How To Suspension :: MCS Spring Install How-To (with big pics)
Old Jul 10, 2006 | 05:40 AM
  #51
jymontoya's Avatar
jymontoya
Where'd all the pics go in these Howto Threads? :(
Old Jul 10, 2006 | 05:58 AM
  #52
etalj's Avatar
etalj
ditto
Old Jul 10, 2006 | 01:13 PM
  #53
polizei's Avatar
polizei
Ditto #3!
-Cody
Old Jul 14, 2006 | 03:58 PM
  #54
UKCoopeR's Avatar
UKCoopeR
i want pics too.....
Old Jul 14, 2006 | 05:50 PM
  #55
FUEGO's Avatar
FUEGO
When I replaced my stock springs with M7 Sport springs Wednesday nite I had no problem removing the driver's side front strut assembly to replace the spring without removing any 'extra' parts. However, the passenger side was a bear. I finally had to compress the spring to get enough of a gap to get the bottom of the strut out of the clamp.
A pair of ratcheting strap (tiedowns) worked extremely well for this task and gave me enough clearance to manuever the strut out of the carrier. Once the shorter springs were installed I had not problems putting both back in place. The straps also made the spring compression to take the tension off of the top plates very easy. A pair of straps in the shortest length you can find is only about 1/2 the price of threaded spring compressors and you don't run into clearance problems. I wish I'd taken pics but I was on a mission to get them done by 11 PM
Old Jul 17, 2006 | 05:31 PM
  #56
jymontoya's Avatar
jymontoya
Where do you get these tiedowns?
Old Jul 29, 2006 | 02:22 PM
  #57
polizei's Avatar
polizei
Any tiedowns will work. You can pick them up at Home Depot, Lowes, Pep Boys, etc. They are just normal rachet straps used to hold down ATV's, Boats, etc.
-Cody
Old Aug 14, 2006 | 01:32 PM
  #58
fluidsoul's Avatar
fluidsoul
With spring rates >200lbs/in, the basic tie down straps would be quickly passing their load rating with a couple inches of compression. Anybody ever snapped these? Perhaps the extra $5 a strap for the 1000lb load rating would be worth it... or use more than two to distribute the force.
Old Aug 14, 2006 | 03:11 PM
  #59
SCMCS's Avatar
SCMCS
When I saw Randy Webb do a spring install he didn’t use ANY tie downs or spring compressors. All he did was to lean on the springs and remove the nuts. When it was time to install the new springs all he did was to have Brian push down on the spring so he could get the nut started.
I’m not saying this would be the recommended way to do a spring swap but it appeared that there was not much tension on the springs so any good size tie wrap should be more then strong enough to use.
Old Aug 16, 2006 | 10:50 PM
  #60
fluidsoul's Avatar
fluidsoul
'aight. Just trying to think through things... My old motorcycle springs had a ridiculous amount of preload. Doing my first car spring install tomorrow. I've only seen it done with dedicated compressors.
Thanks. :-)
Old Aug 17, 2006 | 05:33 AM
  #61
k-huevo's Avatar
k-huevo
For the MINI, once the struts are off the vehicle, springs can be removed without a spring compressor tool. Putting stock springs on is more difficult and it helps to have someone else lean on the top hat while the nut is started; shorter springs are easier still, coilovers are a breeze. Physical capabilities or limitations should be considered before attempting tool-less spring compression; this is not an endorsement.
I tried it one time alone and it convinced me to rent a hook & bolt type spring compressor for the next install; that install encouraged me to purchase a free standing spring compressor, the most convenient way to change springs by far.
A method for retaining spring compression while the driver’s side strut (some find the passenger side harder) is on the vehicle will still be needed, unless you are the fortunate few that don’t require this procedure. Be prepared with either endless loop tie-downs, strong zip-ties, or the stick (post #48).
Old Aug 17, 2006 | 05:49 AM
  #62
DrumMonkey's Avatar
DrumMonkey
I just rented a spring compression tool from Auto Zone for free. They charged me $40 up front to get it, then gave me a full refund when I returned it the next day.
Old Aug 22, 2006 | 08:17 PM
  #63
erickvonzipper's Avatar
erickvonzipper
What happened to all the pics in this thread?
Old Aug 24, 2006 | 07:40 PM
  #64
1QKMNIS's Avatar
1QKMNIS
Bump for pics coming back.
Old Sep 2, 2006 | 11:58 PM
  #65
fluidsoul's Avatar
fluidsoul
So yeah. I don't like tie down straps... not so easy to release without near death experiences... I work alone, so no burly friends. A little bit of compression was all I needed. Thanks all.
Bump for the pics too, even though I know the procedure by heart now.
Old Apr 24, 2007 | 02:05 PM
  #66
supercliff's Avatar
supercliff
Pictures seem to have been all deleted. Can someone repost them?
Old Apr 24, 2007 | 03:07 PM
  #67
k-huevo's Avatar
k-huevo
Not the same how-to, but this one has working photos https://www.northamericanmotoring.co...ad.php?t=92737
Old May 15, 2010 | 04:18 PM
  #68
hwy74's Avatar
hwy74
Bring the Pics back, PLEASE. I am going to do this install soon and, from all of the posts, it looks like it is super helpful
Old May 15, 2010 | 05:30 PM
  #69
twoturbos1mission's Avatar
twoturbos1mission
For anyone interested, a friend in the know asked me to re-upload the photos, I finally found them in the depths of my hard drive so... I hope the pictures help any aspiring DIY'ers from this point on. Sorry for my extended hiatus ;-)
Old May 16, 2010 | 01:19 PM
  #70
hwy74's Avatar
hwy74
Thank you twoturbos1mission! Pictures make things make sense for me. I am way too visual.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
squawSkiBum
Oct 2, 2015 09:21 AM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
