m.p.g. from the GP
Old Oct 3, 2006 | 05:27 PM
TagURit's Avatar
TagURit
m.p.g. from the GP
For all those who are currently enjoying their GP's, what kind of mileage are you getting, normal driving -vs- spirited driving
Old Oct 3, 2006 | 05:31 PM
Motor On's Avatar
Motor On
I thought normal driving was spirited Are you calliung me not normal?
I'd actually be interested to hear this as it should be A more efficent and B lighter.
Old Oct 3, 2006 | 07:23 PM
GoodFinder's Avatar
GoodFinder
Ymmv
300 miles of spirited driving in the countryside yesterday with a bunch of other MINI enthusiasts ... 21.9 MPG ... 42 PSI tire pressure (for the high speeds) ... driver and passenger ... ranging from 90-94 degrees external temperature ... plenty of hills, curves, and WOT (wide open throttle) ... very enjoyable!
Old Oct 4, 2006 | 09:15 AM
RedSkunk's Avatar
RedSkunk
Very much doubt that GPs will get better mileage than MCSs, on average / median.
Old Oct 6, 2006 | 07:24 PM
Highbid's Avatar
Highbid
26-29 mpg over the course of 3900+ miles. I drive my wifes S and I get about the same on either. I drive them both hard but once you get on the freeway there is only so much you can do and there I often just cruise in 6th.
Old Oct 7, 2006 | 07:43 PM
Edge's Avatar
Edge
AdMINIstrator
I disagree, in "normal" (i.e. not WOT) driving, I think the increased power will be offset by the decreased weight. I would expect a GP to pull in about the same mileage numbers as an MCS or regular JCW. Heck, even comparing WOT vs WOT it probably isn't that much of a difference than a regular JCW either (for exactly the same offset reason).
Old Oct 8, 2006 | 10:20 AM
RedSkunk's Avatar
RedSkunk
Driving style is a bigger factor than any of this, so there's no way to get normalized figures from each model (unless you'd want to go to something as flawed as the gov't's figures). But I don't see any reason to believe that an 80 or 90lb reduction in weight offsets a 50hp increase.. Whatever, time will tell. We've gotten two replies in this thread so far. Keep them coming.
Old Oct 10, 2006 | 06:59 AM
Minzilla's Avatar
Minzilla
FWIW after 3500 miles mixed about 29-30MPG, but then again I don't think anyone bought a JP for gas mileage??, it does have a much higher fun factor though
Old Oct 10, 2006 | 05:09 PM
MOTORN's Avatar
MOTORN
It will improve if you turn off the A/C
Knownman
R60/R61 Stock Problems/Issues
55
Feb 14, 2013 11:06 AM
johnny6666
Jul 29, 2008 10:44 AM
MiniXXX
Mar 27, 2007 05:54 PM
