Interior/Exterior Autometer Gauges - Help
Old Jun 3, 2007 | 09:42 AM
Larry Clemens's Avatar
Larry Clemens
I have a 2005 MCS with the chrome package. I plan to buy Autometer boost and oil pressure gauges.
1. Which gauges best match the OEM Tach look and lighting? Is it the Ultralite 11 model?
2. Does anyone know if they are available with chrome bezels? If so, which vendor(s)?
Thanks a bunch
Old Jun 3, 2007 | 12:28 PM
El_Griton's Avatar
El_Griton
autometer gauges have pretty bad lighting. I took out the bulb that comes in it and replaced it with a orange led that matches the tach and speedo really nicely.
Old Jun 3, 2007 | 12:48 PM
kapps's Avatar
kapps
There really aren't any gauges that match the stock one's perfectly. The Autometer Ultralights match the stock color in the daytime but are lit from around the edge (instead of through the ticks) so they don't match at night. There are other gauges that match at night (like the one's Stoopidgirl is selling) but don't match during the day.
I chose to use Stewart Warner maximum performance gauges. They are the closest match to stock gauges I've seen. The grey background is very close and illumination is done around the edge of the gauge (like Autometer) but also through the numbers and ticks. The only thing that doesn't match is the actual swing dial. The SW one is not lit while the stock one's are. This makes it a little hard to read at night but it's not too bad. The main thing you have to do is replace the incandescent bulb that comes with the gauge with the Stewart Warner amber led upgrade. They run $15-$20 a piece but this matches the stock lighting nearly perfect. These LED's are a little bit dimmer than stock but I used the one's meant for gauges. I wonder if the one's for tachs and speedo's would be better.
Old Jun 3, 2007 | 02:35 PM
meh's Avatar
meh
Thanks a bunch
I used the following from Ebay
http://cgi.ebay.com/ebaymotors/SPLIT...spagenameZWD1V
Old Apr 27, 2008 | 03:22 AM
MINIdriver85's Avatar
MINIdriver85
I was wondering, do you think the orange leds would match the OEM look or not? And, where did you buy the guages and the leds?
Old Apr 27, 2008 | 04:42 AM
Bahamabart's Avatar
Bahamabart
The SW can be purchased via summitracing but I did not see a LED upgrade.
I too would like to know where he got the LED for the SW as well. perhaps a part number.
Old Apr 27, 2008 | 05:38 AM
MINIdriver85
I found the SW leds on summit racing, but only the orange ones, not the amber ones...
Old Apr 27, 2008 | 06:02 AM
Bahamabart's Avatar
Bahamabart
thks, found them. I saw orange and amber available.
I'm wondering if they put out more light than the bulbs?
bahman
Feb 14, 2016 10:29 AM
Doc Pain
Oct 28, 2015 07:09 PM
Snotrocket555
Oct 1, 2015 08:59 AM
papawhiskey
Sep 30, 2015 02:50 PM
aldito2
Sep 30, 2015 10:44 AM
