R56 & R53 custom gauge faces
Old Feb 24, 2008 | 11:47 AM
  #51
<MINI>'s Avatar
<MINI>
Originally Posted by rkw
It pulls right off and you just have to be brave about applying enough force. You may need a thin screwdriver to help pry it off the pin. Some instructions and photos here: https://www.northamericanmotoring.co...d.php?t=129178
Would be great if you post pictures mounted in the car, both lit up and not.
I checked those instructions, but the R56 seems to be different. I think Lyle is right, it just pulls off without the need for tweezers. My fingers HURT!!
As far as calibrating goes, the needle stops at zero, even though there is no external stop, like older cars. This one must be internal. So If I pull the thing off near zero, I'll put it back on at zero and see what happens.
Also, I had to take apart much more than I thought I was going to have to. The speedo is attached to the CD player and must come out together. Therefore, the whole center must come apart, including the cupholder/console to allow room for the vertical section to move around.
The color line must be removed (the section w/ the key) and the glove box side must be loosened at the center, but not removed, to allow the speedo/CD to silde out a bit.
I'll post some more step-by-step stuff when I'm finished. "Finished"...at least I'm optimistic!
Old Feb 24, 2008 | 12:28 PM
  #52
rkw's Avatar
rkw
If it's like the 1st gen, there is no physical stop and the needle zeroes when the gauge receives power. So reconnect the gauge first, then insert the needle.
Old Feb 24, 2008 | 02:52 PM
  #53
<MINI>'s Avatar
<MINI>
Here's some shots of the speedo...I still can't get the needle off the tach!
The Piano Black pieces around the climate controls came from Aesthetic Creations.
Old Feb 24, 2008 | 03:21 PM
  #54
kyriian's Avatar
kyriian
maybe i missed the post, but any chance of doing a km/h version for those of us north of the boarder?
Old Feb 24, 2008 | 03:44 PM
  #55
MUNGO's Avatar
MUNGO
Do they make a overlay for the nav? I wonder how hard it would be to disassemble.
Old Feb 24, 2008 | 04:13 PM
  #56
Vinyl Styles's Avatar
Vinyl Styles
Robb - That looks awesome!!! - PM replied
Kyriian - We do not have a template for the km/h version. If you would like to send us your guages we would be glad to hook you up with a set of overlays.
Octo - We don't have a template for the NAV speedo either. If you want to send them to us, we can make a template for ya!
Old Feb 24, 2008 | 04:19 PM
  #57
MUNGO's Avatar
MUNGO
I need to find a junk yard w/ R56 parts!
Old Feb 26, 2008 | 01:35 PM
  #58
<MINI>'s Avatar
<MINI>
It's all finished. More pics are posted in the "CF gauges" thread (post #44)found here:
https://www.northamericanmotoring.co...26#post2060426
As someone else stated, these threads should all be combined.
Thanks Vinyl Styles! I LOVE the inside of my car now!
Old Feb 26, 2008 | 01:42 PM
  #59
Vinyl Styles
Man Robb!! Those look soo sweet with your piano black dash.
Your right, from those pics, it doesn't look like daytime visibility will be an issue.
Sorry about the gauge threads all over the place, I get a little excited sometimes
Mods - Can you combine these threads?
Lyle
-VS
Old Feb 26, 2008 | 08:19 PM
  #60
Minidrivr's Avatar
Minidrivr
Very nice!
Old Feb 27, 2008 | 08:22 AM
  #61
Vinyl Styles
Chrono gauge overlays
We are putting the finishing touches on the overlays for the 05-06 MINI's with the chrono package.
We are pleased with the results and hope you will be as well.
These will be offered as overlays, or overlay w/ adhesive backing.
Pricing to be determined. As always, many color combos and customizations available.
Enjoy.....
^ Gloss black ^
^ Gloss black w/ Chili red gas gauge ^
^ Gloss black w/ Liquid Yellow gas gauge ^
^ Gloss black gauges and chrome ring blackout w/ Chili red gas & temp gauge, and border ^ phweew!
These are our test runs, so the 0's will be filled in and other small imperfections you may see have been corrected.
Old Apr 12, 2008 | 08:57 PM
  #62
Vinyl Styles
Nav gauges w/ colored border
Old Apr 15, 2008 | 07:54 AM
  #63
VicSkimmr's Avatar
VicSkimmr
o rly?
Old May 15, 2008 | 12:13 AM
  #64
Cooper_Si's Avatar
Cooper_Si
Wooo i like these faces. not sure on the dark ones, like people have already commented, but them chrono pack faces are cooooool !!
I thought id also chime in on the needle replacement for the R56. Of course ive been working on the dash lighting for the first blue/white R56 dash lighting that i know of in the UK (i started September last year i think on the project) and the needle is becoming abit of a pain in the side.
It takes some force to come out, and is nothing like the gen 1 style MINI. The needle comes out of the speedo face along with the spindle and no matter what i do to replace it, it ends up in a different position. Even with ignition on then replacing, it just seems to go out of alignment.
Of course more time and research will highlight what needs to be done, i just wanted to tell you all to be careful when removing the needles.
Old May 17, 2008 | 06:58 AM
  #65
StarryEyed's Avatar
StarryEyed
Can you make ones for R56 with nav??? or not possible?
Old May 19, 2008 | 10:24 PM
  #66
Vinyl Styles
We do not have the template for the 07+ Nav gauges yet. If you'd like to send us the nav gauge, we would be glad to send you a set free of charge.
Old May 20, 2008 | 09:13 AM
  #67
StarryEyed's Avatar
StarryEyed
You just let me know when you do finally make one and I'll get one! I'd love a set that's black and hot pink
Old Jun 24, 2008 | 09:25 PM
  #68
joshamman's Avatar
joshamman
sorry to revive this, but its the first time i've seen images of faces for the chrono pack folks.
One question do the numbers have to be cut out? Is there anyway to just to a 100% new overlay (black face with white numbers) or will it prevent light from making it thru at night?
I'm dying to black out my gauges.
Old Jun 26, 2008 | 05:22 PM
  #69
minicoaster27's Avatar
minicoaster27
Aw no R50 love , I love the CF, Black and Blue gauges, they look awesome!
Old Sep 29, 2008 | 01:24 PM
  #70
Red Bull's Avatar
Red Bull
Nice....I am in for a set of dark grey as soon as I get my JCW in 4-6 weeks.
Old Sep 29, 2008 | 09:00 PM
  #71
roadrage1's Avatar
roadrage1
Think I'm in for a checkered set!
Old Oct 1, 2008 | 07:00 PM
  #72
Vinyl Styles
Ooo, haven't done a checkered set yet. We may have to throw a black border around the numbers so it helps visability.
Old Oct 1, 2008 | 07:13 PM
  #73
roadrage1's Avatar
roadrage1
Any chance of seeing a picture after you do a set??? They look good, they're mine!
Old Oct 8, 2008 | 03:30 PM
  #74
Klasse Act's Avatar
Klasse Act
I think the satin black looks great, good job
Old Oct 8, 2008 | 09:16 PM
  #75
ZJedi945's Avatar
ZJedi945
Do you happen to have a set kinda-almost-the-same as the GP's gauges?
