 2010 | 09:13 AM
  #678
JIMINNI's Avatar
JIMINNI
So then it would be calibrated already?
Old Jul 1, 2010 | 01:52 PM
  #679
SRTech's Avatar
SRTech
From Paul at Marshall Instruments:
"Our wideband A/F uses the same default input range as the Innovate LC-1 controller. If you have the LM-1 you may need to set up the input range according to their instructions. See: http://www.innovatemotorsports.com/s...uge_Manual.pdf for details."
Old Jul 15, 2010 | 04:31 PM
  #680
plasticknives's Avatar
plasticknives
Originally Posted by 36rodder
...First of all I would like to thank "plasticknives" for his inexpensive gauge mount, I built one very similar to his and it works great...
Old Jul 15, 2010 | 06:24 PM
  #681
SMOG's Avatar
SMOG
Alliance Member
Temps on a mountain trip
Originally Posted by AA-MCS
Thanks Soggy, I live in Miami where its hot year round. Mine usually runs around 220 (highway and city, occasionally going to 230) till last Monday.
Thanks,
In Miami I'll bet you don't have mountains where extreme load changes take place. Idling in traffic your temperature drops you might feel the fan(radiator) kick on. Mine vibrates so I know when it is on, plus it is noisy.
When we were climbing 4,000 ft mountain passes and carving the corners the temperature dropped to 185 but coasting back down the other side of The Pass the temp went back up to 218.
It seems to take about 20 minutes of city driving, from a cold start, to get to 218. If I idle for long periods in stop & go traffic the temp climbs to 225 before the fan turns on.
Stephen
Old Jul 20, 2010 | 06:27 AM
  #682
Amygdaloid's Avatar
Amygdaloid
I have a question installing the electric oil pressure gauge. The instructions say to make sure the body of the sender is grounded. How exactly do you do that? The "G" terminal connects to the gauge, and it says not to use the other terminal at all. Is the sender grounded by being threaded into the Tapless connector? Is there some other way to ground the body of the sender unit?
Old Jul 20, 2010 | 07:29 AM
  #683
SMOG's Avatar
SMOG
Alliance Member
Amygdaloid:
Although I took 2 conductors(wires) to the sender location, in case I needed a ground there, I only needed one conductor hooked up to the sender. This is what Paul at Marsall gauges told me to do and it has worked just fine without an extra grounding conductor. I used a very sensitive ohm meter to verify that the body of the sending unit was indeed grounded solidly.
Stephen
Old Jul 20, 2010 | 08:09 AM
  #684
ron-s mini's Avatar
ron-s mini
The ground is created by screwing the metal sender into metal adapter/engine block.
The G connects to gauge and the WK is not used.
Old Aug 13, 2010 | 08:55 PM
  #685
Wetworth's Avatar
Wetworth
These all look great, I can't wait to get a pair for my car.
Old Aug 13, 2010 | 09:22 PM
  #686
Tron Chief's Avatar
Tron Chief
Contact Steve at Custom Mini shop and figure out what you need for your installation and really see what your car is doing His contact information is in my signature line.
Old Aug 14, 2010 | 07:41 AM
  #687
SRTech's Avatar
SRTech
Judging by his NAM handle, he may already be a customer.
Steve
Old Aug 14, 2010 | 07:57 AM
  #688
Wetworth's Avatar
Wetworth
He may be, quite recently at that
Old Aug 14, 2010 | 03:32 PM
  #689
Tron Chief's Avatar
Tron Chief
Dr Steve has so many patients that its hard to remember them all. Hopefully those that are local or are able will make it to custom mini shops 5 year anniversary on the 21st of August at 1200.
Old Aug 14, 2010 | 07:05 PM
  #690
JIMINNI's Avatar
JIMINNI
Steve
Hey didn't I steer you to Steve for your M7 plates?
Old Aug 14, 2010 | 07:46 PM
  #691
Wetworth's Avatar
Wetworth
Yes, they arrived today Thank you and no more mushrooming worries
Old Aug 14, 2010 | 09:16 PM
  #692
JIMINNI's Avatar
JIMINNI
Your welcome I have Marshall gauges also, you will like them
Old Sep 22, 2010 | 04:20 PM
  #693
R53-BRG's Avatar
R53-BRG
I went to custom mini shops site, and cant see where to buy marshall gauges. Am I missing something?
Old Sep 22, 2010 | 04:51 PM
  #694
Tron Chief's Avatar
Tron Chief
Steve at custom mini shop has some great prices, give him a call as he is always taking care of business. His number is 559-320-0004. If he does not answer let it ring it will forward to him.
John
Old Sep 22, 2010 | 05:41 PM
  #695
tonester's Avatar
tonester
they're not listed on his website. just give him a call. i just received mine from steve the day after i ordered them from him. He's very helpful over the phone also.
Old Sep 22, 2010 | 09:19 PM
  #696
JIMINNI's Avatar
JIMINNI
Yea his website is a little lacking at the moment, hopefully will updated soon
Old Feb 9, 2011 | 11:52 PM
  #697
Checkmate_2006's Avatar
Checkmate_2006
I really wish I would have seen these before I bought my Auxiliary Gauge Kit from MINI. I just ordered these gauges with Oil Pressure and Boost/Vac Gauge from CravenSpeed. I will change out the old gauges I hate the back lighting and no lighted needles, and the voltmeter is lame. Plus Boost is limited at 15psi.
Old Feb 10, 2011 | 07:43 AM
  #698
SRTech's Avatar
SRTech
Lacking, to say the least.
Steve
Old Feb 10, 2011 | 10:58 AM
  #699
JIMINNI's Avatar
JIMINNI
Is that the kit that sets down there by the cigarette lighter? If so, you can alwas use the pod holder there, just put some non-critical gauges there and the stuff you need to see up top
Old Feb 10, 2011 | 02:37 PM
  #700
Checkmate_2006
No I bought the kit that goes up on the steering column that includes the boost/vac gauge and voltmeter. I am going to keep the plastic trim piece that holds the gauges from the Aux Kit and place the new Marshall MINI Cooper gauges inside the pods. I will probably sell the old gauges on the marketplace for a wicked discount since I am keeping the plastic trim piece. I did buy the trim piece you are talking about that sits down near the cigarette lighter below the toggle switches. I intend to install the Oil Temp and Voltmeter down there, while I have the Boost/Vac and Oil Pressure beside the tach. I like watch the boost, vroom!
