How To Maintenance :: How-To do Seafoam Treatment R55/R56
Old Apr 2, 2010 | 07:57 PM
  #226
DMBFan2's Avatar
DMBFan2
Same thing happened to me when I did this the 1st time as well. However, I was told that I should keep the RPMs up to about 2500 the next time I try this again. So I did. The smoke was thick for a time but eventually cleared up. I do this a few nights before my oil changes and my Minis MPG has increased. Also, someone posted that the dealership does this and leaves it in the car overnight. Maybe it'll work for you?
Old Apr 4, 2010 | 04:45 PM
  #227
thevelourfog's Avatar
thevelourfog
Just did the treatment to mine. Started it up, poped the hose off and poured it in slowly and holding my thumb over the hose. Did this about 10 times using about 1/3 of the bottle before reattaching the hose and shutting down for about 30 min.
Starting back up, had nice clouds of smoke for about a minute of rough idling and driving about a mile. End result is slightly smoother acceleration and lower idle. Idles about 50-ish lower than before.
Will do another treatment before installing my BSH catch can/boost port and getting tuned.
Old Apr 8, 2010 | 07:05 AM
  #228
Dwight Walhood's Avatar
Dwight Walhood
Question
Did the SeaFoam thing the first time at 23K and noticed an immediate improvement in idle and performance. My question is whether one treatment is enough to clear out 23K's worth of carbon? Plan to repeat with every 6K oil change from now on. Thanks for any help.
Old Apr 8, 2010 | 10:14 AM
  #229
Dr Obnxs's Avatar
Dr Obnxs
There is no way to know...
but if things got much better, be happy and just do it with your regular service.
You could get a boroscope to poke around and look inside, or remove the intake manifold to examine the backs of the valves, but it would just be easier to do a couple more treatements!
Matt
Old Apr 8, 2010 | 10:31 AM
  #230
thevelourfog
I'm sure with higher miles one treatment isn't enough. Besides, it's easy to do and seafoam is pretty cheap, so may as well do it a couple times before setting a regular interval for yourself.
Old Apr 8, 2010 | 01:59 PM
  #231
Dwight Walhood
Smile
Thanks much y'all! Two more times it is as the wee beastie is about due for an oil change anyhow.
Old Apr 8, 2010 | 04:35 PM
  #232
BillyCuth's Avatar
BillyCuth
Wow - what a HUGE difference for me... Just bought the car 2 weeks ago, and about a week ago, performance just took a nose dive. The car has 86000 miles on it.. It's felt like it has been in "limp" mode for about a week. No CELs at all, but it still wasn't right.
Now it's back to normal (or what I remember to be normal) and there is no massive hesitation at startup.
Best $7 I have spent on this car so far... 2 treatments in the intake and the rest went in a new tank of gas....
Old Apr 21, 2010 | 12:16 AM
  #233
ra2fanatic's Avatar
ra2fanatic
hey guys, which bottle do i order?
http://www.seafoamsales.com/products.html
Old Apr 21, 2010 | 05:52 AM
  #234
clutchless's Avatar
clutchless
Thirsty Fire, Since SeaFoam is not available in your country, any of those products should work fine if they make claims for carbon removal or intake valve cleaning. Just use the same as SeaFoam. I have done it with http://www.renewablelube.com/pdf/2I-...onditioner.pdf and had great results, plus it does not smoke like SeaFoam! I also add 1 ounce to each tank of gas as a maintenance dose.
Old Apr 21, 2010 | 07:23 AM
  #235
thevelourfog
I've been using the 16 oz bottle on the left of that page. The spray can looks interesting though, could make it easier to apply.
Old Apr 21, 2010 | 08:09 AM
  #236
ra2fanatic's Avatar
ra2fanatic
cool "motor treatment" it is then! thanks!
Old Apr 21, 2010 | 10:04 AM
  #237
elpappy's Avatar
elpappy
Did my first sea foam today at 36k. Smoked like a champ. Also changed the oil and the spark plugs.
Only findings where one spark plug had very minor carbon on it. Seems smoother accelerating at low speeds but that could be my imagination. I'll post any further findings.
Old Apr 22, 2010 | 01:50 PM
  #238
krim's Avatar
krim
Just did mine, just shy of 19k. Neighbors are not happy about the giant cloud of smoke. Unfortunately, the wind changed directions and filled my garage up with smoke. Food and water tastes funny now and i have a headache. Do not walk thru smoke to get out of garage, RUN. At least, now i know how the Spyhunter smoke screen works.
got the CEL, Navi says "Increased Emissions", i figure it'll go away after a long run on the freeway cleans off the O2 sensor.
