Instrument replacement
Old May 17, 2023 | 07:49 AM
rustedpalm's Avatar
rustedpalm
05’ r52. Previous owner replaced the instrument cluster so the mileage isn’t correct. That’s ok for me but the seatbelt and air bag lights will not go off. The run flat light is also on.
Codes tell me the belt tensioner is at fault. I’ve cleaned the terminals but light still on. Do the tensioners have a history of going out? I believe the air bag light is connected with this issue because there aren’t any air bag codes specifically activated.
I’ve reset the tpms but it comes back on. The tires are all pressurized correctly and are wearing evenly.
Is it possible the lights are on because the instrument cluster is not coded to this cars VIN?
my apologies if this has been covered elsewhere. I looked but could not find this exact question.
Old May 19, 2023 | 10:39 AM
garry sharp's Avatar
garry sharp
you'd like to do it by yourself ? or in a mechanic shop
Old May 19, 2023 | 04:46 PM
rustedpalm's Avatar
rustedpalm
Ya I’d like to fix the issue myself but if it needs to be coded I may need to have someone else do it.
Old May 19, 2023 | 11:54 PM
RB-MINI's Avatar
RB-MINI
It should be due to the coding of options in the cluster and not the mismatched VIN. The following thread has a lot of info that applies to a swap of any 1st gen main center gauge: https://www.northamericanmotoring.co...hopefully.html
philwarner
16
Oct 20, 2021 06:45 AM
Seraphina
Jun 23, 2018 06:59 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Woobn8r
15
Aug 19, 2008 10:21 AM
koolmini
Aug 23, 2004 10:15 AM
