How To Maintenance :: How-To do Seafoam Treatment R55/R56
Old Jan 20, 2010 | 05:47 PM
  #151
ThumperMCS's Avatar
ThumperMCS
Wow....thanks for the tubing pics OXY!
Old Jan 20, 2010 | 05:50 PM
  #152
countryboyshane's Avatar
countryboyshane
Holy crap that says a lot. Seafoam is coming soon to my R56 LOL!
Old Jan 20, 2010 | 09:50 PM
  #153
Davidoyo's Avatar
Davidoyo
Originally Posted by OXYBLUECOOP
I ran clear tubing from the breather connection for three days to show what our engines are ingesting from the pcv system. Now I usually have to empty my OCC every week which consists of oil and a white foamy sludge. You folks definitely don't want this crap going through your engines.
Get yourselves some Oil Catch Cans if you plan on keeping your MINI's past warranty along with regular carbon/sludge removal treatments.
What OCC are you running? I only know of 2 for the Mini which are M7 and Riss racing which are basically the same OCC. I have also heard that they are not baffled and to look into the this OCC http://www.42draftdesigns.com/catego...catchcans.html the only problems with the 42 draft designs ones are they are universal fit and don't have a mount for the Mini.
Old Jan 20, 2010 | 10:31 PM
  #154
Oxybluecoop's Avatar
Oxybluecoop
I was using the M7 can and no it's not baffled. I will be purchasing the 42 draft designs can and fabbing up a mount. For now I'll just run the hose out under the car.
Old Jan 21, 2010 | 12:08 AM
  #155
Davidoyo's Avatar
Davidoyo
Let me know what you use to fabb up the mount because I am not that mechanically inclined to fabb things together.
Old Jan 21, 2010 | 06:43 AM
  #156
STi2Mini's Avatar
STi2Mini
Sorry for being a noob, but I'm not sure which hose it is. I pulled off the one here and it smelled like gas and had some nasty looking stuff pouring out of it. I don't see where it goes to the other side of the engine like in the diagram. The length of it sits on the top of the engine behind the cover. The one in the video and the one in the diagram look a lot thicker than this one.
Here is my engine bay. Can anybody point me in the right direction?
Old Jan 21, 2010 | 08:09 AM
  #157
STi2Mini's Avatar
STi2Mini
Well I did it in that hose and it seemed to work. Smoke POURED out of the exhaust already!! Waiting about a half hour before starting her up again.
Old Jan 22, 2010 | 10:21 AM
  #158
STi2Mini's Avatar
STi2Mini
So my butt dyno says that there was definitely a gain in power. When I was given a loaner Clubman-S it felt faster than my MCS. Now it feels just about the same. I am going to give my S another treatment this week. Maybe I will let it sit for an hour or so. Idle is so much smoother and the whole car just runs smoother all around.
Old Jan 23, 2010 | 07:36 AM
  #159
Barrettrw11's Avatar
Barrettrw11
got about another 15-20 minutes left till i start my car back up... Hope it works.
Old Jan 23, 2010 | 08:07 AM
  #160
Barrettrw11
I didn't get a lick of smoke. Maybe it was because I did this on a hill? I'm not to sure what do you guys think? I have an 05 MCS with about 62,000 miles. I also put in about half a can into the pcv valve and waited 35 minutes.
Old Jan 23, 2010 | 08:34 AM
  #161
Oxybluecoop
You should have had some smoke regardless. I'm assuming you put it in at #1 here on this diagram?
When I treated my R53 I used a small hose(just like in the video) and let it pull the fluid out to the point of almost a stall then let it catch up and repeat a few times. It sounds like your not getting enough in there in a short enough time. You not going to hydrolock the motor even if you stall it. If you do stall it then you know there's plenty of fluid in there so just wait 15-30 minutes.
Old Jan 23, 2010 | 09:32 AM
  #162
Barrettrw11
I actually just did it again and i got a lot of smoke. This time I did it on a flat surface and used a squirt bottle to put it in the hose. I also put it in faster this time, the first time I squirted it in slowly. Should I do this again tomorrow or wait a little bit to do it again?
Old Jan 24, 2010 | 12:12 PM
  #163
lacning74's Avatar
lacning74
First treatment half can via spray bottle @ 26000mi in my MC. Waited an hour. Lots of smoke for about 5 minutes of driving. Feels smoother for sure. Idles less than 700rpm now vs almost 800 before. Guess I'll save on gas now while I wait at stoplights now lol.
Old Jan 25, 2010 | 02:27 PM
  #164
trwxxa's Avatar
trwxxa
I've used Seafoam my other vehicles. When I do them, I dribble the Seafoam in until there is a few tablespoons left, then pour it in fast enough to stall the engine. Then I let it sit for 40 minutes or so before starting and blowing out the crud. This pulls a good amount of the liquid in that coats everything, before it's pulled through the motor and combusted. It seems to work very well.
Is this method safe to do on the MINI? Should I just dribble it in, then shut off the engine with the button, before letting it sit?
Old Jan 25, 2010 | 09:19 PM
  #165
Dr Obnxs's Avatar
Dr Obnxs
I'd be wary of flood till stall...
you're probably safe with that little liquid, but going to far down this road will lead to hydrolock. I'm a fan of suck it in and kill the motor while sucking. This turns it into a two person job though....
Matt
Old Jan 26, 2010 | 12:22 PM
  #166
STi2Mini's Avatar
STi2Mini
May sound a bit odd, but I've gained about 2 - 3 mpg after using this stuff!
Old Jan 26, 2010 | 02:21 PM
  #167
Barrettrw11
I'd say that is a good gain for a bottle of seafoam at 10 bucks a can. I'm doing my 2nd treatment tomorrow with a can in the gas tank too.
Old Feb 3, 2010 | 09:01 AM
  #168
JimRoberts12's Avatar
JimRoberts12
could you point out in you photo where and what tube you poured into. i'm so bad with this stuff. it's why i'm not much of a modder. i just don't know all the jazz under the bonnet very well.
then did you just stick a tube in the can and feed it like in the video?
Old Feb 4, 2010 | 10:12 AM
  #169
STi2Mini's Avatar
STi2Mini
Its on the top left side of the block. It's a small hose, much smaller than the one in the video. I used some tubing from fish tank supplies and let the car suck it out of the can. I'll try and make a vid tonight for us R56 people that don't know this car very well yet! Haha!
Old Feb 4, 2010 | 10:50 AM
  #170
JimRoberts12
that would be great. i'm still very timid about this kind of thing. don't want a CEL!
Old Feb 4, 2010 | 03:07 PM
  #171
STi2Mini's Avatar
STi2Mini
Haha, yeah I was the same way!! Then I did the whole thing and I was like, wow that was really easy. An extra set of hands sure does help though. I'll try to take a vid tonight as I still have about a 1/3rd left. Hopefully it won't be too dark!
Old Feb 6, 2010 | 07:21 AM
  #172
phxsteele's Avatar
phxsteele
Im planning on doing this today. I just want to make sure I am putting it in the right spot. Here is a copied pic of an R56S engine bay. Is the red arrow were the seafoam goes in?
Old Feb 6, 2010 | 07:37 AM
  #173
Oxybluecoop
Yes that's the correct hose.
Old Feb 8, 2010 | 07:24 AM
  #174
JimRoberts12
any luck on that?
Old Feb 8, 2010 | 12:39 PM
  #175
STi2Mini's Avatar
STi2Mini
Not yet, was out at the g/f's place all weekend. I will do it tomorrow night!
