Interior/Exterior Post pics of your shift knobs
Old 09-26-2007, 12:14 PM
minipooper02's Avatar
minipooper02
minipooper02 is offline
Post pics of your shift *****
Post some pics of your shift *****! I would love to see some mini's with pool ball shift *****.
Anyone have any knowledge of these people? http://thehotrodgirl.com/8ballshifter.html
Old 09-26-2007, 12:56 PM
03Indigo's Avatar
03Indigo
03Indigo is offline
User Title's are Silly
Whalen Yin Yang ****
whalen #10 and I also have a #2.
I have seen that site before, but never looked into their products. Can't imagine that they would be all that bad, and for the price, you really can't go wrong...if it does not work, you will have a great paper weight
Old 09-26-2007, 01:00 PM
ImagoX's Avatar
ImagoX
ImagoX is offline
I used the Hot Rod Girl pool ball shifter you linked to... Paid $15. Simply can't be beat.
NOTE: The rubber bootie thing that you get with the pool ball doesn not fit the very thick shaft used in the MINI... Just get a tube of silicone caulk (about $5 at Lowe's) and fill the hole about 1/3 full of goop. Mash ball onto shaft and allow to dry overnight. Mine went over a year before it loosened up - a quick re-application solved the issue. To me, that's worth the drastically lower price tag over the Whalen, but some will disagree (shrug).
ALso note that I have the leather shift boot pulled down in the pic to show the attachment point - the cover still pulls all the way up to the ball for everyday use. Great heft and size in the palm but BE WARNED: garages, valets and others that are unfamiliar with a 6-speed car will not be able to find "Reverse" without help since the shift-pattern diagram will be missing, so get in the habit of showing people where reverse is when you hand over your keys. This applied to ANY aftermarket **** w/o the shift pattern on it.
Old 09-26-2007, 01:05 PM
minipooper02
Originally Posted by ImagoX
Hot Rod Girl pool ball shifter... Paid $15. Simply can't be beat.
Can you explain to me what they come with to put it on.? how big is the hole. I see that yours sits up far on your shifter. Could you not fit it on that lower knotch on the shift stick. thats what i would do. Just cut it down some.
-ALSO....is it an actualy pool ball? size/ weight?
throw me the details man! thanks!
Old 09-26-2007, 01:10 PM
03Indigo's Avatar
03Indigo
03Indigo is offline
ImagoX's only looks like it is sitting high becuase of the lack of the fitting like on the Whalen. If you undo the boot, and raise it over the notch, it will look less high, or less of the shaft showing.
here is the boot on the Whalen...and yes, much more expensive, not for everyone, but it comes down to personal preference. Both are great options depending on your budget.
ImagoX's Avatar
ImagoX
ImagoX is offline
It comes with a rubber peice that's meant to friction-mount the ball to a round shifter rod shaft, but that rubber boot is fitted for classic cars wit a more slender shaft. The ball really isn't any higher on the shaft than the stock one - it's an illusion caused by me having the leather shift boot pulled down. I have it pulled up over that "collar" beneath the shift ball for everyday use - I just pulled it down while I was installing the ball.
If you use silicone goop to attach it, the goop will fill the "notch" and keep the ball from moving. If you need to remove it ever, a spirited twist (about as hard as you need to use to remove the OEM ****) will tear free the silicone, allowing you to re-install the stoock ****.
And yes, it's a real pool ball.
Whalen mounting hardware IS awfully, awfully nice, don't get me wrong. It's just too rich for my blood for a simple ****, sorry...
Old 09-26-2007, 01:19 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
I designed this new shift lever and asked Doug Whalen to fabricate a prototype for me...it's was a bit too tall for me and on it's way back to be shortened 15mm...
I did try it out and shifting is no longer a vague excersise for me...
Greatly improved shifting speed and precision!!!
Doug mentioned that he may be adding this design to his product line up in various materials including Delrin...mine will remain brushed aluminum as my choice...
Old 09-26-2007, 01:27 PM
03Indigo's Avatar
03Indigo
03Indigo is offline
here is a shot of the black version of that shifter
and here is a brass and abalone version he is working on:
golden_child's Avatar
golden_child
golden_child is offline
Coordinator :: Capital Area MINI Modders
I was wondering when he would start to produce shifters like this. Niiiiice.
Old 09-26-2007, 01:28 PM
golden_child
That's the one I want!
Old 09-26-2007, 01:41 PM
k-huevo's Avatar
k-huevo
k-huevo is offline
UUC and extension
Old 09-26-2007, 01:46 PM
03Indigo's Avatar
03Indigo
03Indigo is offline
he is also working on a black round one Derlin I believe
Old 09-26-2007, 02:31 PM
Mr. D's Avatar
Mr. D
Mr. D is offline
Nice looking interior upgrades
Old 09-26-2007, 03:09 PM
Jahmills's Avatar
Jahmills
Jahmills is offline
MSFITOY, what is the advantage of the cylindrical design as opposed to the standard sphere?
Old 09-26-2007, 03:17 PM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
For me personally, it feels much more precise with my fingers wrapped around it like a bat...during quick shifts from 1-2, my fingers sometimes slip off the ball causing a miss-shift...so I tend to pause between the gate...not anymore...sides, if the design's good enough for C6 LeMan racers, it's good enough for me...
Old 09-26-2007, 04:25 PM
vdubdoug's Avatar
vdubdoug
vdubdoug is offline
here is my 2 ball shifter that fits perfectly on the shifter
Old 09-26-2007, 04:42 PM
ChrisMCS04's Avatar
ChrisMCS04
ChrisMCS04 is offline
Peace Keeper
^Very Nice! I really like your shift boots.
Old 09-26-2007, 04:56 PM
kgdblu's Avatar
kgdblu
kgdblu is offline
Old 09-26-2007, 04:57 PM
hemiheaded18's Avatar
hemiheaded18
hemiheaded18 is offline
Yeah, where can I get a plaid shift boot? Hmmm, dark green with either black or white accents...
Old 09-26-2007, 06:44 PM
03Indigo's Avatar
03Indigo
03Indigo is offline
Originally Posted by kgdblu
That is an awesome idea....very personalized. I like it
Old 09-26-2007, 07:01 PM
jimz68's Avatar
jimz68
jimz68 is offline
This was made for me by a (now late) friend for my Nissan. It's now on it's way to Whalen to be modified to use his connecter.
Still may get the Black Delrin, though!
Jim
knob1.jpg?t=1190858349
Old 09-26-2007, 07:57 PM
minjae's Avatar
minjae
minjae is offline
man..now i gotta choose from the cylinder shape and ball shape.
i'll probably end up gettin both.
the leather on my stock one is wearing out slowly.
Old 09-27-2007, 03:14 AM
vdubdoug's Avatar
vdubdoug
vdubdoug is offline
Shift and e brake boots are custom made by a friend. Pm me for details
Old 09-27-2007, 04:13 AM
MSFITOY's Avatar
MSFITOY
MSFITOY is offline
My ball is going up for sale as soon as the cylinder comes in...
edit...SOLD!
Old 09-27-2007, 10:51 AM
capnmini's Avatar
capnmini
capnmini is offline
I really like that preppy look it gives your car
Quick Reply: Interior/Exterior Post pics of your shift knobs
