Interior/Exterior dash install tips??
Old Dec 15, 2007 | 10:59 AM
Beecher's Avatar
Beecher
dash install tips??
i just got my jcw cf dash this morning, and am trying to install it. The center and driver side went well, but i cant get the psngr side fully attached. It just clips in with friction clips, and i cant get the two upper ones towards the drivers side to engage. Ive pulled it back off, and tried starting with those two, but it just clips all the ones in as soon as i apply pressure. Any one got any tips or cheats for installing it?
i will also give a tip to people removing one, when you get the drivers side one unattached, or maybe even before would be easier, but anyway, remove the tack, and un hook the rubber part from around the piece of alluminum showing in there. Its hard to see. I pulled the rubber off from the dash piece itself, and when i opened the new one, found it came with a new rubber. Its much easier to remove the rubber the proper way that trying to pull it off the rivets that hold it to the dash insert:impatient.
thanks for any help
oh, its a 3pc dash by the way.
and the jcw spoiler looks amazing, i just wish it was warm enough to install it
Beecher
Old Dec 15, 2007 | 11:03 AM
PGT's Avatar
PGT
mine just snapped in. check the fittings...maybe pop one out and see how it works on the dash piece itself before reinstalling.
the only issues I had were getting that rubber piece back in place under the tack and the aluminum mount for the tach getting crossthreaded. luckily, I had a tap and die set to retap the holes and it went back in like new. be sure to get things lined up before reinstalling....aluminum isn't the best piece to thread into and it's easy to ruin the holes.
Old Dec 15, 2007 | 11:06 AM
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
I have installed a bunch of dashes.
The trick that I have noticed is that you start in the very drivers side corner. This will insure that the corner sits correctly and then you just push it in along the top edge and then finally the bottom.
I hope that this helps you with your problem.
blake
Old Dec 15, 2007 | 11:21 AM
Beecher's Avatar
Beecher
thanks guy, i will try both of them right now. Never thought of trying one with out the dash piece. You have any idea how hard it is to get those fitting off tho? haha. Mine arrived sans 2 of them, and i had to pry them off the old dash. they stick good on the dash, haha.
Beecher
Old Dec 15, 2007 | 11:54 AM
Beecher's Avatar
Beecher
done and done. thanks guy.
When i pulled it off one of the tangs stuck in the hole (the one i had to remove from the old dash actually). So i decided to pull the twothat i couldnt get in off, and stick them in the holes, and pried the one in the hole out and put it back on the insert. Lined it all up, gave it a couple wacks, starting in the upper drivers side corner, and presto, good and tight. looks amazing.
I have no idea how to resize pics to post them, so i will just put a pic up in my gallery. one of these days will have to figure out how to do that.
thanks again guys
Beecher
Old Dec 15, 2007 | 12:24 PM
PGT's Avatar
PGT
Old Dec 15, 2007 | 02:13 PM
Beecher's Avatar
Beecher
ah, thanks. wish it was a batter shot, tho. I will try to get a better one. did you basically just take that from the gallery, save it in its default size from there, and then post it? I never thought of that. It only occured to me because it looks like the same size as whats in the gallery. thanks alot PGT.
Beecher
Old Jul 22, 2008 | 07:08 PM
auscoops's Avatar
auscoops
Thanks to those who posted tips for the install!
I just completed my JCW CF 3 piece dash kit.
Old Jul 22, 2008 | 09:19 PM
Malcon's Avatar
Malcon
i REALLY had to push hard!
glad to know you got it in!
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
Chippawaguy
Aug 18, 2015 11:17 AM
