Interior/Exterior help needed ASAP!
help needed ASAP!
hey everyone
i was in the midddle of trying to do a rear wiper delete.. i had everything ready to be removed ! the only thing is stopping me is disconnecting the motor to the blade! its PITA to remove! i need advice or tips how to remove it.. wats needed etc... and wat should i use to plug the small black tubing!!!! pls let me kno ASAP!!! thnx
ace
ace
I did the wiper delete and did not have any problem with taking the wiper off the motor. I did that before even opening the interior panel.
Take the wiper arm off from outside.
Take interior panel off the boot.
Unbolt the wiper motor.
Pull sprayer line off, unplug wiring.
Put a screw with adhesive on the screw in the spray line.
Put a 1" or 1 1/8" plug in the hole, with adhesive to seal.
Put the interior panel back on.
It took me about an hour tops and I had never done or seen this mod before.
It should not be hard, just a simple disassemble.
iwant2knowwhois
11
Sep 19, 2015 12:18 PM
Rennfahrer555
Aug 13, 2015 09:07 AM
minipopkart
Aug 13, 2015 05:22 AM
Aug 12, 2015 01:24 PM
