Interior/Exterior Gauge overlays-help anyone done this?
Old Nov 15, 2008 | 04:02 PM
  #26
benji_mini's Avatar
benji_mini
Originally Posted by benji_mini
ok so im in the process of doing it now but im taking a break (out of frustration) - this may sound silly and make me look stupid but how do you get the hazard button out of the black platic peice from the speedo?! i want to get that entirely off and out of the car. im sending it to Lyle for some cool stuff (pics when its all finished obviously). and i cant figure out how to get the black ring off, i got the clear plastic off over the speedo which was easy as can be...but that black peice looks tricky. i dont see any write ups anywhere for removing the tach either...any instructions?
thanks in advance.
ok i got the gauges done, i had to push the clips of the black peice in and use a "place holder" basically (credits cards that were old and such) to keep the tab open and worked my way around until all were done. hope this helps someone.
they look amazing. Lyle does fantastic work. pictures will be up either tomorrow or during the week, whenever i get a chance. im still trying to remove the othe chrome bits from the car to send to Lyle for my next project. haha
Old Jun 24, 2009 | 09:43 AM
  #27
enron29's Avatar
enron29
Has anybody found a trick to removing the needles? I will be installing my gauges soon, and I really want to try and avoid cutting them and would like to pull off the needles.
Old Jun 29, 2009 | 09:46 PM
  #28
dwf137's Avatar
dwf137
anyone happen to have a write up for how to do the gauges without taking the whole dash apart and removing the speedo totally?
Old Jun 29, 2009 | 11:14 PM
  #29
rkw's Avatar
rkw
There is no way around it. You have to take everything apart.
There's a good video on removing the speedo: https://www.northamericanmotoring.co...al-on-r56.html. For the speedo only, you can skip the middle steps where he demonstrates taking apart the center console.
Old Jun 30, 2009 | 11:04 AM
  #30
dwf137's Avatar
dwf137
^yea, i guess that's what I was thinking was avoidable.
oh well, shouldn't be too hard either way
Old Jul 16, 2009 | 06:41 PM
  #31
celiborgy's Avatar
celiborgy
That video discourages me to do this mod. It sure is nice though...
Old Jul 16, 2009 | 07:07 PM
  #32
dwf137's Avatar
dwf137
^it's easier and less intimidating then it looks. You don't need to do anything around the center console. The "hardest" part is popping off the trim behind the tach.
Old Jul 16, 2009 | 07:53 PM
  #33
enron29's Avatar
enron29
For those of you that cut slits to slide around the needles rather than popping off the needles, how did you cut your tach overlay. I know most have cut along the zero line so that it lies behind the needle when the car is off. My question is did you cut directly through the dash and 0, or did you cut down that line and then go around the number 0 and dash?
Also, how much double sticky did you use on the back of the speedo gauge. I had installed one previously, but was having problems with it warping. Not sure if I messed it up when installing and bent it too much, or the high heat we've had recently. Just trying to see how much sticky tape everyone used and where you placed it.
Thanks for the help.
Old Jul 16, 2009 | 10:52 PM
  #34
dwf137's Avatar
dwf137
my speedo just started warping in the warm weather too...
i went to the extreme on the tach and cut out the entire clear section that would go over the screens. Mine got scratched and trying to clean it up only made it worse. I decided I'd rather spend 20 mins cutting them out then settling for them being scratched and looking like crap. It made it really easy for where to cut, Just a small little slit in the thin portion below the needle.
Old Jul 17, 2009 | 05:12 AM
  #35
enron29's Avatar
enron29
I'm not happy that yours is warping too, yet I'm glad to know that it's not just me. I was thinking about doing the same on the tack. Did you just take an exacto knife and cut around the edges really slowly and carefully?
Old Jul 21, 2009 | 07:12 PM
  #36
<MINI>'s Avatar
<MINI>
Here are a couple of links that helped me, post #40 in the second link has a couple of links to instructions and pictures that guided me through the whole process. Cutting the new face to slide over the needle was the only way I could do it cuz the needles were never going to come off!
https://www.northamericanmotoring.co...uge-faces.html
https://www.northamericanmotoring.co...cf-gauges.html
Old Jul 31, 2009 | 01:25 PM
  #37
enron29's Avatar
enron29
Is anyone else, besides DFW137, having issues with the speedo gauge overlay warping in the hot summer temps? Any recommendations on how to fight it? I'm wondering if it's cause I cut it to slide it over the needle. It seemed like I layed a lot of double stick tape, but that didn't work. Any ideas? Thanks.
Old Jul 31, 2009 | 01:38 PM
  #38
<MINI>'s Avatar
<MINI>
My speedo lifts a little bit, but not much. I didn't use tape or glue to hold it down, just dry. It may be a bit wavy depending on temperature, but nothing to worry about.
Old Jul 31, 2009 | 02:03 PM
  #39
dwf137's Avatar
dwf137
mine's so bad it actually is messing up the movement of the speedo needle.
I'm going to take mine apart and use most of the tape in the center, none at the edges.
The problem is that the plastic that was used has a high expansion rate. If you put it on in cool weather, when it heats up it expands. with tape cut up and put in a ton of locations it will cause it to bunch up.
and yes, I just worked very slowly with an exacto knife to cut out the clear areas on the tach.
bahman
Feb 14, 2016 10:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
