Newbie GP2 Questions
Old Dec 20, 2015 | 07:50 PM
32 ft. per sec2's Avatar
32 ft. per sec2
Apologies if these are in a previous thread.
Anyone have an opinion on installing a turbo heat shield for the GP2?
Also, is there a safe, effective way to remove the nanny state issued warnings on the sun visors?
Old Dec 20, 2015 | 10:03 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes I cut a notch in our hood heat shield and use it as it works the best and is cheap.
http://www.waymotorworks.com/mini-co...5-r56-r57.html
Most people put stickers over the visor stickers, trying to remove them leaves a black square.
Old Dec 21, 2015 | 06:45 AM
tech12's Avatar
tech12
Do you recommend adding the turbo heat shield as well if we apply your hood heat shield?
http://www.waymotorworks.com/nm-tita...er.html?&cat=0
Old Dec 21, 2015 | 09:19 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
There's some info on the stickers for the visor in this NAM thread here.
888.280.7799 | 6am - 5pm PST
Old Dec 21, 2015 | 07:16 PM
WayMotorWorks
Vendor
You can, but check out our turbo wrap as it goes under the stock heat shield and works even better.
http://www.waymotorworks.com/wmw-turbo-heat-shield.html
Old Dec 31, 2015 | 10:09 AM
32 ft. per sec2
Update on mods performed:
- Installed Way's hood heat shield and turbo wrap. Like a total d-bag I couldn't get the hood version to mount properly because there were no instructions provided and couldn't find any online. So of course I did it wrong but only after I saw a picture of it correctly installed. The turbo wrap was another story becuase I couldn't reach the lower OEM factory heat shield mounting bolts so took it to a repair shop and they got it done. It smells/smokes but am told it goes away. Thank God my wife wasn't around! By the "Hand-O-Meter" all seems much cooler and hard to tell there's anything there beyond the OEM stuff.
- Installed Rennline RS door pulls (red of course) and they're video was very helpful, much better than the written instructions however they missed a couple of small pieces that had to be fabricated. Getting your hand down between the door card and window was a PITA- hopefully you'll have thin friends or coordinated child available. One thing that wasn't apparent but needs fixing by Rennline is the laser finish on the face plates. There's a slight bur on them that snags at the cloth door pulls. I'll smooth them out with small round file but really...
- Installed the Hella 118db horns and haven't had a chance to use them in anger yet. Getting at them is a PITA too, had to pull the headlight off otherwise you go up underneath by taking the lower valence/bumper off. Argh.
- Installed Stubby antenna. I actually didn't f' this up.
- Installed black trim rings on front & rear lights with moderate success. I was stressed with the whole clip thing and after watching a couple of videos figured it'd be OK. The fronts were straightforward but I snapped the internal clips on the chromes when removing. And chipped the paint. I really shouldn't be trusted with anything sharper than a butter knife.
The only thing left are Rennline RS pedal covers but they'll have to wait a few months. And then there are motor mods.... or suspension?
Tikigod
Dec 13, 2015 05:10 PM
stellaherself
Cooper (non S)
Dec 10, 2015 01:44 PM
gpwpat
Electrical
Dec 7, 2015 05:30 AM
polepino
Dec 4, 2015 09:30 AM
KinetechMW
Nov 30, 2015 08:34 PM
