coolant fan wiring problem
Old Aug 8, 2022 | 02:18 AM
daveking's Avatar
daveking
Hi
had the front off last week.
When put back together the fan on the rad did not work.
Found the resistor blown.
Now fan runs as soon as the engine starts.
Also i found a second small plug on the fan loom
but can't see what it connects to.
Could this be the fan on all the time problem.
Thank you.
dave king
Old Aug 8, 2022 | 09:50 AM
BRGPA's Avatar
BRGPA
If you have an early R53 there are two plugs for the fan, both close together along the top right hand side of the unit as you face it from the front.
Old Aug 8, 2022 | 12:07 PM
daveking's Avatar
daveking
thank you but
Hi
I have the two plugs from the fan.
I do not know where the small plug goes to as
i took the front off.
I need to know where the small plug goes as
i can't see another plug on the car loom.
It must have been plugged in before i took the front
off as the plug is clean inside.
Thank you
Old Aug 9, 2022 | 09:56 AM
BRGPA's Avatar
BRGPA
On my "03 the plugs from the fan join a loom coming from the driver's (left) side. They connect at a spot beside one of the AC valves, and the plugs come out of the looms very close together so I doubt you could miss the other plug. I wonder if your wiring could have been modified at some point. Hope you can resolve the issue without too much aggravation.
Old Aug 9, 2022 | 02:25 PM
Here2Go's Avatar
Here2Go
NAM Community Team
Maybe I missed it.
What year is your Mini?
As @BRGPA pointed out - ' has an '03 which has 2 plugs (larger main and one small). I have an '04 pre-facelift R53 (built in 11.3. 2003) and has only 1 plug (the changed/started in '"p-f" '04 model).
Are you the original owner? The reason I ask is that; if you have a model after 2003 - Someone may have previously replaced the fan with one for an earlier 2 plug wire model (2001 - 2003).
Again as BR also mentioned perhaps it has been re wired to work?
Just curious - What is the coolant temp reading? ....If air in system is present it may cause overheating = the fan will automatically kick on.
I'm no expert. Just a thought.
Old Aug 13, 2022 | 05:50 AM
garry sharp's Avatar
garry sharp
do the car heat up so quickly ?
Petrie_@yahoo.com
40
Jun 14, 2020 08:52 PM
daytripper540
Oct 19, 2016 05:50 PM
jessebiltz
Nov 8, 2012 08:14 AM
zpnbyu
Aug 2, 2010 08:14 PM
ART ED
Jun 2, 2008 01:33 PM
