Orange Lifting Blocks
Old Apr 24, 2010 | 03:23 PM
BoostLE's Avatar
BoostLE
I just found out that my GP is missing the four orange lifting point extenders used to jack the car up. I called Crevier BMW and after some searching the found the part, but want $63 each!
What do you guys use to lift this car if you no longer have the orange blocks?
Old Apr 24, 2010 | 05:31 PM
PorscheMini's Avatar
PorscheMini
Blocks of wood about the same size
Old Apr 24, 2010 | 10:38 PM
mrwilson's Avatar
mrwilson
Don't have mine either and I'm also missing one of the plastic flap covers that clip over the frame pocket, in my case the one under the driver side. I'm with just using a block of wood, which I will test soon with my spanky new Racing Jack from Harbor Freight tools. The missing cover is something to scour ebay for over the next few years, though the benefit of the cover is a bit sketchy. The only plus is that it's an OEM part, and I do want to keep GP 0826 in spec.
Old Apr 24, 2010 | 10:51 PM
WC50 408's Avatar
WC50 408
Check at a different dealer as the part number is 51717188454 and they are listed at 28.49 ea.
Old Apr 24, 2010 | 10:59 PM
WC50 408's Avatar
WC50 408
The covers are for reduced drag under the car, part # 51777186270 @ 19.76 ea. are the fronts and 51777186271@ 19.76 is the left rear and 51777186272@ 19.76 is the right rear
Old Apr 25, 2010 | 08:02 AM
quikmni's Avatar
quikmni
pelicanparts.com has the fronts and rears for $21.75 each.
Old Apr 25, 2010 | 05:38 PM
mrwilson's Avatar
mrwilson
THX bro...will get to shopping.
Old Apr 25, 2010 | 05:42 PM
mrwilson's Avatar
mrwilson
while I'm at it, do you know what that cover part officially called? apologies to the OP for this hijack...though somewhat related...and welcome to the only GP forum really worth visiting.
Old Apr 26, 2010 | 07:32 AM
quikmni's Avatar
quikmni
RealOEM is a good place to see parts diagrams and to obtain part numbers.
http://www.realoem.com/bmw/
The covers are:
Cover, jack fixture, front; P/N 51777186270
Cover, jack fixture, rear left; P/N 51777186271
Cover, jack fixture, rear right; P/N 51777186272
Old Apr 27, 2010 | 09:00 PM
azminiman's Avatar
azminiman
The blocks would be easy to make. just get the exact mesurements, and anyone who is a good wood cutter can make.. Then paint orange!!
Old Apr 29, 2010 | 10:48 AM
BoostLE's Avatar
BoostLE
I guess I'll go the orange wood route too I'm guessing the wood should fit inside the lifting point. Thanks for the info about the covers guys, I'm missing those as well.
Old Apr 29, 2010 | 01:05 PM
quikmni's Avatar
quikmni
Be careful how you use wood blocks. You need to pay attention to the wood grain and how you apply stress to the block so that you do not split the wood block, especially when using a small block at the jack point where the weight/force is not distributed over much surface area.
I have used long wood blocks under the Mini with no problem (not at the jack point) but a small block at the jack point is a different issue. I have split 6" long 2x4 pine blocks on heavier vehicles, so just be careful.
USNAE2
16
Jun 17, 2022 07:17 AM
M7Speed
Jul 10, 2018 09:26 AM
Doc Pain
Oct 28, 2015 07:09 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
M7Speed
R61 :: Paceman Talk
Oct 1, 2015 06:57 AM
