Interior/Exterior Matching factory gauges
Old Jun 24, 2010 | 01:51 PM
  #651
plasticknives's Avatar
plasticknives
Originally Posted by JIMINNI
No they look good I wouldn't go out and change them either. I am now looking for a AFR gauge and obviuosly nothing is going to look OEM
I know GReddy used to make a wideband A/F gauge with the same silver face and bezel that JackFlash has. Not sure if it is still in production however.
Old Jun 24, 2010 | 01:59 PM
  #652
AA-MCS's Avatar
AA-MCS
Thanks Soggy, I live in Miami where its hot year round. Mine usually runs around 220 (highway and city, occasionally going to 230) till last Monday.
Thanks,
Old Jun 24, 2010 | 02:17 PM
  #653
Tron Chief's Avatar
Tron Chief
If my engine is running hot and the thermostat opens up or if I turn on my AC it is going to cause my temps to go from the normal 220 area to the 190-200 area. Also if I start really kicking the turbo it will drop the temps in the same manner.
Old Jun 24, 2010 | 02:35 PM
  #654
AA-MCS's Avatar
AA-MCS
Interesting Tron, Monday I used the AC at the Max setting. The temperature lately has been in the high 90's. Feel better after you guys chimed in with your experiences.
Old Jun 24, 2010 | 03:34 PM
  #655
JIMINNI's Avatar
JIMINNI
Actually Marshall makes a very close looking silver analog A/F gauge. SRTech showed me a pic. Only really thing that is different is the needle center is black, not silver. He is calling Marshall to see if they can remedy this for us Mini people If that happens I am going to get one and post pics, I may post the pics of what they have now and let everybody see it.
Old Jun 24, 2010 | 05:47 PM
  #656
michele r53's Avatar
michele r53
I have the Marshall gauges and the center is silver now not black anymore
Old Jun 24, 2010 | 10:15 PM
  #657
JIMINNI's Avatar
JIMINNI
Correct, on some of their gauges. I have the water temp and boost, they both have the silver center, but they haven't as yet make the A/F like that, but hopefully
Old Jun 25, 2010 | 02:30 AM
  #658
Tron Chief's Avatar
Tron Chief
Between Marshall's and Custom Mini Shop I'm sure this modification is possible.
Old Jun 25, 2010 | 07:21 AM
  #659
SRTech's Avatar
SRTech
Your silver needled AFR gauge should be here today. I'll take a picture with it next to the MINI gauges. I don't believe there is enough interest in a MINI specific gauge, but maybe I will be proved wrong.
Steve
Old Jun 25, 2010 | 07:28 AM
  #660
SRTech's Avatar
SRTech
Time to re-post gauge prices. All gauges are in stock. I can supply any of Marshall Instruments' gauges at a great price, MINI or not. I'm also testing the new CravenSpeed Hotlink for the automatic transmission, second generation MINIs, so it should be available soon.
Current Gauge Prices at Custom Mini Shop. The electric gauges without peak recall and warning (in red) are still available.
7411 - Vac/Boost, 30" Hg - 30 PSI (mechanical) $57.99
7471 - Vac/Boost 30" Hg - 30 PSI (stepper) $108.99
7421 - Voltmeter, 0-18V (electric) $57.99
7472 - Voltmeter, 0-18V (stepper) $66.99
7433 - Oil pressure, 0-100 PSI (electric) $79.99
7473 - Oil pressure, 0-100 PSI (stepper) $89.99
7434 - Water temperature, 100-260°F (electric) $73.99
7474 - Water temperature, 100-260°F (stepper) $82.99
7435 - Oil temperature, 170-310°F (electric) $79.99
7475 - Oil temperature, 170-310°F (stepper) $89.99
Marshall Dimmer for stepper gauges $25.99
RAC Dimmer for steppers (integrates with MINI's dimmer) - $45.00
Oil pressure, oil temperature and water temperature gauges include the sending unit with 1/8" NPT connection.
Stepper motor gauges have peak recall and warning functions.
CravenSpeed mounting systems and sender unit adapters are still available at a good price, also.
Please call Custom Mini Shop at 559.320.0004 or e-mail steve@blackoaks.com for ordering information. Thanks.
Steve
Old Jun 25, 2010 | 04:42 PM
  #661
SRTech's Avatar
SRTech
JIMINNI's Marshall AFR with the silver needle in our display. The face doesn't match, but if you're not too picky.....
Old Jun 25, 2010 | 06:38 PM
  #662
JIMINNI's Avatar
JIMINNI
That is sweet! Thanks Steve Custom Mini Shop is your Marshall headquaters
Old Jun 26, 2010 | 03:49 AM
  #663
bebop86's Avatar
bebop86
Curious- For us guys with chrono package how do u mount multiple gauges- since have the 2 larger guages to start with??
does anyone sell a mounting kit that fits where the cup hldrs are on Gen 1 to make it look built in??
