Interior/Exterior Front and rear MINI emblems
Old Jan 3, 2008 | 10:39 AM
jtack's Avatar
jtack
Does anyone know if they are just stuck on or are there posts that go into the hood and trunk. I want to shave them off but dont want to find holes underneath.
Thanks.
oh this is on a 04 MCS if that matters.
Old Jan 3, 2008 | 10:43 AM
1QukMINI's Avatar
1QukMINI
They are just stuck on there.
Old Jan 3, 2008 | 10:44 AM
Gil-galad's Avatar
Gil-galad
Believe the tool of choice for removal is dental floss.
Old Jan 3, 2008 | 10:46 AM
jtack's Avatar
jtack
cool! Thanks for the fast response.
Old Jan 3, 2008 | 10:47 AM
gokartride's Avatar
gokartride
I believe there are two alignment holes for at least the front logo, so if you remove it there will be holes. Not sure about the back one.
Old Jan 3, 2008 | 11:09 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Correct. There are alignment holes for both emblems.
Old Jan 3, 2008 | 11:25 AM
jtack's Avatar
jtack
wow! you guys saved me big! I was getting ready to take these off...that would have been a real bummer to find the alignment holes.
gaffer's Avatar
gaffer
I ordered a new emblem a couple of weeks ago. They have 2 alignment posts, side to side, and thin black rubbery tape. You will have 2 holes roughly 5mm in diameter, roughly 40 some odd millimeters apart (guessing from memory). That is for the smaller front S emblem. The back emblem is bigger, not sure if the holes are spaced wider.
Old Jan 3, 2008 | 02:02 PM
WLSH BST's Avatar
WLSH BST
The mini emblems definately have holes for the front and back. I had mine removed the holes welded shut and panel's repainted. I prefer the look but its not worth the hassle unless you're having the panels painted for some other reason.
Old Jan 3, 2008 | 03:14 PM
Jahmills's Avatar
Jahmills
I thought they had holes, I was just thinking about how to go about pulling mine, so they use tape to stick on? Do they have to be heated? I will need to pull mine this summer when I change my stripes. I do want to put them back on over the stripe.
Old Jan 3, 2008 | 04:40 PM
WLSH BST's Avatar
WLSH BST
No need to heat them, just floss them off. If you're careful in removing them it is possible to reuse them, buy the double sided adhesive backing from an auto paint store they know the stuff if you ask for it there.
emulajavi
Dec 24, 2018 09:15 AM
StealthR53
Aug 8, 2015 10:59 AM
Aug 7, 2015 05:56 AM