Idle was immediately smoother and power seems to be smoother as well on a short run to the bank. I did notice a large amount of water inside the tailpipes and on the floor behind. I assume it's because i was driving in the rain last. Im going to do another 1/3rd later and let it sit overnight and send up another cloud way early in the morning when i leave for work, no one will be the wiser.
Old Apr 22, 2010 | 07:36 PM
  #239
onefish2's Avatar
onefish2
Just did my first Seafoam treatment (thanks for helping ndylam). All I can say is wow!!! I must be doing something good as there was ton of BLACK smoke that poured out of the tail pipes. I have about 15.5k miles on my car. Never did a engine treatment on the car. No CELs either.
I am happy with the results.
Old Apr 22, 2010 | 07:58 PM
  #240
Dwight Walhood
Exclamation WARNING
FYI to all you Seafoamers. If you get that stuff on your skin, I'd advise washing with COLD soap and water ASAP! It's loaded with some powerful, nasty organic solvents like naphthalene and I suspect toluene and benzene as well. Ever wonder why not even a skunk will get near a moth ball? Naphthalene!!
Old Apr 23, 2010 | 03:21 AM
  #241
hoonpv's Avatar
hoonpv
one question,
I seafoamed my R53 today and sucked the seafoam through where the grey line, the thin line below the IC cover (you can't see it here but it's green arrow) since it was the one with vacuum.
but I got very little smoke afterwards.
Was I suppose to put the Seafoam to where the yellow arrow is pointing? that one didn't have any vacuum at all. no suction.
-drew-
Old Apr 23, 2010 | 07:28 AM
  #242
thevelourfog
Originally Posted by hoonpv
one question,
I've never done it to an R53, but the Yellow Arrow, B, is the PCV hose. You may have more suction if you rev it a little. You can really use any vacuum line. If there's any around the throttle valve, you can use those too.
Old Apr 26, 2010 | 01:44 PM
  #243
jsargevt's Avatar
jsargevt
Thanks Oxy!
Oxy - thanks for posting this. Even I, a moron about working on cars, figured this one out with success.
I have to say that it does seem to make it idle smoother and there seems to be less hesitation (although that might just be due to the fact that I am looking for it).
I did pick up the spray can and probably used less than 1/3 of the can - more like 1/5th or so. I wanted to make sure that I was doing the right thing so I fiugred that little is better than a ton. Waited an hour and then fired it up to a bunch of smoke as expected. Note to self - turn off the AC/Fan when doing this so I don't blow a bunch of smoke into the cabin.
So....+1 from me on doing this. Simple, easy and it seems to have immediate results. Thanks for providing a video so even I can figure this out.
Old Apr 27, 2010 | 09:42 AM
  #244
JimRoberts12's Avatar
JimRoberts12
i'm planning on finally doing it tomorrow. clear/warm day here in indy. i think since there isn't an S one, i'm going to do a video of my mcs for the forum. no promise..
Old Apr 27, 2010 | 09:44 AM
  #245
Thirsty Fire's Avatar
Thirsty Fire
I could not find Seafoam here in my country but I've found 3M Do-It-Yourself Fuel System Tune-Up Kit
http://solutions.3m.com/wps/portal/3...gl4XNTZDZS4Bbl
Is it any good?
Old Apr 27, 2010 | 09:58 AM
  #246
JimRoberts12
Is it any good?
where are you? i don't know if i can but might be able to send some. dont know what the restrictions are.
Old Apr 27, 2010 | 10:07 AM
  #247
Thirsty Fire
I live in Saudi Arabia, anyway thank you I can get it from Amazon but it will take some time thats why I'm asking if that 3M is good alternative.
Old Apr 27, 2010 | 10:10 AM
  #248
JimRoberts12
no problemo. best of luck. no idea about the 3m.
Old Apr 27, 2010 | 10:15 AM
  #249
Thirsty Fire
Thank you. I just ordered a pack of 6 for 40$ I will receive it next week.
thank you amazon
Old Apr 27, 2010 | 10:23 AM
  #250
jsargevt's Avatar
jsargevt
Uh....recheck page 1 of this thread. There is an R56 S video in position #2. They even have a nice looking NM Engineering CAI.
