Interior/Exterior How to: install lower grill (Aero Grill Kit)
This is why I'm getting tired of this board. Anytime someone new asked a question (that has admittedly been asked a thousand times) they get smart *** remarks and no real advice. Nice.
Whiteonblack, Yes it is a pain to do the lower grille but doable. Do a search above for Aero Grille or something similar and that should get you going in the right direction. I have a link to the install notes at home. If no one else chimes in, I'll try to PM them to you later.
Jason
Oh and welcome to NAM.
Jason
Yeah no need to be an *** when someone asks for help.
Here you go. https://www.northamericanmotoring.co...+grill+install
Two sides to this coin. Trolls are as old as the Internet, as are Newbies.
If you learn (quickly ;-) ) to search the forums you'll be much more readily accepted. Welcome to the "club" by the way. You'll have a lot of fun with your MINI and your new comrades.
As for the lower grill, another guy and I did ours at a "mod day" where everybody gets together at somebody's house, typically a guy who's mechanically inclined, and has tools to back up the know how, and there were a couple guys who had done this before so they helped us.
That's my recommendation, if like me, you're not that mechanically inclined. Get together with a group of MINI owners in your area, and have a mod day.
BTW, it's really not that bad if you take your time and pay attention.
Post pics once you have it done!
im not sure how helpful this is, but I tried doing both the upper and 'lower' (middle) aero grill installs on a stock MCS bumper...i had a bit of trouble so I just took the car to my local MINI collision center and had them install it for $75. They did a great job too...the lower grill is almost perfectly flush with the rest of the bumper and looks fantastic. See what your local service center or collision center will do for ya; might be worth the look and a few extra bucks.
If you have a Dremmel tool its quite easy. Pull off the old piece, hold up the aero piece to the bumper, put tape where the new tab holes need to go. Use the little cutter bit to drill out the tab holes and put on your new aero grill. Just be sure you have a steady hand and your new tab slots should be just wide enough for the new grill to lock in place.
whiteonBlack, where are you in Orlando? I'm relatively new to NAM too, so welcome! I'm looking to get involved in some things locally and meet some fellow Mini owners, so if you're attending any events or know of any easy ways to get involved, let me know! Sunshine Minis doesn't seem to be too active in Central Florida recently...
For aero grill on the aero bumper MCS or MC then it is very easy, just line up and snap/glue in place, then you're done.
For the Stock MC or MCS bumps the holes or slots for the stock grill do not line up with the pegs for the aero grill hence you will have to cut the pegs and trim or modify the slots so that you can make the two pieces match. Then the grill will be flush with the surface of the front bumper, if you do not cut and trim or dremmel then the grill sticks out about 1/8" and is not flush. I have seen it done both ways and I like it better flush.
I did the top grill myself and had a body shop do the lower grill, they took off the bumper and took a very long time trimming and glueing. You also have to paint black the area behind the lower grill so that it looks good as you can see through the grill and see the bumper color.
squawSkiBum
10-02-2015 09:21 AM
