Interior/Exterior Venting the Bonnet - A Unique Design
#103
#105
on
Out doing SID is a very worthy goal!! and you have done just that
sorry Sid.
#106
#108
on
new this would generate a post from you - SID
I can use the coal - I'm working on a coal fired mini project. So far the analysis shows it will blow Jan's efforts away !! I just have to figure out how to eliminate the coal car (think trains) because it does slow things down.
#109
I look forward to hearing more about your tuning options BahamaBart. Are they any cheaper than Jan's? heh heh
About the NACA ducting mentioned earlier:
From Wikipedia, the free encyclopedia
The NACA duct or NACA scoop is a common form of low-drag intake design, originally developed by the National Advisory Committee for Aeronautics (the precursor to NASA) in 1945. When properly implemented, it allows air to be drawn into an internal duct, often for cooling purposes, with a minimal disturbance to the flow. The design was originally called a "submerged inlet," since it consists of a shallow ramp with curved walls recessed into the exposed surface of a streamlined body, such as an aircraft. It is especially favored in racing car design.
Prior submerged inlet experiments showed poor pressure recovery due to the slow-moving boundary layer entering the intake. This design is believed to work because the combination of the gentle ramp angle and the curvature profile of the walls creates counter-rotating vortices which deflect the boundary layer away from the intake and draws in the faster moving air, while avoiding the form drag and flow separation that can occur with protruding inlet designs. This type of flush inlet generally cannot achieve the larger ram pressures and flow volumes of an external design, and so is rarely used for the jet engine intake application for which it was originally designed, (the North American YF-93 and Short Sherpa being exceptions.) It is, however, common for engine and ventilation intakes.
end wiki quote
EDIT: After a google search, it turns out you can buy NACA ducts of various sizes from racer parts wholesale. But money is a big issue right now.
end wiki quote
Last edited by nabeshin; 11-27-2007 at 03:17 AM. Reason: google, it is standard procedure.
#110
on
#111
#112
on
Getting closer!!!
Note the attention to detail. Primed and painted all the bits that can be seen through the grills matte black and have the bug guard from Bug guards for Beemers.
Bonnet is on, most of the trim in place. Another day of cleanup and the like... but for now.
A proper photo shoot will be forthcoming..have some other tricks up my sleeve first.
#116
#119
#121
#123
#124
#125
on
I never did any testing of underhood temps before the change so in the spirit of NAM I'm going to claim that it lowers the IAT's to ambient at all speeds, makes hair grow on bald men and chicks dig it.
Bob, frankly, this is a bling mod and any extra cooling is just a good thing. In theory that location is a low pressure spot on the hood and hot air should be drawn from under the hood.
If it was the bug guard you meant...well the water temps in day to day running around are teh same with or without. I did note that the water does reach it's high a little quicker, but not so much faster that it may just be a statistical anomaly. Running full bore on track on 100+ degree days the temp was on avg 7 degrees higher with the bug guard then without. But given the gauge has a an advertised +/- 2% range that may be just minor sensor fluctuation.
