Interior/Exterior headlight ring removal
Old Jan 21, 2008 | 11:45 AM
jtack's Avatar
jtack
tried to do a search but didnt find anything....was wondering what involved with headlight ring removal...do the headlights need to come out? If the headlight needs to come out are the (3) tabs that I can see from the outside easy to remove?
Thanks!
Old Jan 22, 2008 | 04:49 AM
MiniStupidfun's Avatar
MiniStupidfun
Remove the head light(3 nuts). Carefully pry the tabs that hold the head light ring to the headlight.
Old Jan 22, 2008 | 10:56 AM
UKSUV's Avatar
UKSUV
use a jewelers common screwdriver and be real easy...youll most likely break one (i didnt) but just use 3M double sided tape and it will be fine!
Old Jan 22, 2008 | 10:59 AM
glnr13's Avatar
glnr13
pry the bottom and two side tabs. once those are free you can slide the ring upward and avoid dealing with the top 3 clips
Old Apr 13, 2008 | 07:01 PM
foreverfadesx's Avatar
foreverfadesx
If you don't paint them what kind of vinyl can you use and how do you apply it?
Old Apr 14, 2008 | 06:12 PM
RTurner's Avatar
RTurner
get some high quality vinyl from any good sign shop. i got mine from a shop called sign-a-rama. they have stores all over the country. it cost me about 25 bucks for a 2' x 3' piece. as for applying it, use heat and be patient. i messed up a couple times but finally got it right.
Old Apr 15, 2008 | 05:24 PM
foreverfadesx
Heat as in a hairdryer or do you need a heat gun?
Old Apr 15, 2008 | 07:04 PM
MUShadd's Avatar
MUShadd
hairdryer would be plenty...a heat gun gets too hot...if ur not careful with a heat gun, you could melt the rings, and/or your hands.
Old Apr 15, 2008 | 07:05 PM
glnr13's Avatar
glnr13
yah, dont melt your hands
Old Apr 15, 2008 | 07:34 PM
Jhud's Avatar
Jhud
hey what happened to you...oh nothing i just melted my hands with a heat gun. no big deal.
Old Apr 16, 2008 | 06:34 AM
foreverfadesx
But then you could have awesome hooks for hands. Everybody wins in this situation.
dyeLucky
Sep 11, 2015 10:41 AM
greekzilla
Aug 23, 2015 03:44 PM
kpl
Aug 11, 2015 04:52 AM
dyeLucky
Aug 7, 2015 07:10 AM
