Interior/Exterior Will Skid Plate Hurt Engine Bay Airflow?
I'm about to install a Cobalt stainless steel skid plate to my '03 MCS. Living in Minneapolis and planning on some light winter use, it seems like a safe precaution. Also considering a M7 carbon fiber Air Diverter Plate. Keeping in mind how the M7 ADP helps divert airflow to the radiator, AC heat exchanger and engine bay, I'm wondering would the skid plate have a negative effect on any of this setup. Does anyone know? Or has anyone installed either or both? Ladies and gentlemen, your thoughts please...
Benson
Benson
Yeah..some have drilled bigger holes around the fan of the PS unit. I had the same plate on years ago but I took it off once I decided to lighten up my car. In fact, where the heck IS my skid plate?
It's in my garage somewhere...:impatient
I've been running my skid plate for 2 years & 30,000 miles. To be honest I can't tell if it affects engine bay airflow. My car doesn't run hot & I've had zero problems with the power steering. I really like the fact that my engines cast aluminum pan is protected from icebergs in winter & race track curbing in summer.
+1
Thanks.
What about changing the Oil? Will I have to remove my plate when dumping the oil? I just installed it a couple weekends a go.
Mario
Mario
You only need the PS fan cover on 02-04 models, I believe, right? It's mainly there to keep you from sucking plastic bags or paper into the fan and blowing the PS fan, right? My 06 had a fan cover pre-installed (IIRC)...
M
Get a Fumoto Valve. I've heard those with skid plates got the version with the nipple--where they put on a piece of hose to drain the oil from the valve through the skidplate. I've had a Fumoto Valve in both my MINI's with over 80,000 miles combined and no issues.
Richard
Richard
Thanks, I was thinking about buying a really nice system that sucks the oil from the dip stick. I have heard good things about certain ones. This would be perfect for me because of the plate, and the car being so low. I can't even put a floor jack under the car with out driving it on ramps first.
M
M
Richard
Richard
I have zero problems with draining the oil with the skid plate on. I'm not a fan of the Fumuto valve. One more thing to worry about breaking off. It's not a hardship to remove one 13mm drain bolt.
114,500 miles and counting with a SS Moss skidplate installed. Local temps range from below zero to 100F+. Never a problem, but the bottom of the skidplate is scared from occasionally being forced to run over something with a lowered car. Makes me happy it's there.
Scott
90SM
Scott
90SM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
05 & 06 MINI's already have a guard in place.
