Interior/Exterior Brake duct install...
#26
Cool but, the rigitity of the Modular Front End (the composite thing you cut into) is severely comprimised. Several procedures (oil pan removal, clutch/trans work, etc.) call for the MFE to be slid forward on long bolts, it needs all its rigidity to prevent collapsing in on itself. However, if you wanted, you could just remove it for any job in the future.
Do you really notice brake fade often? I have a hard time getting mine to feel faded. They hold temp well and really bite when warmed up.
#27
No brake fade...but every small advantage counts...it's not for everyone...
#28
Had to jump in since I didn't see this answered, ... the jack stands are Torin Big Red
http://www.northerntool.com/webapp/w...3386_200313386
They are very sharp looking. I used mine once and the problem I had was that they are not wide enough for the jackpoints to sit completely on the jack stands 100%. You only get one side on. To work around that problem I cut small blocks of wood that go into the jackpoints and fit perfectly on the jack stands. Haven't used them yet to get the whole car up in the air because I only have 2 stand, but I just ordered 2 more.
I went with the stands becuase other stand would have dug into the blacktop on the drive way (the only place I have to work), and these didn't dig in.
ok, back on topic ... Very nice brake duct project!!!!
#29
#30
Just waiting for the new splitter standoffs to arrive tomorrow...they'll be attached to the frame this time and come out where the driving lamps used to be through the two holes in the grill...
Need to fix the rust in the tow hook Everything fit perfectly...the tire clears the ducts no problem throughout it's travel envelope...I blew air through the ducts and it comes out strong against the brake rotors...more tomorrow...
#32
#35
on
Way just got to Atlanta and I forgot to ask him before I dropped him off. I'll remind him to get you the info in the morning.
BTW, with those ducts your car looks like it's ready to suck anything in front of it up like a vacuum cleaner. So hawt. I'm jealous again.
#37
on
now MSFITOY, will you please tell me where you gots those mirror plates, where they fit to the door? or did you make them?
I want those lights if you sell them, with or without the harness. they are the HOTTNESS!!!
vbmenu_register("postmenu_1517386", t
#41
#43
Misfitoy,
did you have to remove any aluminum bumper reinforcement to get the duct to fit?
Also, what is holding the actual "air ducts" in place near the "exit" point?
Gonna give Way a call and order the ducts for my track car.
I know from just removing the fog lamps, cutting a 3" hole in the wheel well and installing a short piece of tubing in there will decrease my BBK rotor temperature by 140°f.
Thanks in advance,
kmicey
I hope you don't mind me posting your PM question here so I can answer them for everyone...
A small corner of the aluminum bumper structure needs to be trimmed to clear the funnel of ram intake...this will be self evident when you start the install...cutting this tiny amount of extrusion at the ends of the bumper will not affect the integrity at all...
The duct front is held against the ram intake via a slip fit and the rear of the duct is ziptied to the fender liner...
I'll take a photo later today and come back...
Sid
Thanks in advance,
kmicey
Sid
#44
#45
#49
They don't just bolt right up the the aero bumper just yet. Gnatster is having his mated to his aero kit and said he would post results. Although, waylen also said that he was working on sets for the aero kit and they would be available soon.
