How To Interior/Exterior :: Headlight Joey Mod How To
Old Jan 14, 2015 | 05:35 PM
  #201
znekcihc's Avatar
znekcihc
A hair dryer is sufficient heat. Perhaps you're not doing it properly? Also, before painstakingly separating the lights, but a $15 lens repair kit at wal mart. Spend 15-30 minutes using some elbow grease and it will look brand new. Trust me. I couldn't see through mine, so foggy and hazy. Crystal clear now.
Old Jan 14, 2015 | 06:58 PM
  #202
NatJoo's Avatar
NatJoo
Thanks...think i'll go that route.
Old Aug 20, 2016 | 09:01 AM
  #203
DrewWphoto's Avatar
DrewWphoto
Ok so I've got the headlights to my wife's 2005 jcw apart and can't figure out how to get the projector shroud off. All the pictures to the installs don't work so I'm having a hard time figuring this step out.
Old Aug 20, 2016 | 12:01 PM
  #204
BlwnAway's Avatar
BlwnAway
It's been a long time, but I'm thinking it is just held on by some small tabs on the shroud itself and basically just pops on and off.
But as I said it's been a while.
Old Aug 20, 2016 | 07:04 PM
  #205
DrewWphoto's Avatar
DrewWphoto
got it. Thank you.
Old Jan 18, 2018 | 08:28 PM
  #206
bump32's Avatar
bump32
Joey Mod Help
Ok... so I'm knee deep in the Joey Mod and hit a snag.
I cannot get the lower reflector (high beam) chrome piece out. (Picture 1 yellow circle)
EDIT: So I ended up leaving this piece chrome.
Joey Mod midwayThere are 3 torx screw that I can reach and unscrew no problem... (2 in red shown, 1 on the other side of the upper xenon mount)
But there are 3 more (one shown in yellow) that are ridiculously buried deep in the housing with no way of reaching???? Are people just painting this piece in the housing? Or leaving it chrome?
EDIT: These bolts were super deep in the housing and I was not able to get them out. I decided to leave the piece in picture 1 chrome.
Old Jan 18, 2018 | 08:44 PM
  #207
bump32's Avatar
bump32
Joey Mod Help
Couple of things that might help the next guy that tries this. (it's not to bad... just go slow)
1) For those of you that (like me) couldn't see the pictures on page 1 from DrPhilGandini's super helpful "how to"....(images not showing up for me) I found them....upon digging into DrPhilGandini's Albums, I was able to find some of the pictures.
https://www.northamericanmotoring.com/g/album/3728330/2
And....
2) In order to pop off the Chrome piece around the xenon projector I had to go from the backside (yellow arrow) (where the bulb goes in) with a long dentist tool to pop the two tabs. (yellow circles ] You can set up a light to shine back in the projector bulb to see the tabs.
Here's the two little tabs that need to be pop out in order to get this piece off.
Then you can remove the smoked clear piece from inside the chrome with the three outside tabs. (DrPhilGandi has a good picture of this too on his album)
Hope this helps the next guy.
Attached Thumbnails Interior/Exterior :: Headlight Joey Mod How To-screen-shot-2018-01-18-at-8.30.11-pm.png
Old Apr 18, 2018 | 02:27 PM
  #208
red calipers's Avatar
red calipers
Hey Dr. Phil,
It seems as if your "How To" on the Joey Mod is the best one out there! I am getting a good idea of how to do it just from the text, but all of your photos are gone!! Is there any way to view these? There just seems to be blank space between the text where the photo would have been. Thanks so much. Looking forward to doing this!
-Mason
Old May 14, 2018 | 07:10 PM
  #209
bump32's Avatar
bump32
pictures
Old May 19, 2018 | 03:55 PM
  #210
red calipers
Going to attempt this tomorrow. A few last questions for some experts:
-After reading through this post, I still haven't seen any final word on if High Temp paint is needed? (I bought some facelifted xenons). Would some classic Rustoleum paint work? Or should I get some High Temp BBQ paint?
-As far as timing goes, can I start putting everything back together after a few hours, or should I let the painted internal components dry for a day or so?
Thanks for the all help!
Old May 19, 2018 | 04:10 PM
  #211
BlwnAway's Avatar
BlwnAway
Standard paint will work fine, something formulated for plastic would be best, but not needed (plastic formulated paint is designed to adhere to slick surfaces better)
And no, if the paint is dry, your good to reassemble.
Old May 19, 2018 | 04:19 PM
  #212
red calipers
BlwnAway, thank you!
And lastly, what was your prep process for the plastic? Did you take the time to sand down the surfaces, then wipe with alcohol wipes? Do I actually need to acetone off the existing chrome?
Old May 19, 2018 | 08:19 PM
  #213
Dave.O's Avatar
Dave.O
You can just wipe them down with alcohol or a couple lite wipes of acetone but it all depends on how oily your hands are and where you touched the chrome you are painting.
If you spray light coats of black and you see “fish eyes” a.k.a. spots where paint will not stick it’s because there is oil still on the chrome. Stop painting and wipe that area down again.
Old May 19, 2018 | 09:24 PM
  #214
BlwnAway's Avatar
BlwnAway
Ditto, I would get some acetone if you can (even Wal-Mart has it) but if not at the very least use some rubbing alcohol.
The thing about the acetone is that it will actually start to take some of the chrome finish off, which will give you a better surface for the paint to adhere to.
Old Nov 27, 2020 | 06:32 AM
  #215
eimkeith's Avatar
eimkeith
bookmarking for later.
Old May 25, 2021 | 03:08 PM
  #216
nyckid221's Avatar
nyckid221
Anyone with a diy for 2003 xenons?
patsum
26
May 29, 2021 06:29 PM
Burkee52
Electrical
Sep 18, 2015 11:12 AM
theateist
Sep 16, 2015 07:22 AM
dscott90000
Sep 9, 2015 07:55 AM
tylewis
Sep 6, 2015 07:36 PM
