Interior/Exterior Lamin-x tailights anyone?
Old Aug 14, 2007 | 10:53 AM
  #51
Loony2N's Avatar
Loony2N
Yeah, those lights don't look that curvy until you do this. Looks great!
Old Aug 14, 2007 | 11:13 AM
  #52
thlaxx's Avatar
thlaxx
thanks, i know exactly what you mean, i was shocked when i got upclose and tried to lay the flat tint over it...haha
Old Aug 14, 2007 | 01:13 PM
  #53
familiarstranger's Avatar
familiarstranger
if i was to do it again. and i may. i would remove the chrome surround (just use a flat head screw driver from the inside out) that way the film can just go under it. no cutting or anything required.
Old Aug 14, 2007 | 01:18 PM
  #54
Loony2N's Avatar
Loony2N
cutting? what cutting is required?
Old Aug 14, 2007 | 02:51 PM
  #55
familiarstranger
i had to trim just under my application tabs on each side
Old Aug 14, 2007 | 05:32 PM
  #56
thlaxx's Avatar
thlaxx
yea me to, and a little bit where i was a little off just to touch up
Old Aug 15, 2007 | 08:24 AM
  #57
thlaxx's Avatar
thlaxx
i sitll have a couple bubbles and places where bubbles where and there noticeable. do they go away? and also, at the top and bototm of the lights i have a couple ridges. should i use a blow dryer to flaten that out?
Old Aug 15, 2007 | 10:59 AM
  #58
familiarstranger
thlaxx i am in the same position. i popped some of the bubbles but am bummed about the ridges. i dont know what to do. i will try the blowdryer
Old Aug 15, 2007 | 07:03 PM
  #59
thlaxx's Avatar
thlaxx
i got most of the ridges down with a blow dryer, i think i MAY need to apply a small amount of adhesive, bc i peeled it up from the edges a couple times so maybe it lost some sticky-ness. but the kinda deflated bubbles and some little bubbles in the main part, im wondering if itll be like my tint and i need to jsut give it a week. it looks great from a stnading distance away though!
Old Aug 15, 2007 | 08:39 PM
  #60
familiarstranger
i am with you there thlaxx. i may add some adhesive to just kind of keep it there. we will see. give it some time
Old Sep 20, 2007 | 05:12 AM
  #61
Loony2N's Avatar
Loony2N
I give up!!!!! Despite having successfully applied Lamin-X to my tail lights, rear fogs and arch lights, and despite 3 separate attempts, I cannot get Lamin-X to stick to my right side side turn indicator (the clear oval lens by the "S". The driver's side sticks perfectly. I have cleaned it with adhesive remover, alcohol, etc. and it will just not stick! I think I will just remove the lenses and spray paint them from the inside.
Old Sep 20, 2007 | 05:25 AM
  #62
edubledie's Avatar
edubledie
i was able to get the curves of the side indicator and have the lamin-X stick by using a heat gun a blowdryer gets nowhere near as hot as it needs to be to fully wrap the lamin-x around hard curves ...if you do it with a blow dryer ( low heat ) the lamin-z will end up pulling back and not sticking
Old Sep 20, 2007 | 05:37 AM
  #63
Loony2N's Avatar
Loony2N
It stuck everywhere except the right side signal. I'm not going to buy a heat gun just to get the POS on.
Old Sep 20, 2007 | 07:47 AM
  #64
edubledie's Avatar
edubledie
hmm thats weird that it stuck everywhere except that .....a thing i learned when i did all mine and peeled them off numerous times is when you get it really hot ( like with a heat gun ) then it gets the film super sticky again but yeah i have a heat gun at my house that i dint buy my brother did so yeah i wouldnt buy one either but i hear they go as low at $20 and theyre a good handy thing to have at times .
Old Sep 27, 2007 | 09:55 PM
  #65
indy82799's Avatar
indy82799
I picked up a HarborFreight heatgun on sale for $9.99. Its not the best quality but to ensure a perfect install once or twice... the 10 buck was worth it.
http://www.harborfreight.com/cpi/cta...emnumber=35776
Old Jan 21, 2008 | 01:40 PM
  #66
jblaw's Avatar
jblaw
This may be a silly question, but is this removable?
Old Jan 21, 2008 | 02:09 PM
  #67
glnr13's Avatar
glnr13
yes. theyre basically stickers. thick, heavy duty, and durable
Old Feb 6, 2008 | 02:32 PM
  #68
soul embrace's Avatar
soul embrace
i'm having problems getting most of the lamin-x tint to stay stuck down and i need help.
the rear lights tint, fog light tint and one headlight tint will not stay stuck down for nothing. the only ones i'm not having a problem with is the side lights on the fender flares and that's because it's a flat surface. i almost pulled the rear off today and i the fog lights will be coming off too. so far i think i wasted my money on this product and i had a tint place put them on so i know it was done right. it was around 70 degrees out yesterday when they got installed so i don't think that's the problem.
you can see in this picture where it's coming off on the right light (on the bottom corners)
the left one is coming off on the top corners.
i almost pulled the taillight tint off this afternoon, the left one looks worse than the one in the above picture and the fog lights look light crap also. i sent lamin-x an email asking what i should do and i wanted to ask you all also. as it stands right now i do not recommend their products unless all you want is the tint for the lights on the fender flares.
need help cause i'm probably going to pull most of it off tomorrow and just take the lose. sad thing is i love how my MINI looks with it on.
thanks for any help you can give me
Old Feb 6, 2008 | 03:11 PM
  #69
Auto Paint Guard's Avatar
Auto Paint Guard
Hello. If there is any dust or dirt under the film you will not be able to lay it down. If it is clean still use water/alcohol solution and then use a hair dryer to press it out. It may take a few minutes to do so.
Old Feb 7, 2008 | 01:27 AM
  #70
ghosthound's Avatar
ghosthound
get a heat gun from harbour freight. They are like 10 bucks and work perfectly for such things.
UKDragon
Dec 27, 2007 07:54 AM
jerjer
Sep 22, 2006 09:45 AM
Pat W
Jun 17, 2006 07:07 AM
Pat W
Jun 16, 2006 10:33 PM
