Interior/Exterior Gauges
Old Feb 13, 2009 | 12:08 AM
Porthos's Avatar
Porthos
Gauges
I looked around couldn't find anything about this. I have seen that some people have the tach and speedo right next to each other is there an option for this or is it a mod that can be done? Thanx sorry new and want to get my Mini
Old Feb 13, 2009 | 04:27 AM
schatzy62's Avatar
schatzy62
That is a Gen1 Option only. And then only for certian configurations. Not available on 2nd Gen cars.
Old Feb 14, 2009 | 02:12 AM
Porthos's Avatar
Porthos
Is there away to retrofit?
Old Feb 14, 2009 | 09:39 AM
spfdhed's Avatar
spfdhed
see Alta. They have the best aftermarket solution.
Old Feb 14, 2009 | 09:55 AM
dwf137's Avatar
dwf137
not easily. the location of the old ones was in the center of the car, moving the speedo over next to the tach. That's pretty much impossible on these.
Just check out alta as mentioned. They have some really nice aftermarket gauges.
I'm dying for a temp gauge.
Old Feb 14, 2009 | 10:08 AM
Smoogy's Avatar
Smoogy
I think this what your looking for https://www.northamericanmotoring.co...s-for-jcw.html
Old Feb 14, 2009 | 10:39 AM
dwf137's Avatar
dwf137
^ i haven't seen that, that's somewhat good, somewhat disappointing news. I'd like to see more options, like oil temp, oil pressure, boost, etc. At least they're offering a coolant temp gauge though.
Old Feb 14, 2009 | 11:14 AM
Jason Montague's Avatar
Jason Montague
To Go In Harm's Way
Check out "Scan Gauge II".EBay has it for $155.It's 8-10 gauges in one.Four gauges can be displayed @ once and even changed while driving.It also decodes the idiot lights and resets them.Kit comes complete with every thing you need.It takes about 5 min to install,plugs in to the OBDII under left dash and lights up @ night in various changable colors.It weighs nothing and is small 4"x11/2"x11/2".Mount it any where you want with the provided self adhesive velcro. Jason Montague
Old Feb 14, 2009 | 02:01 PM
trackster's Avatar
trackster
X1
This is an amazing tool and gives you all the important info you could ever want in one easy package. The added bonus of checking error codes and re setting them is a huge plus.
Old Feb 14, 2009 | 11:04 PM
Porthos's Avatar
Porthos
Thanx for the help I don't need 50 bajillion gauges I just really liked the look of the 2 right next to each other. It looks really professional.
Old Feb 14, 2009 | 11:08 PM
dwf137's Avatar
dwf137
^I'd agree with you.
Staring at a digital gauge isn't really the same as looking at an analog style gauge. You have to think about the readout from a digital gauge, an analog gauge you can just glance at and understand what's going on.
Old Feb 14, 2009 | 11:47 PM
Porthos's Avatar
Porthos
Ya even though I won't be able to to retrofit it it will be ok. I loved how it responded and how easy it is to read the tach in the car.
Old Feb 15, 2009 | 12:13 AM
dwf137's Avatar
dwf137
you'd be able to get the gauges shown in the link above, no problem...
I still think Alta might be the better option because they have the boost, and water temp, and exhaust gas temp... a bit more performance oriented then the "relative torque" gauge.
Old Feb 15, 2009 | 12:40 AM
Porthos's Avatar
Porthos
boost gauge is a most the rest is just relative
Old Feb 15, 2009 | 05:37 AM
Mini Bo Bini's Avatar
Mini Bo Bini
I went with the Stewart Warner boost and temp gauges mounted in the Alta dual pod.
Installation was relatively easy, the gauges look like stock, and it all works as advertised!
Old Feb 15, 2009 | 09:19 AM
dwf137's Avatar
dwf137
how did you tap in for the water temp?
did you buy one of the little couplers from m7 to take temp readings of the actual coolant being circulated, or did you tap the bottom of the reserve tank?
Old Feb 15, 2009 | 01:24 PM
Porthos's Avatar
Porthos
Do you got pictures the website doesn't have any install pictures. But they look good.
bahman
Feb 14, 2016 10:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
