Interior/Exterior Joey mod R56!
Old May 26, 2013 | 02:45 AM
  #551
Nouprep's Avatar
Nouprep
Old May 26, 2013 | 07:14 AM
  #552
GHoov's Avatar
GHoov
looks like it paid off! I have had Zero problems with my mod... and its been a little over a year! So just enjoy!
Old Jun 7, 2013 | 06:35 AM
  #553
rac427's Avatar
rac427
Love this mod!!
Old Sep 9, 2013 | 03:40 PM
  #554
Raymazing's Avatar
Raymazing
What is the trick for the projector surround?
Old Sep 9, 2013 | 05:26 PM
  #555
borderwave2's Avatar
borderwave2
The projector "shroud" as it is called is held on by two small tabs at 9:00 and 3:00, which can be reached from behind the projector. Push each tab in one at a time and wiggle the shroud off carefully. When you fully remove it you will see a small Phillips head screw holding the clear section of the shroud. Unscrew this screw and. Remove the clear section before painting.
Old Sep 11, 2013 | 10:52 AM
  #556
mini6spd's Avatar
mini6spd
attempted this 2 days ago but i broke some clips on the Right headlight inner housing... good thing my headlight is a standard R56 reflector housing, so i sourced one on a local wrecker for basically nothing. Cant imagine how much i'd be out if i had the xenon projector lamp...
Old Nov 24, 2013 | 09:12 PM
  #557
Sgt.Beer's Avatar
Sgt.Beer
my joey mod
Heres mine. I did the joey mod and I swapped out the projector lens for a clear one and modded the projector to make more color at the cut off. Pictures dont do it justice though
Attached Thumbnails Joey mod R56!-20131116_171102.jpg   Joey mod R56!-20131113_204031.jpg   Joey mod R56!-20131121_220816.jpg
Old Nov 25, 2013 | 05:08 AM
  #558
borderwave2
[QUOTE=Sgt.Beer;3846142] Heres mine. I did the joey mod and I swapped out the projector lens for a clear one and modded the projector to make more color at the cut off. Pictures don't do it justice though[/QUOTE
What lens did you use? I went with a ZKW-R (value) from TRS and it fit perfectly. My cutoff is razor sharp, even with the stock shield. Did you back out the shield adjustment screw and bend/remove the RV shield? Your cutoff doesn't look as sharp as it should be with a clear lens.
Old Nov 25, 2013 | 01:05 PM
  #559
Sgt.Beer's Avatar
Sgt.Beer
I got the same lens as you did. I think its just the pictures. The passenger side is very sharp but I couldnt erver get the driver side to match. But I adjusted that screw alittle and put spacers on the bottom 2 screws of thr lens mount.
Old Jan 8, 2014 | 08:30 PM
  #560
8eMINI's Avatar
8eMINI
This looks pretty cool. I actually need a set of the halogen headlight orange turn signal lenses for my R56. If anyone has a pair for sell, please send me a pm!
Old May 16, 2014 | 04:53 PM
  #561
CZ Mate's Avatar
CZ Mate
Anyone from Oregon know how to do this. I Would love to have my Wife's halogen headlights done, but to scared to do it myself. I live in Eugene, and would love to find someone thats done it before.
Old May 16, 2014 | 04:55 PM
  #562
Sgt.Beer's Avatar
Sgt.Beer
There are a couple threads on how to. It's a whole lot easier then u think.
Old Nov 5, 2014 | 07:34 PM
  #563
LILYisatig3r's Avatar
LILYisatig3r
Ugh I also want to do this to mine but it sounds terrifying @_@
Old Dec 16, 2014 | 08:52 PM
  #564
<MINI>'s Avatar
<MINI>
For those still considering the "Joey Mod".....DO IT!
I had my MINI for more than 4 years and 120,000 miles AFTER painting my "standard" headlights - without issue.
Condensed instructions:
oven at 200 - 250* F for 5 minutes
Krylon Satin Black without scuffing the surface, just a good cleaning with acetone.
Attached Thumbnails Joey mod R56!-mini-7-14-010.jpg   Joey mod R56!-mini-7-14-007.jpg   Joey mod R56!-mini-7-14-009-large-.jpg
Old Jan 10, 2015 | 06:34 AM
  #565
'10JCW's Avatar
'10JCW
I am having trouble getting the lower outside bolts off, it seems the metal housing they screw into are spinning. Any suggestions on how to get it out? I am about the just Dremel the damn thing!
Old Jan 10, 2015 | 12:14 PM
  #566
Ovrclck's Avatar
Ovrclck
Is it wrong to pay someone to joey mod my Xenons? :p
Sent from cellular device.
Old Jan 10, 2015 | 12:46 PM
  #567
<MINI>'s Avatar
<MINI>
WARNING....
I helped a friend do his 2013 with halogen lights last week and found that acetone REMOVED the chrome plating from the plastic rings that attach to the clear lenses. This was just a quick wipe to prep the surface for paint. It wasn't an issue as they were being painted anyway, but don't wipe the reflector areas!
Also, he used a no-name blue tape instead of 3M...it left a residue on the reflectors. It proved very difficult to remove as we were so afraid of damaging the chrome.
Use 3M tape and good luck!
Old Jan 10, 2015 | 12:49 PM
  #568
<MINI>'s Avatar
<MINI>
If you don't think it's within your comfort zone, then yes, get someone else to do it.
It really isn't difficult, though. Just read the entire thread and take notes.
Old Jan 14, 2015 | 06:25 PM
  #569
toolazyforalogin's Avatar
toolazyforalogin
go back and read my posts about it earlier in the thread.
Old Feb 27, 2015 | 05:18 PM
  #570
Ovrclck's Avatar
Ovrclck
Edit: figured it out.
Old Mar 14, 2015 | 07:07 PM
  #571
Ovrclck's Avatar
Ovrclck
So today I attempted the mod via the heat gun method. Turns out I don't have the patience and ended up scrapping the project for now.
The oven method looks way simpler. Are the electronics easy to remove on a Xenon?
Old Jun 16, 2015 | 06:43 AM
  #572
no1jones's Avatar
no1jones
I've had my 08 MCS for 3 weeks and I saw the "Joey" mod sniping the pages. I had to do it and I like the results. I've already blacked out most everything else so this was only natural. Also smoked the amber plastic and all reflectors while I was at it.
Attached Thumbnails Joey mod R56!-img_0653.jpg   Joey mod R56!-img_0654.jpg   Joey mod R56!-img_0655.jpg
Old Jun 17, 2015 | 11:56 AM
  #573
BackcountrySkier13_inAZ's Avatar
Looks good!! What am I seeing with your bulbs being blue?? I want to Joey Mod mine too but honestly I have been a bit afraid to haha, I think I will after warranty though.
Old Jun 17, 2015 | 09:06 PM
  #574
no1jones's Avatar
no1jones
That is just the cover that is over the bulb. I had seen others paint it black so I figured I would see about painting blue to match. It turned out better than expected. Do the mod you won't regret it. I just jump right into projects. There are great tutorials on this thread that walk thru step by step.
I personally did 215 degrees for about 5-6 minutes and it came right apart. I also highly recommend getting real automotive tape for the masking. Masking off the reflective part was by far the most frustrating part for a not so patient person.
Over all I think it looks good, plus tinting all the other lights around the car ties it all together. So don't wait any longer, jump in feet first. Worst case you ruin a light and you have to buy a new one .
embiggenedmini
Oct 15, 2015 12:36 PM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
Bea5tMa5ter
Aug 27, 2015 01:42 PM
makg
Aug 21, 2015 02:49 AM
