Interior/Exterior blacked out a couple things today
Old Aug 7, 2008 | 02:52 PM
  #126
call it spade's Avatar
call it spade
Originally Posted by chaseabryant
There are two screws in each, you have to open you glovebox to access one on the passenger side, and then to get to the upper screw on the driver's side, you have to pull down your knee bolster. To do that, you have to put your hands on either side of the cutout for the steering column cover. Be sure to be grabbing in there pretty well, because you can separate the plastic backing from the decorative outer panel.
Any way, pull with a little force, and it should come unclipped at the top, and swing down on a hinge system. Unscrew the two screws holding the downtubes on. To make things easier, clip your knee bolster back up where it was.
Next, you will have to detatch your center console that the gearshift comes out of. First, unscrew both screws located in your cupholders, then, you have to pry up your seat heater controls, don't worry, this is very easy. I used a butter knife to get between the plastics, and turned it sideways to pop it up. It should lift right out. Be careful that you don't lose the little brass clips that may begin falling out of the seat heater button assembly.
Unplug all wires from the seat heater controls, be sure to note (mentally at least) which plugs go where. Then unscrew both screws that are located below where the seat heater controls were. It might help to unclip your gearshift boot trim, just grab on either side and pull up. Just raise the ring/boot over your gearshift so it is out of your way.
Then, last but not least, unplug your cigarette lighter and the little bulb that lights the ring surrounding the lighter.
Now, your center console should be loose, slide both seats all the way back, and slide the center console backwards; your downtubes should be able to tilt out from behind your dash, and then slide down and out through the center console.
Installation is reverse of removal, I do hope this helps, and wasn't too convoluted...
-Chase
Thank You very much chase! i will be using this to my advantage very soon!
-Spade
bneer
Jul 15, 2019 04:41 PM
mcoopers81
Aug 19, 2015 01:42 PM
jrezzo
Aug 9, 2015 10:32 PM
SDMini_me
Aug 7, 2015 08:10 AM
M7Speed
Aug 6, 2015 01:48 PM
