Interior/Exterior BMW OEM Fire Extinguisher
Old Dec 7, 2008 | 09:39 PM
MaxMini81's Avatar
MaxMini81
Wanderer
Anybody know where to get the OEM Bimmer Fire Extinguisher? I've seen it so I know it exists, and now i naturally want it.
Old Dec 7, 2008 | 10:26 PM
MiniFaron's Avatar
MiniFaron
From: Albuquerque, New Mexico No I dont need a Green Card
I will ask my friend in the BMW Parts Department if we sell one. I will et you know!
Old Dec 7, 2008 | 11:47 PM
lovethecorners's Avatar
lovethecorners
According to RealOEM.com the Fire Extinguisher can be mounted in either the glovebox or trunk and if accurate the part is still available...
http://www.realoem.com/bmw/showparts...27&hg=72&fg=95
Old Dec 7, 2008 | 11:53 PM
desertmini21's Avatar
desertmini21
Old Dec 8, 2008 | 07:34 AM
MiniFaron's Avatar
MiniFaron
I will look into it when I get to work!
Old Dec 8, 2008 | 07:55 AM
MaxMini81's Avatar
MaxMini81
Wanderer
Thanks guys, please do let me know. As for the links, it was stumbling across the DIY on motoringphile that alerted me to its existence. It seems cool, different, and nice and compact.
Old Dec 8, 2008 | 09:50 AM
desertmini21
Have you tried this site:
http://www.lbcarco.com/searchf.html
Old Dec 8, 2008 | 11:28 AM
k-huevo's Avatar
k-huevo
This MINI extinguisher is fine if you desire it for its unique qualities, but for function, a larger capacity extinguisher will serve you better when needed. Even a 2.5 lb extinguisher won’t last very long (you should hope to have accurate aim and catch the beginnings of an electrical fire). As for the mounting location, the diminutive MINI extinguisher won’t weigh much, but it will place stress on “plastic” mount points. The rear of the glove box is secured with one small screw, which self taps into a plastic thin walled fresh air chamber box. The outer attachment points are plastic also and I would presume not designed to support much of a load. Mileage weakened attachments could allow the heavy object to eject if rear-ended.
Please don’t misunderstand my cautions about this product, I highly recommend an inboard fire extinguisher for 1st generation MINIs, and a mount location within arms reach. However, I suggest choosing a higher capacity extinguisher, and more secure mounting method for the bracket than the glove box shell.
Old Dec 8, 2008 | 01:12 PM
MaxMini81's Avatar
MaxMini81
Wanderer
Very good info. Thanks. Two things came into play here.
1) I liked the look and uniqueness of the OEM part. Despite its side and whatnot it seemed to be an interesting addition. I wasn't honestly looking for funtion, mayber I should be.
2) I don't know what in the world this will cost. I don't want to spend a lot but if it is expensive you can bet I would go for the better product. I have used a cheap extinguisher in the past and it worked fine, but if I'm looking at over say, $80 for this I'll go ahead and get the Halon high quality ones. Right now I'm just trying to gather info.
That said, excellent points made and info presented. Definately food for thought.
Old Dec 8, 2008 | 01:43 PM
desertmini21
If you type "fire extinguisher" in the search field and choose "New MINI" from the drop down menu, you will find the price to be about $75.
Old Dec 8, 2008 | 03:53 PM
MiniFaron's Avatar
MiniFaron
Looks like you found it with out my help!
Old Dec 8, 2008 | 08:01 PM
MaxMini81's Avatar
MaxMini81
Wanderer
I guess so, assuming thats it... lol thanks everyone for the help!
Old Dec 8, 2008 | 08:36 PM
desertmini21
Are you looking for an extinguisher that is specifically BMW?
Old Dec 8, 2008 | 09:03 PM
MaxMini81's Avatar
MaxMini81
Wanderer
Yes the OEM (Original Equipment Manufacturer) BMW. But that site didn't have an illustration. But I appreciate the input, the sites a good resource.
Old Dec 9, 2008 | 02:09 AM
xnotfunkylex's Avatar
xnotfunkylex
I think you can only get them in Europe. At least that's what I read on two sites.
You can try these though
Fire Extinguisher # 7260 0000 335
Bracket # 7260 1945 556
Old Dec 15, 2008 | 05:32 PM
kb30's Avatar
kb30
here is a link to a british site with the r56 oem extinguisher.
http://www.mybeautifulmini.com/index...roducts_id=403
hope this helps, it's not too expensive
blackie
Oct 2, 2015 07:41 PM
Aug 19, 2015 12:51 PM
FLYM1N1
Aug 16, 2015 01:15 PM
