Interior/Exterior blacked out a couple things today
Old Jun 25, 2008 | 09:28 PM
  #101
pimpedout97x's Avatar
pimpedout97x
hahahha
Old Jun 25, 2008 | 09:31 PM
  #102
cartar452's Avatar
cartar452
lookin sweet son
Old Jun 26, 2008 | 12:08 AM
  #103
call it spade's Avatar
call it spade
my friends brother just brought up his e46 M3 from malibu today and it was murdered out. we call it the bat mobile. i'll snap some shots for you guys, it is totally awesome.
Old Jun 28, 2008 | 01:51 PM
  #104
cartar452's Avatar
cartar452
Here's a few pics with my recent blacked out pieces...
Now just need to do the door handles and tint my lights
Old Jun 29, 2008 | 12:18 PM
  #105
pimpedout97x
that looks real good man, and yea those red tails are killin it!
i hate everytime i look at mine, makes me want to black them out everytime.. i just havent done it yet
Old Jun 29, 2008 | 01:18 PM
  #106
Nitrominis's Avatar
Nitrominis
Originally Posted by pimpedout97x
i am blacking the gauges out, i just refuse to spend the $150+ (i believe) for the gauge faces.
I don't use the cup holder either. This gauges can be seen and read while driving. I am 6ft and have no trouble. This gauge holder was made complete with paint for about 15$.
Old Jun 29, 2008 | 01:42 PM
  #107
Malcon's Avatar
Malcon
any way to get a how to write up on that setup???
Old Jun 29, 2008 | 05:39 PM
  #108
istara's Avatar
istara
I second that!
Old Jun 30, 2008 | 02:01 PM
  #109
call it spade
+3!
Old Jul 1, 2008 | 06:55 PM
  #110
call it spade
so blacked out my headlight rings and my chrome trim above the doors and tinted the lights. Also, i picked up H-lowering springs and JCW Exhaust today for $50 and i am painting the exhaust black as we speak soo stoked!
Old Jul 2, 2008 | 05:55 PM
  #111
pimpedout97x
pics when your done!!! just post em here !
Old Jul 3, 2008 | 01:04 AM
  #112
call it spade
alright i'll shoot some in the morning!
Old Jul 4, 2008 | 12:00 AM
  #113
call it spade
alright here is the JCW exhaust
installed...
here's the front end now
yay just a few more steps and i'll be done blacking it out
Old Jul 4, 2008 | 10:32 AM
  #114
pimpedout97x
what paint did you use for the exhaust? i have the same JCW exhaust, i think im just gonna paint my tips black, so i dont have to take the whole thing off.
Old Jul 4, 2008 | 01:43 PM
  #115
Nitrominis's Avatar
Nitrominis
Thanks ! I will work on it .I have the pictures around some where. You are going to laugh when you see what I used. But the end product look good and easy to duplicate.
Old Jul 4, 2008 | 11:58 PM
  #116
Malcon's Avatar
Malcon
PVC??
thats what it sorta looks like to me!
I have a home made tach mount in my old mustang that i made with PVC. you wouldn't know the difference if it wasnt painted and purdyfied.
haha
Old Jul 5, 2008 | 12:32 AM
  #117
call it spade
i used just a flat black 1200˚ spray paint. i just cleaned it thoroughly and it looks nice. you can still see the John Cooper Works signature on the tips
good luck!
Old Jul 5, 2008 | 06:51 AM
  #118
pimpedout97x
dupli color engine enamel?
Old Jul 5, 2008 | 01:03 PM
  #119
call it spade
yes sir. thank you. i didn't have it where i was so i couldn't say what kind it was.
Old Jul 6, 2008 | 12:11 PM
  #120
Nitrominis's Avatar
Nitrominis
PVC??
haha
and a little sanding.
Old Jul 6, 2008 | 04:25 PM
  #121
Malcon's Avatar
Malcon
haha i guessed it? awesome!
does that mean i win a set!?!
thanks man!!!
-Malcon
haha
Old Aug 4, 2008 | 02:27 PM
  #122
macinova22's Avatar
macinova22
how did you get the clock mount off?
Old Aug 6, 2008 | 05:34 PM
  #123
call it spade
how do you take the pillars on the center console off?
Old Aug 6, 2008 | 08:18 PM
  #124
chaseabryant's Avatar
chaseabryant
There are two screws in each, you have to open you glovebox to access one on the passenger side, and then to get to the upper screw on the driver's side, you have to pull down your knee bolster. To do that, you have to put your hands on either side of the cutout for the steering column cover. Be sure to be grabbing in there pretty well, because you can separate the plastic backing from the decorative outer panel.
Any way, pull with a little force, and it should come unclipped at the top, and swing down on a hinge system. Unscrew the two screws holding the downtubes on. To make things easier, clip your knee bolster back up where it was.
Next, you will have to detatch your center console that the gearshift comes out of. First, unscrew both screws located in your cupholders, then, you have to pry up your seat heater controls, don't worry, this is very easy. I used a butter knife to get between the plastics, and turned it sideways to pop it up. It should lift right out. Be careful that you don't lose the little brass clips that may begin falling out of the seat heater button assembly.
Unplug all wires from the seat heater controls, be sure to note (mentally at least) which plugs go where. Then unscrew both screws that are located below where the seat heater controls were. It might help to unclip your gearshift boot trim, just grab on either side and pull up. Just raise the ring/boot over your gearshift so it is out of your way.
Then, last but not least, unplug your cigarette lighter and the little bulb that lights the ring surrounding the lighter.
Now, your center console should be loose, slide both seats all the way back, and slide the center console backwards; your downtubes should be able to tilt out from behind your dash, and then slide down and out through the center console.
Installation is reverse of removal, I do hope this helps, and wasn't too convoluted...
-Chase
Old Aug 6, 2008 | 08:46 PM
  #125
chaseabryant
I hope that you don't mind if I answer this, using a plastic prying tool, or a butter knife in my case , locate a point about half way back on the on the pod, and then release the clip that is on that side. When locating the clip, your tool should not go very far into the clock pod. Once you have the clip on whatever side you are working on seemingly free, just pry downwards, it should release the metal clip that is on the front of the pod, as well as the other "clip" that is directly opposite the one you were working with. From there, it is self explanitory, unplug the clock, and then unscrew the inner workings from the outer pod.
Hope it helps!
BTW, to everybody that has posted pictures, amazing jobs so far. Everything is looking amazing!
-Chase
