Thinking of buying a GP
Old Feb 26, 2014 | 05:58 AM
Bean0709's Avatar
Bean0709
Does anyone know...can the suspension be adjusted so it rides higher? I do not like the look of where the wheels look as if they will scrape the wheel wells.
I like to get up and go, but I do not speed around corners, so I do not need it to sit low.
Old Feb 26, 2014 | 06:50 AM
yetti96's Avatar
yetti96
The coilovers are adjustable. How much higher are you wanting to go?
Old Feb 26, 2014 | 06:54 AM
Bean0709's Avatar
Bean0709
I don't know, how high does it go?
Old Feb 26, 2014 | 09:26 AM
ra2fanatic's Avatar
ra2fanatic
How quickly do you need to "get up and go" to justify raising up a lower-than-jcw GP2 and plunking down $40k for it? A S-model isn't enough power for you?
If you're not going to speed through a corner, not that it's necessary information to justify a specific model, you really don't need a GP2.
Unless you're looking to put it on a mantle somewhere.
Old Feb 26, 2014 | 09:27 AM
akng's Avatar
akng
Maybe the one you are looking at is lowered to the max already. You should ask the salesman to confirm.
Old Feb 26, 2014 | 09:50 AM
Bean0709's Avatar
Bean0709
I already own a JCW hardtop. I like the look and seats and rumble of the GP. Hey...don't worry about how I spend my 40k.
I just do not like the look of the wheels almost touching the wheel-wells. To each their own I suppose.
Old Feb 26, 2014 | 09:57 AM
ra2fanatic's Avatar
ra2fanatic
lol. No worries, If you want to spend 40k, don't let me stop you! I'd think you'd get more body roll by raising it though. To each their own.
Old Feb 27, 2014 | 01:31 AM
robbo mcs's Avatar
robbo mcs
Different GP's seem to come from the dealers set at different heights. I have had 2 GP2's, both from the sale dealership new, and they came set at quite different heights.
I suspect that the car you are looking at may have been fully lowered. A GP2 set mid range does not have the wheels any where near touching the wheel wells!
You need to have a look under the car at the coilovers. The coilovers have a threaded part. On the front there are 2 black rings one on top of each other, on the rear there is 1 black ring. If you can see thread visible above these rings, then there is room to raise the suspension. The amount of thread showing above the ring is the limits to how much further it can be raised.
Old Feb 27, 2014 | 03:32 AM
JackMac's Avatar
JackMac
By default, the GP2 should be set at the midpoint at delivery. So to answer your question, yes it can be raised.
Just want to add that I've never had an issue at the default ride height. There is still plenty of wheel travel.
Old Feb 27, 2014 | 03:34 AM
Bean0709's Avatar
Bean0709
Awesome! Thank you so much for your responses. Helps a lot! 😉
Old Feb 4, 2026 | 11:30 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Was I lying ???
woodstudio
Mar 15, 2020 08:28 AM
Yazon
Tires, Wheels, & Brakes
11
Aug 27, 2015 04:41 PM
elightbo
Aug 17, 2015 01:50 PM
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
