Removing Rear "Vents" from MCS Bumper
Subscribe
Aug 27, 2007 | 06:00 PM
Does anyone know how to remove the black, plastic "vents" from the bottom of the rear MCS bumper? I tried using a credit card to find tabs (like when removing the cowl vents), but I didn't have any luck.
If you have removed them, what does the bumper look like without them? I think it might look better without the vents, but figure there could be conspicuous holes left from the tabs.
Reply 0
Aug 27, 2007 | 06:07 PM
mine shows the ugly shiney heatshield film...i need to get unlazy and paint it black to hide it better.
Reply 0
Aug 27, 2007 | 06:51 PM
Not that greatest pic for showing what you want. But with the Aero rear I cut out the openings and installed grill mesh instead. I painted the rear heat shield black, but I will eventually remove it when I do a exhaust system.
Reply 0
Aug 28, 2007 | 08:37 AM
There are 4 tabs towards the corners, at least I from what I remember it's been a while since I worked on them. But they pop inwardand then you can just pull them off. I used tin snips to cut the exhaust heat shield down so that it didnt show through the vents when I was done with them. It's quite easy. And don't worry about breaking the tabs on the vents, I wrecked one and bought a replacement from the dealer for $10, so they are not that expensive.
Reply 0
Aug 28, 2007 | 09:14 AM
Thanks, folks. I was hoping the regular MCS bumper would be the aero kit and that there would be a flat, body-color panel behind the vent. I guess I'll leave 'em in.
Reply 0
Aug 30, 2007 | 09:35 PM
I think m7 has cool-looking "Ultimate" rear grilles to match the fronts they offe (available in black or silver powdercoat).
Reply 0
Sep 3, 2007 | 10:30 PM
PUSH ... just a bit more. They will come out.
I trimmed the heat shield and added mesh
Reply 0
Sep 4, 2007 | 09:32 AM
PhysicsGeek and CorBlmy --
how did you attach the screens to the inside of the bumpers?
Reply 0
Sep 4, 2007 | 12:31 PM
I very carefully cut the mesh at the OEM tabs so that they "hook" onto those tabs.
The mesh is about 1 inch larger than the hole.
I can do this mod without removing the rear bumber
Will try to take a close-up photo for you
Reply 0
Sep 4, 2007 | 01:23 PM
Your only the second car iv'e seen with that rear bottom spoiler. Fracky from my city has one too .
Reply 0
Sep 4, 2007 | 02:51 PM
Reply 0
Subscribe
