Interior/Exterior What do you think?
Old Apr 15, 2009 | 01:57 PM
AkFarina's Avatar
AkFarina
What do you think?
I am thinking about getting these wheels and i want some fellow mini opinions.
link
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
the offset is 40 so will i need to get spacers are is that wider than stock?
Old Apr 15, 2009 | 02:08 PM
schatzy62's Avatar
schatzy62
Nice Looking and very close to one or more of the OEM wheels.
Old Apr 15, 2009 | 03:45 PM
Shrashmere's Avatar
Shrashmere
mmm....
i want...
Old Apr 15, 2009 | 04:56 PM
JAS76's Avatar
JAS76
I like them!! My only thing is the weight ;( not a big deal though. I am looking into wheels too. I am looking into saving a little weight for performance as well. Overall a good looking wheel Want to see pics if you get them.
J
Old Apr 15, 2009 | 07:59 PM
Xray'dit_Mini's Avatar
Xray'dit_Mini
Alta carries the Konig Zero's that look almost exactly the same, but only weigh 17lbs........I have them on my car
Old Apr 20, 2009 | 01:19 AM
brocky
Guest
Posts: n/a
Those rims are soo beautiful. If you don't like the word beautiful, it looks AWESOME. haha. Good choice. Get some FAT rubbers on those. Like 235's.
Old Apr 20, 2009 | 03:11 PM
DNadar's Avatar
DNadar
post pics!!!
Old Apr 20, 2009 | 03:33 PM
glnr13's Avatar
glnr13
but your wheels are only 7" wide while the OP's are 7.5" so although you have less unsprung weight the OP will have a larger foot print.
also to the OP, in comparing the new set up (17x7.5" et 40) to OEM (17x7" et 48) with that offset your inside clearance will be fine, you will be pushing the outer dimensions of the wheel out .56" past the where your OEM 17x7" wheel is now.
Old Apr 20, 2009 | 03:40 PM
iwashmycar's Avatar
iwashmycar
No you will not need spacers. I just put some et38's on mine and its perfect. They will stick out 8mm more than the stock rims, plus a little extra because they are wider than stock. Also you may not be able to 'put some fat rubber' on them, like was said above. For example, on the rims I have, which only stick out 2mm more, there was a guy who could only fit 205s (this was on H&R springs though)
Old Apr 29, 2009 | 08:53 AM
dtsoccer6's Avatar
dtsoccer6
I almost opted for these! Great price, great style, and Kazera makes quality wheels. However, couple things to consider...
1. Heavy - at 21lbs+
2. The silver part in the middle throws off the black out, IMO
If those things don't bother you, then go for it, it will look great!
Old Apr 29, 2009 | 10:28 AM
AkFarina's Avatar
AkFarina
They are my daily driver wheels.
Old Apr 29, 2009 | 10:34 AM
asaulo1's Avatar
asaulo1
spacers?
Old Apr 29, 2009 | 10:36 AM
AkFarina's Avatar
AkFarina
no? 17x7.5 40 of set with 215x45 17
Old Apr 29, 2009 | 11:29 AM
dtsoccer6's Avatar
dtsoccer6
Old Apr 29, 2009 | 12:37 PM
AkFarina's Avatar
AkFarina
they are wider than my fenders tho so i couldn't lower it to much or it rubbed
