Interior/Exterior So upset dont know what i am doing wrong
Old Jun 7, 2008 | 11:33 PM
ittle85's Avatar
ittle85
hi everyone.
I tried the where you make the fog light work as a taillight. Well, i have visted a total of three sites, and yes read all the threads here about it, i didn't want to splice the wires so i simply placed a jumper wire in pins 1 and 4, well after everything i have played around with and did and read i can't get the darn thing to work!! Please, what am i doing wrong? I've been here since 10 30 pm and its 1 34 am...pretty ridiculous right?
Thanks for your help guys..
Old Jun 7, 2008 | 11:49 PM
billie_morini's Avatar
billie_morini
For now:
1. go to sleep
For later:
1. are you sure the the jumper wire is making connection at each node?
2. have you got a ground?
3. is the bulb in the fog light still good?
4. do the tail lights still work (if not, check fuse)
Old Jun 8, 2008 | 12:44 AM
ittle85's Avatar
ittle85
oh wow....
um making a connection at each node how can you be sure if i'm just putting the wire in the pin? i push it in as much as i can...would that be makin a connection?
My ground...I'm putting one end of the wire from one pin and the other to the other pin...i thought pin 4 was the ground...?
bulb in the fog light still being good, that's a great question...
tail lights still work yes...
can't go to sleep was hoping someone would respond! :-)
Old Jun 8, 2008 | 08:59 AM
rkw's Avatar
rkw
Do you mean as a rear running light (not a brake light)? The popular 02-04 fog light jumper mod makes the fog turn on with the brakes only. For the rear running light, you'll have to determine which pin it is connected to and apply the jumper there. BTW, you don't have to deal with ground. All the bulbs in the taillight should already be connected to ground through another wire.
Old Jun 19, 2008 | 12:17 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
1st question (maybe it's obvious) is what year MINI you have? This was only possible on the 02-04 years.
Old Jun 19, 2008 | 10:56 PM
yellowbritishrocket's Avatar
yellowbritishrocket
if you have the right one make sure the diode side (usually red or has a stripe) is pushed into 1 and push down till u hear is rub against the metal connector...use some electrical tape to keep it down
Old Jun 20, 2008 | 10:22 AM
ittle85's Avatar
ittle85
yeah that's exactly what i was doing incorretly..the metal connector...thing is i decided to go against it when i read posts about some ppls bc1 or something like that going wrong after doing that particular mod...for me, better safe than sorry
ccfirelt
Oct 18, 2015 01:02 PM
honderpilot
Oct 11, 2015 06:35 AM
simo711
Oct 1, 2015 05:36 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
TifosinDel
Sep 28, 2015 10:45 AM
