How To Drivetrain :: Alternate DoS Intake Install Method
Old Mar 21, 2011 | 02:18 AM
  #26
Mini'mon's Avatar
Mini'mon
Originally Posted by daryl70
Where can I get it?
If you want to mod the panel yourself, you can get one from your dealer or from Classic MINI in Ohio or Morristown MINI in NJ. They have really great prices on OEM parts if you mention that you're a NAM member.
Hope this helps!
-Clint
Old Sep 6, 2011 | 02:08 PM
  #27
fishbert's Avatar
fishbert
Originally Posted by Mini'mon
This type of filter typically has a very long cleaning interval unless you live in very dusty/pollen-heavy conditions.
Here is some info concerning cleaning intervals from the K&N Website that should be helpful.
(from http://www.knfilters.com/faq.htm )
4. How often do I need to clean my K&N air filter?
If you have not experienced a decrease in mileage or engine performance, chances are your filter is fine and does not yet need cleaning. To be more specific, the filter does not require cleaning if you can still see the wire screen on the entire air filter regardless of how dirty it may appear. When the screen is no longer visible some place on the filter, it is time to clean it. When used in normal paved road, street or highway conditions, our replacement air filters that fit in the factory air box should require cleaning every 50,000 miles and our large conical filters on an intake system should require cleaning every 100,000 miles. When used in dusty or off-road environments, our filters will require cleaning more often. We recommend that you visually inspect your filter once every 25,000 miles to determine if the screen is still visible. . . ."
All that being said, I still check the ones that I use every 10,000-to-15,000 miles. You can pull the CAI and shine a shop light into it's large mouth to see if you can still see the wire screen that holds the cotton gauze filter material in place.
Finally, remember to not over-oil the filter. It only takes a small amount of oil to recharge the filtration ability of a cotton and wire mesh filter. I like to use the aerosol recharger kits. One light pass across the inside and outside is all it takes.
-Clint
When cleaning the filter, do you need to disassemble the intake to remove the filter, or can you wash & oil it in-place?
Old Sep 7, 2011 | 06:41 AM
  #28
blitzed310's Avatar
blitzed310
Absolutly not, you do not want any oil or water coming close to the MAF. You must remove the cone and dissassemble the housing to remove the filter to wash and oil it.
Old Sep 7, 2011 | 07:28 AM
  #29
fishbert's Avatar
fishbert
Well, I would let it dry... Not like I'd be washing & oiling the MAF as well; that's downstream of the DoS intake, not attached to it.
Old Sep 7, 2011 | 09:52 PM
  #30
Mini'mon's Avatar
Mini'mon
Yup. You should disassemble the intake. There is no way to thoroughly clean and evenly apply the recharger spray to the filter w/o removing it from the housing.
Best,
-Clint
Old Oct 21, 2011 | 11:46 AM
  #31
captain-fitch's Avatar
captain-fitch
This kit looks great! Been looking at a few different CAI's, all of the ones I've come across I'm pretty sure will suffer from horrendous heat soak but this could be the solution. Will it fit a UK spec car and is there anywhere I can get it in the UK? Thanks in advance
Old Oct 22, 2011 | 02:08 AM
  #32
Mini'mon's Avatar
Mini'mon
Shipping a DoS CAI to the UK
To answer your questions:
1) The DoS R56 CAI will fit a UK spec car. We have quite a few customers in the UK and Australia.
2) We ship orders to the UK 1 to 2 times per week. Drop me an email or PM if you'd like me to send you a shipping quote.
Have a great weekend.
-Clint
Old Dec 8, 2011 | 02:52 PM
  #33
conrad0102's Avatar
conrad0102
Originally Posted by sunman
Conversely, you can always get another bulkhead panel 51712755866, which is listed at $30.00 for passing inspections...
woa woa wao... can't pass inspection with the DoS? what if I am in Texas? ahhh this is making me want it less. Can anyone help? This would be my first mod to an 07 MCS with stage 1 jcw kit. Oh and how much better is the DoS than the stage 1 intake system?
Old Dec 8, 2011 | 03:03 PM
  #34
Mini'mon's Avatar
Mini'mon
Conrad, you will still pass inspections if you have a DoS CAI. Sunman lives in SoCal and they're more strict about visual inspections of the engine there due to the stringent CARB standards in CA. If you live in TX, you'll be fine.
-Clint
Old Dec 8, 2011 | 07:00 PM
  #35
conrad0102's Avatar
conrad0102
Thankyou.
Old Dec 8, 2011 | 08:27 PM
  #36
Mini'mon's Avatar
Mini'mon
Thankyou.
No problemo!
Old Dec 8, 2011 | 11:55 PM
  #37
fergy016's Avatar
fergy016
Being located in California, about 45 minutes from the address on DOS website, I am curious if DOS is planning on submitting the CAI for Carb EO requirements?
Old Dec 9, 2011 | 09:42 AM
  #38
sunman's Avatar
sunman
-Clint
The original message I posted about the getting an additional bulkhead does pertain to the visual inspection that Clint mentions. I'm still looking at options of how I will do this when it comes to getting my car smogged, but considering I still have a few years to go before that happens, I'm thoroughly enjoying the DoS CAI in the mean time...
Old Dec 12, 2011 | 10:52 PM
  #39
fergy016's Avatar
fergy016
The bulkhead being cut would not raise any flags, but the modified intake would, and I was curious if DoS is/was getting the intake Carb EO approved to run in states that require that certification.
Old Dec 13, 2011 | 01:38 PM
  #40
Mini'mon's Avatar
Mini'mon
fergy016,
sunman pinged me about the CARB question earlier this year. We're going to file the paperwork for CARB exemption/certification in January 2012 and see if they'll allow us to do the testing locally. If they do not allow us to test at a lab in the Bay Area, we'll be looking for DoS customer in the LA metro that would be willing to help us out.
-Clint
Old Dec 13, 2011 | 05:18 PM
  #41
fergy016's Avatar
fergy016
Just wanted to say thank you to both Sunman and Clint for the amazing information you have offered.
Cheers
silence2-38554
98
Sep 21, 2016 02:52 PM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
