How To Drivetrain :: Change Your Own Chain Tensioner
Old Nov 7, 2015 | 05:13 AM
  #176
gjxj's Avatar
gjxj
From the TIS: N14 Engine
8. Install the locating pin (Special Tool 11 9 590) to lock the position of the engine. 9. Remove the chain tensioner and collect the residual oil with a shop towel.
does the service bulletin say to lock the cams? (in steps 1-7...)?
that first tool just looks like you could use any suitable size rod,corect?
edit here is the fullservice bulletin http://minideathrattle.weebly.com/uploads/2/8/0/6/28063917/bulletin_si_m11_02_07.pdf
answer no, the tsb does not say to lock the cams.
Old Nov 9, 2015 | 07:27 AM
  #177
Originally Posted by sub3622
Thank you very much ECS
Welcome.
Old Nov 9, 2015 | 08:42 AM
  #178
Lex2008's Avatar
Lex2008
Lex2008, mine has 53K but I already install the new chain tensioner about a month ago.
Hold it, you already changed the tensioner? Was it making noise when you changed? I assume so and under warranty yes? how many miles ago was that?
Old Nov 9, 2015 | 11:34 AM
  #179
sub3622's Avatar
sub3622
Tensioner bolt was changed 100 miles ago.
It was starting to make noise. After install noise was completely gone.
No warranty its 2008 and dealer here is a vaccum machine for money.
Did it myself with no issues.
Old Nov 9, 2015 | 01:47 PM
  #180
Lex2008's Avatar
Lex2008
Oh I see. ok so now you're wanting to change the tensioner as well. Might as well do the chain and chain guides while you're at it. no?
Dude the markup on parts at the dealer is obscene beyond imagination. I feel ya.
Old Nov 9, 2015 | 02:58 PM
  #181
sub3622's Avatar
sub3622
If i ever need to change the timing chain i would probably do it myself.
I really do not want to do the job but i refuse to pay insanely amount of money to the dealer plus i don´t trust any indy shop around here, they seem to not now much about minis.
This is the main reason i always check my oil level and change it every 2500 miles.
Old Sep 27, 2016 | 01:38 PM
  #182
pitpete's Avatar
pitpete
Melvinyip
Apr 17, 2020 09:28 AM
Spank
11
Apr 9, 2020 02:23 PM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