Old Jun 26, 2010 | 08:11 AM
  #664
SRTech's Avatar
SRTech
There is a factory gauge kit that comes with a mounting panel. The panel is available separately and fits under the switch panel and screws to the console beneath. There are also CravenSpeed mounts (Z brackets) for the speedo/tach combo. If you mount the cups up high you can clear the steering wheel. It's not the best looking way to mount the gauges but at least you can see them.
Steve
Old Jun 28, 2010 | 10:34 AM
  #665
JumpingJackFlash's Avatar
JumpingJackFlash
That A/F gauge is sweet. However, they must have changed the production design. The SCX Silver gauges on Marshall's website show a black needle base instead of silver. Having the face match is not the most important to me. Overall color theme is what makes my day... silver tone, silver/amber needle, amber lighting.
Now if Marshall made a wideband O2 MINI specific gauge, or at least an EGT gauge (which is supposed to allow determining A/F by calculating the exhaust temperature), that would be the best.
Old Jun 28, 2010 | 03:44 PM
  #666
SRTech's Avatar
SRTech
I had this gauge made specially for JIMINMI, it's not a regular production model.
Steve
Old Jun 29, 2010 | 02:08 PM
  #667
JIMINNI's Avatar
JIMINNI
JumpingJackFlash, not sure what you mean by a wideband gauge? It's not the guage that matters its the sensor. I had a bung installed on my header and will get a wideband sensor so it will be a wideband.
Old Jun 29, 2010 | 02:19 PM
  #668
ScottRiqui's Avatar
ScottRiqui
The gauge needs to be matched to the sensor - you can't use a wideband sensor with any old gauge and expect it to work.
Even if you have a wideband sensor and wideband gauge, the gauge still has to be calibrated to the sensor. If you take a handful of different-brand wideband sensor/gauge packages and swap around the sensors, they still wouldn't read accurately until you calibrated them (if the gauge even allows calibration - not all do.)
Old Jun 29, 2010 | 10:28 PM
  #669
JIMINNI's Avatar
JIMINNI
So how does one, calibrate them?
Old Jun 30, 2010 | 04:03 AM
  #670
ScottRiqui's Avatar
ScottRiqui
If you're using the sensor that came with the gauge, you shouldn't need to calibrate it since it should have been done at the factory.
If you do need to calibrate it, you can buy tanks of compressed gas that will give a certain A/F ratio. Then, you just adjust the gauge until it reads correctly. A tuning shop would probably be your best bet for this.
But the easiest solution is to use the sensor that comes with the gauge in order to avoid all the compatibility/calibration issues.
Old Jun 30, 2010 | 06:49 AM
  #671
JumpingJackFlash
ScottRiqui, thanks for chiming in. I know that most narrowband gauges read on a 0-1 Volt range, and that most wideband gauges read on a 0-5 Volt range (hence the better accuracy). Yes, the GReddy gauge computer adapters do have dials on them, which I would suspect are for calibration purposes.
Having said that, can I actually mate the gauge unit with a wideband O2 sensor? If that is possible, I would definitely like to make that upgrade.
Old Jun 30, 2010 | 08:45 AM
  #672
n1tr0's Avatar
n1tr0
If you get a wideband kit like innovative's LC-1 you can calibrate it to match whatever sort of gauge you want.
http://www.innovatemotorsports.com/products/lc1.php
I believe you can even set it's voltage output so you could get away with a narrowband gauge and still have wideband accuracy.
I've used them before in (non-mini) projects with great success.
Old Jun 30, 2010 | 11:21 AM
  #673
JumpingJackFlash
Thanks n1tro0! I'll definitely keep that in mind.
Old Jun 30, 2010 | 08:54 PM
  #674
SRTech's Avatar
SRTech
Paul at Marshall recommends the Innovate sensors since Marshall makes most of the Innovate gauges. The Marshall AFR gauge needs 0-5 volts.
Steve
Old Jun 30, 2010 | 08:57 PM
  #675
36rodder's Avatar
36rodder
From: I live in Webster, NY (just east of Rochester)
Marshall MINI Gauges
Just finished installing Marshall MINI oil pressure and boost gauges in my '02 MCS. Thought I would post what they look like. First of all I would like to thank "plasticknives" for his inexpensive gauge mount, I built one very similar to his and it works great. One issue I had was mounting the gauge oil pressure sender along with the original sensor on the block. Very little space and I couldn't get it not to leak so I mounted them remotely, the ONLY way to go!
Much easier installatin and no leaks.
This is what the Marshall MINI gauges look like installed.
and with the lights on
If you want to dim your add on gauges with the stock gauges disconnect the plug on the back of your tach and tap into the middle wire. That is the backlight power for the Tachometer. Hook that to your backlight wire on your new gauges and they will dim the same as the stock gauges.
'02 Liquid Yellow MCS
